Tile to tub problems.
Discussion in 'Garage / Workshop' started by drewskie, Dec 7, 2011.
  1. Dec 24, 2011 at 11:36 AM
    4Wheelin4Banger
    4Wheelin4Banger Supercharged Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Supercharged Silver State Edition 245WHP
    3" OME lift 885s & Dakars riding on 33" KM2s
    Overfill the spot you want to caulk slightly then run a wet finger (alcohol) over it to smooth the caulk. Clean finger off from time to time with wet rag (alcohol). It takes some practice to get a good clean bead so don't be afraid to clean it off while it's still wet, let it dry & try again.
  2. Dec 28, 2011 at 12:35 AM
    drewskie
    drewskie [OP] Well-Known Member
    Drew
    Burbank, CA.
    08 Prerunner 4 banger
    Jflan, that was an awesome response, thanks. I never thought about using masking tape, but I figured there had to be an easier way to smooth the bead. I thought I was doing something wrong because it was so liquid. I may just leave the lumpy bead there for a while before I try and do a new smooth one.
  3. Jan 9, 2012 at 12:10 PM
    kris77
    kris77 Born in the Backwoods
    West Virginia
    08 DC TRD Sport Speedway Blue
    In channel Vent Visors, AVS Bug Shield, Hankook Dynapro RF10 265/70/17
    First off. Your main problem might be you cut too much off the end of the tube.
    You just need a hole big enough to put something down in like a coat hanger to break the seal. Run a little bead. Just big enough to cover the gap. If its on the shower floor where the door meets, you just need a bead about the size of the cable on your mouse or keyboard, possibly smaller. Lick your finger and run it across the bead in one solid motion from right to left. clean your finger, then run back from left to right. Should be done.
