Tilton Engineering: Hydraulic Release Bearing Conversion Kits (Adapted for +2005 6MT Tacomas)
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by Kasbien, Jul 16, 2023.
  1. Apr 28, 2024 at 12:57 PM
    #81
    TacoTuesday1
    SD CA
    yeah…it doesn’t seem consistent
    On or off road
    I feel like the hydraulic softens what my foot is telling the clutch to do
    kind of like mom and dad both tell you something different
    sounds like the Tilton may be better in that regard
    What’s more, I used to get fluid leaking from the bleeder. Guess I’ll ask them if there’s an easy way to fix what maybe shouldn’t have happened. I’m afraid they’re might not be.
    that SS line probably goes all the way to the bearing inside the bellhousing.
    maybe that has something to do with it. Doesn’t sound ideal to me. Other car bleeders don’t leak when closed.
    way I see it, air is thinner than DOT4. So if DOT4 leaks out, then under suction (pedal going back up) it may be possible for the bearing to pull air into the system up from that
    old temporary bandaid “fix” attempts I’d throw at it anytime this happened was do another bleed.
    It’s def had many more bleeds done than what’s considered normal schedule otherwise.
  2. Apr 29, 2024 at 1:50 PM
    #82
    Kasbien
    Kasbien [OP] Well-Known Member
    Kellen
    BC, Canada
    07 DCSB 6MT 4X4
    Pop rivets and JB Weld.
    Heck yeah! :cheers:
    Tfs94gt[QUOTED] likes this.
  3. Apr 14, 2025 at 6:43 AM
    #83
    Tfs94gt
    Tfs94gt Well-Known Member
    2013 DCSB Trd OR 6 spd
    Didn’t realize it had been over a year since I’ve been running this setup. I’ve taken it from TN to Florida three times and probably have put 20,000 on it over the last year. No issues.
    BillDaCat8 and 1 Limited Toyota like this.
  4. Apr 14, 2025 at 6:33 PM
    #84
    HellsWells
    HellsWells Well-Known Member
    Spencer
    Richmond, Va
    2011 TRD Off Road Double Cab
    Same here, I’ve had Kasbien’s kit installed since September 2023. Zero issues whatsoever. I’ve found the hydro setup take a finer degree clutch actuation/modulation than the OEM setup, which is a huge plus for me. Use HP Tuners to eliminate the rev hang and install a larger clutch pedal set and short shifter- you can drive your tacoma like a sports car without getting sports car tickets :)
    dborrer, BillDaCat8 and Tfs94gt like this.
