Tightening up the steering on a 2012 Tacoma 2wd....
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 2012_Prerunner_man, Jan 17, 2016.
  1. Jan 17, 2016 at 10:40 AM
    2012_Prerunner_man
    2012_Prerunner_man [OP] Active Member
    J.
    2012 Prerunner Crew Cab
    I bought a 2012 Tacoma Prerunner with 93,000 miles on it ( looks and feels like the majority of the miles were freeway or easy miles ) , but the steering has a very small amount of play at the steering wheel. When driving down the freeway going 65 - 75 mph , it tends to require minor adjustments ( about 1/4 inch of movement ) at the wheel to keep the truck in its lane. I have four brand new Dunlop AT20 Grand Trek tires on the truck , and they are all inflated at 36 psi.
    Is there a part that could need replacing in the steering linkage that would restore the original zero play in the steering wheel ?? What would the best way of determining what is wrong with the steering be ? I don't have great luck with getting any problems resolved at Toyota dealerships , though I do have a gold level extended warranty.
  2. Jan 17, 2016 at 11:51 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    might look up the zip tie mod. But realisticly, go get it aligned, wandering like that tends to be due to bad alignment.
  3. Jan 17, 2016 at 11:57 AM
    TacoTaco15
    TacoTaco15 Well-Known Member
    Jake
    VA
    2015 MGM DCSB PreRunner 2.7
    Sub'ed to see what you do. I have always wondered what specific parts wear out to make the steering wheel give a little bit more over time.
  4. Jan 17, 2016 at 12:00 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Alignment IMO. My 2012 is tight as a tick, yours should be also.
  5. Jan 17, 2016 at 2:02 PM
    2012_Prerunner_man
    J.
    Thanks for the tip... I will go get a 4 wheel alignment on it. - J.
  6. Jan 17, 2016 at 2:04 PM
    Justinlhc
    Justinlhc Not looking for a relationship
    Is the truck lifted or leveled?
  7. Jan 18, 2016 at 9:17 PM
    2012_Prerunner_man
    J.
    No the truck has no modifications to the suspension or frame , or wheels ( no lift kit, etc. )
    - J.P.
    Re : 2012 Tacoma Prerunner that has slight play in steering
  8. Jan 18, 2016 at 9:18 PM
    2012_Prerunner_man
    J.
    I will try lowering the tire pressure a bit , and see if that helps.
    - J.P.
  9. Jan 19, 2016 at 2:11 AM
    bludweiaer
    bludweiaer Well-Known Member
    pa
    2017 Pro DBL Cab,,2020 F3L Spyder...Polaris 800..
    avs rain guards,,,tyger auto tubesteps... stealth SR8's.265/70/17,ridge grapplers..shiftsense pro...
    how do you align the rear 2 wheels ?
  10. Jan 19, 2016 at 3:13 PM
    2012_Prerunner_man
    J.
    I don't know exactly , but I think they just check to see if the rear wheels are tracking properly ( using lasers on a alignment table ), and if it's not in alignment , they make changes to whatever is causing them to be out of alignment from where they should be.
  11. Jan 19, 2016 at 3:24 PM
    Lefthook
    Lefthook Well-Known Member
    New jersey
    2014 DCLB
    Tonneau cover
    First have alignment shop check your front steering and suspension parts for play. If there is any play in any component, then replace it. If the front end is tight you can get what is called a Thrust Angle Alignment. This means they adjust your front wheels to the thrust angle of the rear axle to make your truck drive and steer straight without any pull or wander.
  12. Jan 19, 2016 at 5:28 PM
    2012_Prerunner_man
    J.
    Thanks, I really appreciate the advice... I will definitely go and get that done. - J.P.
  13. Jan 19, 2016 at 10:23 PM
    TacoTaco15
    Jake
    VA
    Let us know how it goes!
  14. Mar 11, 2016 at 2:55 PM
    dirtnsmores
    dirtnsmores A camping truck
    Southern California
    06 DCLB Prerunner
    OME885/5100, DAKAR MED-DUTY, SOFTOPPER
    so how did it go??
