Timbren Suspension Enhancers versus Wheeler's SuperBump Bump Stops?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by keninsb, Mar 22, 2014.
  1. Mar 22, 2014 at 3:51 PM
    keninsb
    keninsb [OP] "Senior", Senior Member
    Ken
    Goleta, CA
    '13 Taco DC 4WD V6 LTD
    I was thinking about upgrading the bump stops on my 2013 Tacoma Double Cab 4WD 4.0L Limited. I REALLY like dealing with Wheeler's and know they make great stuff. I was thinking about putting the Timbren sets in the front and back, but have noticed that a lot of guys seem to be putting the Wheeler's SuperBumps on the front and the Timbren setup on the back. Is there a reason for that? What setup do you guys recommend for my truck? Here are some of my truck specs:
    OME 52887 Coils in front
    Icon Progressive 3 leaf add-a-leafs in the rear
    Bilstein 5100 shocks all around
    Any input is GREATLY appreciated!
    Thanks,
    Ken
  2. Mar 22, 2014 at 4:16 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    IMO, the timbren ones are WAY over priced.... that much for a piece of rubber, jezus.
  3. Mar 22, 2014 at 5:27 PM
    keninsb
    Ken
    Goleta, CA
    I agree, they are a bit pricey, but was wondering if anyone has any feedback about performance, etc. You know, useful info :D
    Just kidding, but would like to know how both brands perform.
    Thanks again,
    Ken
  4. Mar 22, 2014 at 6:23 PM
    RacecarGuy
    RacecarGuy Well-Known Member
    Houston, Texas
    '12 DCSB OR
    Pelfreybilt front and rear HC bumper w/swingout, BAMF LCA Skids, BAMF Diff skid, Pelfreybilt IFS and Trans skid, RCI gas tank skid, Bronze SCS F-5's, Icon RR's ext travel, Dakar leafs, Archive Garage shackle flip
    I have Superbumps and they're nice. You can't even tell when they bottom out. I heard the Timbrens tend to bouncy on the rebound.
  5. Mar 22, 2014 at 6:26 PM
    Jeremy M.
    Jeremy M. Well-Known Member
    Fort Drum, NY
    13 DCSB TRD Off Road
    I have had timbrens on two previous vehicles, they are great for load carrying, but are stiff enough to limit articulation.
    Black Taco likes this.
  6. Mar 22, 2014 at 6:53 PM
    keninsb
    Ken
    Goleta, CA
    Thanks guys, that is exactly the kind of feedback I was looking for.
    Thanks again,
    Ken
  7. Mar 22, 2014 at 6:55 PM
    CanisLupus
    CanisLupus Member since 2011
    Stokesdale | NC
    ‘19 Honda Civic Hatchback
    I have heard Timbren's are better for towing while SuperBumps are better for offroading. (I have SuperBumps FYI and like them)
    Rehak90 and Black Taco like this.
  8. Mar 22, 2014 at 7:11 PM
    keninsb
    Ken
    Goleta, CA
    Thanks Matt. I don't do a whole lot of off roading, but build my truck kin of with the attitude that it is better to have and not need than to need and not have. It is my "every day driver" even though I don't put a LOT of miles on them. What do you guys think a wannabee like me should use (and is the most prudent choice? Damn I am getting old. The last time I heard "prudent used in a sentence I think I was either in my teens or drunk (or both).
    Ken
  9. Mar 22, 2014 at 7:20 PM
    CanisLupus
    Stokesdale | NC
    I think SuperBumps would be a good choice, although there are cheaper alternatives that are still a little better than the stock crap. I think Daystar, All Pro Offroad, and some others makes polyurethane ones that are pretty good.
  10. Mar 22, 2014 at 7:21 PM
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
    I have Superbumps on the front, and the difference from stock is considerable. No more jarring hard hit, thinking you broke something from driving through a pothole.
    DoorDing likes this.
  11. Mar 22, 2014 at 7:58 PM
    robm7
    robm7 Well-Known Member
    2012 TRD OR
    I have Timbrens for towing not off roaring. keep the bed from bottoming out. I like them
  12. Mar 23, 2014 at 10:18 AM
    keninsb
    Ken
    Goleta, CA
    Thanks guys. I have had good luck with DayStar parts too, them and Energy Suspension, but mainly for bushings, etc.
    Robm7, how is the daily driving with the Timbren setup in the rear?
    Thanks again to all.
    Ken
  13. Mar 23, 2014 at 12:23 PM
    robm7
    2012 TRD OR
    Driving is normal with them, there is a 1/2 to 1 inch gap between it.
  14. Mar 23, 2014 at 5:21 PM
    keninsb
    Ken
    Goleta, CA
    Gotcha. Like RaceCarGuy said, I have been hearing more about the "bounce back", especially on the front Timbrens setup. Decisions, decisions...
    Thanks again,
    Ken
  15. Mar 23, 2014 at 5:54 PM
    robm7
    2012 TRD OR
    Good luck
  16. Mar 23, 2014 at 6:06 PM
    keninsb
    Ken
    Goleta, CA
    Thanks man. I always need all the luck I can muster up, not matter what the situation:)
  17. Mar 23, 2014 at 9:32 PM
    JimBCa
    JimBCa Well-Known Member
    Jim
    Bay Area California
    2012 TRD Off Road
    Build Duratrac 265/75R16 Load rated E BAMF Rock Sliders, Pelfreybilt Front bumper and skid plates (3) Pro Runner front and rear shocks,Add-A-Leaf springs ATO (Armor Tech Offroad) hilift mounts, Famous Fabrication cb antenna/flag mount CoverKing Tactical seat covers, Flyzeye dash-light ARE Shell, backup light mod SumoSprings and Stops
    I just installed Sumo suspension set up for front and rear. I have loaded my truck up with off-road protection, which added a bit of weight, plus pull a boat from time to time. Mine look about the same as the others, not sure which are better. I really noticed a big difference in the ride, not as bouncy, and no dip diving into the corners. When the boat is connected, ride is smooth as well.
  18. Mar 23, 2014 at 9:36 PM
    FatTony415
    FatTony415 Well-Known Member
    Tony
    San Francisco, CA
    '20 DCSB 4x4 TRD Off Road
    Stock for now
    I have the SuperBumps and like them. I don't tow, but I haul a lot of equipment so I sometimes bottom out the rear. The Wheeler's really smooth it out - it almost feels like you're still going through the spring compression. WAY better than stock! And they're reasonably priced.
  19. Mar 23, 2014 at 9:37 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    I heard the Timbrens will buck real bad when off roading!
  20. Mar 23, 2014 at 9:39 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Superbumps in front, which are AMAZING for offroading, and GM Silverado bump stops in the rear, both the mismatch bump stops made of the same material are EXCELLENT for offroading, and absorbing the blow of landing from a jump while offroading.
    Biscuits likes this.
