Tilted Bed
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 4dimad, Dec 15, 2016.
  1. Dec 21, 2016 at 8:26 AM
    Scooby24
    Scooby24 Well-Known Member
    Greg
    2017 DCSB OR 4X4
    Full tank here and only 1/4 inch lower on rear left. Front maybe 1/8 inch difference
  2. Dec 21, 2016 at 8:35 AM
    dilbert
    dilbert AI Member
    PNW
    2019 DCLB TRD Off-Road
    Mine had a really bad lean to the left. I assumed it was just taco lean until it started hitting the bump stops when going slow over speed bumps. It ended up being a blown shock on the left rear. The shock was replaced under warranty and now it's back to normal taco lean.
  3. Dec 21, 2016 at 8:37 AM
    Scooby24
    Greg
    2017 DCSB OR 4X4
    You guys may want the lift the rear, loosen the leaf spring front mount and rear shackle, then lower the truck, bounce on the bed a couple times to put some load on the springs and then retighten the front and rear.
    I replaced the leaf springs on my last truck and had to follow this procedure as tightening the front and shackle mounts with the leaf springs unladen may cause the spring tension to be off.
  4. Dec 21, 2016 at 9:07 AM
    Hail
    Hail Middle Age Crazy Member
    Tomball, TX
    2016 Inferno TRD Sport 4X4
    It may be normal but I don't have to like it. :) I have my first service on Friday and I am going to bring this up.
    baileybrandon likes this.
  5. Dec 21, 2016 at 9:10 AM
    Coot83
    Coot83 DORKEL NATION
    Scottsdale, Az
    2012 Baja TX
    TC 3.5 LT, RCV axles, Demello sliders, BD light bar/fogs, LP6, DMZ rear, SOS skids, custom bumper, King 16" triples, Locked-on hydro rear bumps...
    Taco lean affects the front and rear. My rear SUA kit has two different leaf springs for the kit to account for the taco lean. In time you wont even notice it.
    Coot
  6. Dec 21, 2016 at 3:41 PM
    DarkSky
    DarkSky Well-Known Member
    Oregon
    2016 SR5 Double Cab V6 Auto 4X4 Barcelona Red
    Mine is about one inch lower on the rear left, measured at fender in line with the axle, as in other photos here.
  7. Dec 21, 2016 at 3:44 PM
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    Crappy rear suspension. Mine squeaks too
  8. Dec 21, 2016 at 4:07 PM
    Pittrider
    Pittrider Pitty, those needing correction.
    Greg
    B.C.
    2016 MGM LTD LB
    Do you need to know, or care?
    and you'll get the same response for everything else, "normal".
    Marcoc and smitty99 like this.
  9. Dec 21, 2016 at 4:13 PM
    oldtoyotaguy
    oldtoyotaguy Well-Known Member
    Peter
    Ontario, Canada
    2018 4 Runner ORP
    Stock but with a Warn 10s winch Used to be a lightly modded Tacoma
    Shim it up and make it sit level it's not rocket science. It's a heartless piece of rubber and steel that will behave exactly the way you want it to.
