Time for a dealer visit---
Discussion in '2nd Gen. Tacomas (2005-2015)' started by nighthawk87, May 10, 2010.
  1. May 10, 2010 at 7:46 PM
    nighthawk87
    nighthawk87 [OP] Well-Known Member
    Taking the truck into the dealer tomorrow for the following:
    -Squeeky rear leaf springs
    -Metal clank sound when initially starting to move after parked
    -Popping noise when turning onto an incline (suspension flexes)
    -Vibration in steering wheel at around 50-65 MPH
    -Harsh 1-2 shift (always been there and they its always "normal" to them)
    Anybody have similar issues or maybe know whats wrong. Anything common on here? If I could get the above fixed then this truck would be flawless
    I have a 2008 DC SB 4x4 Taco
  2. May 10, 2010 at 7:48 PM
    MxRacer190
    MxRacer190 Well-Known Member
    Georgia
    06 SR5 4x4 Indigo
    harsh shift is normal.
  3. May 10, 2010 at 7:51 PM
    nighthawk87
    no its not buddy, why does everyone accept it. shi* I hate it
  4. May 10, 2010 at 7:59 PM
    nighthawk87
    I did go mudding and they were worse until I washed them, but they're still squeeking. Not acceptable, the truck should be able to handle a little mud.
    Brake shoes look fine, they shouldn't be re-seating, whatever that means
    Tires may be out of balance, I noticed it after I had them put on. Its been a while now so I'm not sure if walmart will re-do it.
    Level check and yes its fine.
  5. May 10, 2010 at 8:38 PM
    Hootbro
    Hootbro Omnipotent
    Delaware
    2009 Tacoma Regualr Cab 4x4 2.7L
    Kinda helps if you put your vehicle particulars in your profile information or in a signature.
  6. May 10, 2010 at 9:13 PM
    SandyEggo
    SandyEggo Member
    So Cal
    2013 Prerunner SR5 access Cab
    nevermind
  7. May 10, 2010 at 9:37 PM
    nvdeserted
    nvdeserted Well-Known Member
    Reno, NV
    2009 Tacoma TRD OR Access Cab
    Electric Dynolock tailgate, TrailGear Slides, , 285/75-16 Yoko Geolanders on Wheelers Type B, SAW 2.0 front and back, Camburg b/j UCA, 1.5" AAL, Ubolt flip, ARB bump.
    The first 4 issues could all be stemming from an issue with your leafsprings...
    From my exp 90% of sqeeky suspension is a result of dirt/grime in components; the other 10% is from worn/loose suspension components. It's a good idea, after you pressure wash the underside, to spray eveything under the body that's black with Armorall or a Silicone spray, whichever you prefer.
    As for the wobbly front at 50mph it's probably a tire issue (blancing etc) but that might stem from an alignment/suspension issue that's caused your tire to deform, or hopefully you just lost a 25cent weight from our wheel and it can just be rebalanced.
    Good luck. Let us know what happens.
  8. May 10, 2010 at 9:42 PM
    nighthawk87
    Thank you nvdeserted, you made me think! lol
    I went offroading right after I got my A/Ts installed to try them out. I bet I knocked one of the weights off. Come to think of it, thats when I noticed the vibrating...I just thought it was a balancing issue from the beginning that I didn't notice right away and I did it offroading.
    Regarding the leaf springs, I hope your right. I knwo the squeeking is from that and hopefully the dealer will fix it. I removed my hitch ball so hopefully that was the clanking.
    I will be so happy if I can fix everything. My biggest pet peeve with the truck is seriously the 1-2 shift though.....I really wish it was smooth like the other gears. Sometimes it feels like a old truck shifting if you knwo what I mean.
  9. May 10, 2010 at 9:46 PM
    knickerbocker
    knickerbocker Well-Known Member
    middle
    '07 Indigo 4.0l 4x4
    the leading minor of order 1 is not positive definite.
    i get the metal clang when first starting off, but usually it's when i put on the brakes to back up after pulling out of my parking spot, happens more frequently/severely the sharper the wheel is turned. i also get the pop when i hit a bump during a low-speed, sharp turn. i also have a lift, however, so i have many more possibilities for source of problem. anyway, let us know what you find out.
  10. May 10, 2010 at 9:51 PM
    nighthawk87
    Thanks guys, keep 'em coming. I am just the type of person to like a perfect vehicle all the time. Little noises really drive me crazy the most. At least this Tacoma (fingers crossed) for the past 36K miles has been rattle free inside. Even my $38K lexus IS had rattles in the dash, lol.
  11. May 10, 2010 at 9:53 PM
    nvdeserted
    Reno, NV
    I had a 'lost wheel weight issue' a while back, I don't know if the installer forgot to put his purse down first or what but a few went missing in about a week and caused a crappy ride between 45-55mph.
