Timbrens Harsh ride on 2010 DC TRD Sport!
Discussion in 'Suspension' started by StandupTaco, Jun 7, 2010.
  1. Jun 7, 2010 at 8:44 AM
    StandupTaco
    StandupTaco [OP] Well-Known Member
    2010 DC TRD Sport
    I installed these things on a reccomendation from a friend who owns a Tacoma and I wish I hadn't. They were installed professionally with the required gap and man, oh man what a pounding they make on a less then perfect road with no weight whatsoever in the bed. Even with just me driving on some bumps in the road the truck hits hard, hard enough to feel it in my back. These things have no soft lead in transition at all, in other words, non-progressive! I took them off and went stock until I figure out something else. On a smooth road it's fine but any bump whatsoever you'll feel it. Anyone else find them rough? I took them back today for a refund!
    FYI, my truck is Canadian so it has a 4 leaf pack. I just installed a Cap on the bed and even though it's still higher in the rear the leafs are almost straight. Shouldn't there be some arch there?
  2. Jun 7, 2010 at 4:45 PM
    Eesh
    Eesh Well-Known Member
    Regina, Sask., Canada
    trd Sport
    Did you get the TSB done?
  3. Jun 7, 2010 at 4:48 PM
    StandupTaco
    2010 DC TRD Sport
    No need for the TSB as it came with a 4 leaf pack anyways! I would think if I added another TSB leaf it would ride like crap, No?
  4. Jun 7, 2010 at 4:49 PM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    With the vehicle sitting unloaded. What is the gap between the timbrens and the axle (where they contact)?
  5. Jun 7, 2010 at 5:10 PM
    StandupTaco
    2010 DC TRD Sport
    The gap was close to 1 1/2". It's what they called for and I thought there was a spacer in there but there wasn't as I asked them to take it out to see if that would help. Was wondering if they ordered the right set of Timbrens and they ordered what it was calling for, TORTUN4, for the 4 leaf pack...Not sure what the 3 leaf pack would be like?
    Here's the link for it!
    http://timbren.com/timbren-application-guides/toyota.htm
  6. Jun 7, 2010 at 5:19 PM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    Huh. Everything sounds right. But if you are unloaded, you really shouldn't be hitting them unless doing some big whoops or jumping. Normal driving should not have them come into play.
  7. Jun 7, 2010 at 5:35 PM
    StandupTaco
    2010 DC TRD Sport
    That was my understanding also! I guess the Tacoma leaf pack flexes enough (soft) to bring them into play a little earlier then expected.
    Like I mentioned the road isn't perfect but it's far from jumping or anything along those lines, just some unevenness/imperfections/bumps in the road surface....
  8. Jun 7, 2010 at 6:16 PM
    mgrande
    mgrande iKill
    Raleigh
    2011 TRD off road
    Kings, AP 3" leaf pack, timbrens front and rear, TC UCA's, pro comp 7189's, baja ATZ's, CBI sliders and rear, relentless front, dynomax catback
    You said your leafs are almost flat? maybe you could post a picture so someone could check them out. Maybe they're worn prematurely.
  9. Jun 7, 2010 at 6:19 PM
    thinkingman
    thinkingman Well-Known Member
    redmond WA
    2006 dbl cab 4wd 6sp
    Foglights are for fog, not oncoming traffic!
    Can't imagine why you're getting so much contact on the Timbrens?
  10. Jun 10, 2010 at 7:23 PM
    StandupTaco
    2010 DC TRD Sport
    New Truck only 2 months old and the Timbrens were installed 1 week from new. I assumed with the 4 leaf pack that's the way they were. I will post a pic when I get a chance over the next couple of days....
    Me neither! I've since took them back for a refund so onto other options in the near future.
  11. Jun 10, 2010 at 10:53 PM
    bajamoon
    bajamoon Well-Known Member
    STEVE
    Whittier
    i hated mine when i had them, they were on the truck for two days. going over speed bumps felt like you were getting rear ended.
  12. Jun 10, 2010 at 11:03 PM
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    i have mine with the all pro 3" leaf pack and I love them
  13. Jun 11, 2010 at 2:19 PM
    StandupTaco
    2010 DC TRD Sport
    I think they need more gap so if you installed an AAL in the back then that would raise the rear more and give more clearance so they don't come into play so soon. Stock suspension is too soft and they hit too soon and too abrupt. That's just my 2 cents!
  14. Jun 11, 2010 at 6:46 PM
    bajamoon
    STEVE
    Whittier
    i had deaver 10 pack so keep splainin
  15. Jun 11, 2010 at 11:59 PM
    numbah57
    numbah57 GIVE THE MALL A BREAK...WHEEL THAT SHIT
    kahai
    Maui, Hawaii
    09 tacoma 2.7 Beaten not Babied
    URD ARB G2 PELFREY BAMF LCE AFE
    Put some hydraulic bump stops in there
  16. Jun 12, 2010 at 4:40 AM
    StandupTaco
    2010 DC TRD Sport
    I didn't know they made such a thing. I've heard of airbags but not Hydraulic Bump stops!
    Well Bajamoon, if yours still bottom out with that then there's no more splainin I can do. They just didn't work like I expected, hit too hard and too often where my back couldn't take it. When my kids were in the back it hit sooner so it was no good. I don't recommend them at all on the Taco! Again IMHO!
  17. Jun 19, 2010 at 6:22 AM
    huntingskeetman
    huntingskeetman Member
    Olmsted Falls - Ohio
    Tacoma 4WD Access Cab
    I was considering the Timbren's also for my 06 Access Cab 4x4, but ended up going for the Roadmaster Active Suspension instead. Just got kit this week and will be installling next week, along with some TRD Bilstein's all around I got from somebody on this forum. I got screwed by Toyota, who wouldlnl't do TSB mod because I was out of warranty by 3mos last spring, so I decided to come up with my own remedy. The TRD shocks should give me a little firmer ride than standard and the Roadmaster only kicks in when loaded, so it shouldn't affect ride quality around town.
