tightening u-bolts
Discussion in 'Suspension' started by Adam Baum, Mar 2, 2012.
  1. Mar 2, 2012 at 6:30 PM
    Adam Baum
    Adam Baum [OP] Well-Known Member
    PCS
    01 PreRunner SR5 debadged
    Installed a pair of Wheeler's (Alcan) 8-leaf springs a few weeks ago, and now it is about time to re-torque them (according to Wheeler's receipt).
    Should I re-torque my leaf spring u-bolts while the truck is on the ground or jacked up? The FSM says that my torque wrench should be set at 90lbs for an 01 DC Prerunner.
  2. Mar 2, 2012 at 6:40 PM
    Sublime
    Sublime Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    Icon/All Pro.....chopped for 35's
    Not sure if it matters but I do mine on the ground at ride height! Same with the eye bolts/shackle on the springs!
  3. Mar 2, 2012 at 8:17 PM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Won't matter. Do it whatever way is easier for you. Cross pattern torque them for best results with a calibrated torque wrench 40-80% of its range.