    Also, shifting should be smooth. I'm still surprised at how smooth the shifting is in mine, even when I'm on the gas going uphill (usually when it's harshest) so hopefully they can figure that one out for you. All trucks are a little different but there ARE smooth shifting Tacos out there. Occasionally it can be a little harsh when I'm towing but I guess that's expected.
  12. May 10, 2010 at 9:56 PM
    nighthawk87
    I know it should be smooth, thats why I keep pressing the issue, but until something breaks, I don't think they'll do anything :( . I do understand them though because I have no idea what could be wrong....only thing I can think of is the torque converter.
  13. May 10, 2010 at 10:48 PM
    TRDsport253
    TRDsport253 Well-Known Member
    Fife, Wa
    05 PreRunner TRDsport
    TRD Cold air TRD Cat-back
    I too have the harsh shift. And it is not normal for the truck to do that. I've address the isssue numerous time and no fixs. There are tsb out for the 09-10 model they can get the ecu reflash done but how bout the 05-08 owner out there. Are we out of luck?
  14. May 11, 2010 at 9:47 AM
    dtaco06
    dtaco06 Strawberry abuser
    Danny
    Orange County
    06 BSP AC PR / 07 4Runner
    First post, long time lurker. My truck is currently at the dealer for harsh shifting. It's a 2006 with 60,189 miles on it, OF PR. I'm currently being told that the tech can't replicate the problem. My ass, it's there. So I'm taking the tech for a drive in a couple hours to make sure I can get it to shift hard. I've tried arguing the reflash, but I've been told since the 2006 isn't in the tsb, they can't do it. It's total crap. I have a 100k extended so if they don't fix it, it has been documented I had it in, and then I'm going to drive the truck as hard as possible and grenade the trans (not really, but it sounds good right?) I'll keep you all updated as to if they tell me it's normal, but I know it can't be.
  15. May 11, 2010 at 10:16 AM
    1TUFFTRD
    1TUFFTRD WTF
    out and about building powerlines
    06 AC with a skewp
    06 With a Skewp.
    Make em fix it
  16. May 11, 2010 at 3:18 PM
    TRDsport253
    Fife, Wa
    Yeah please keep us updated so maybe I too can remedied my problem thanks in advance.
  17. May 11, 2010 at 3:36 PM
    Good351
    Good351 Well-Known Member
    Ames, IA
    03 4Runner V8
    My rear leaf's used to squeek like mad! I took it in to get the rear leaf TSB springs and mentioned this to the techs. They said there is another TSB for squeeky rear springs and that the new leaf packs would be way better. They were spot on! The new springs are quiet and ride much better.
  18. May 11, 2010 at 3:49 PM
    dtaco06
    Danny
    Orange County
    Well, I went by the Dealer at lunch to take my truck for a test drive with the tech, but the dude handling my case was on lunch even though I said I would be there about noon and he confirmed he would be available. Pretty much pissed me off so I just picked up my truck and left. The paperwork I got says that the truck shifted smooth and the tech could not replicate the problems I was having. It also goes on to say that the transmission is electronically controlled and any major issues would throw a code on the scan tool they use while diagnosing.
    This is the second time I've gotten the runaround at this particular dealer. The only reason I keep going back is because I don't have to pay my extended warranty deductible if I take the truck back to where I bought it for any warranty repairs. At this point, the problem has been documented and if it continues to get worse, I will go back again. I don't have the time or energy to fight with Toyota or the Service department, so I'm just going to keep driving until something finally gives.
  19. May 11, 2010 at 4:52 PM
    newtaco2008
    newtaco2008 Well-Known Member
    Fort Mill, SC
    08 prerunner indigo ink pearl
    hey nighthawk, i have 2008 access cab 4.0 auto and have the same problem, along with wind noise and some other small issues but i have been told by 2 dealers that this is normal even though my taco has a matching vds in the vin for tsb 0373-09. going to try my 3rd dealership on 5-14-10. I will let you know what they say..btw, does your transmission have a lag sometimes after making turns and driving in stop and go traffic?
  20. May 14, 2010 at 2:11 PM
    newtaco2008
    Fort Mill, SC
    Just got my truck back from the 3rd dealer. The tech said my transmission was low on fluid and filled it. Seems to shift a little better, he also said the tsb is for 2009/2010 only even though I had a matching vds in the vin. Anyway while the truck was there they replaced the entire back sliding glass window due to a faulty seal on the sliding glass part, $900.00 bucks, they ordered new door seals and a new latch for the sticking access door. I finally have a a taco that I like!!!!!!!!..thanks toyota for picking up the tab
