Tim, recommend plating the bumper mounts?
Discussion in 'Elite Off-Road' started by drarin, Nov 14, 2011.
  1. Nov 14, 2011 at 8:27 PM
    drarin
    drarin [OP] Well-Known Member
  2. Nov 15, 2011 at 2:10 PM
    Timicha
    Timicha Timicha
    TIM
    Tillamook / Portland , Oregon
    04 White Tacoma
    Fabtech 4 inch lift, tinted windows, diff drop, 33 inch MTZ tires on Raceline Raptor wheels, ELITE OFF-ROAD bumpers and sliders
    if you were to weld them in then yes it would make a difference but where he says its "optional to weld them" in is wrong because if you didn't weld them in then it wouldn't be any different than having the plate bumper bolted to the mounts besides the fact that you would then have two plates bolted to the mounts. I offer frame reinforcement plates that strap from the bumper mounts to a hole in the frame and they would offer more than enough strength for any bumper.
    so if you want to spend the 35$ then i would suggest getting them completly welded on. you could also just tell me if you want them and i could cut you out a set and strap them with the bumper. let me know if you have any other questions
  3. Nov 15, 2011 at 2:20 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    It seems if those bolts were torqued down evenly and correctly, that situation shouldn't be able to happen. I don't see how you can snap off the bolt mount on one side and not even tweak the bolt mount on the other side. That's a wide mount so to me it seems things weren't tightened down properly when that bumper was installed.
    Any comments from the fabricators?
  4. Nov 15, 2011 at 2:28 PM
    Timicha
    Timicha Timicha
    TIM
    04 White Tacoma
    ya i've seen it happen on 2nd gens from pulling hard on an aftermarket bumper, the front mounts are only 1/8" steel and not supported the greatest, but those plates the guys offering would only work if welded in
  5. Nov 15, 2011 at 2:33 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    x2
