Time for a new battery? 2018 original 55k
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 908tacoma, Jan 4, 2024.
  1. Jan 4, 2024 at 8:00 AM
    908tacoma
    908tacoma [OP] Well-Known Member
    New Jersey
    2018 MGM
    OME, SPC, TRD
    Still smooth sailing, voltage is good, cranks a little slower now that the temperature has dropped but other than that seems fine. What’s the consensus? I do travel a bit to very cold areas and don’t have a garage so curious if now a a good time to replace before I get stuck.
    Stevie17 likes this.
  2. Jan 4, 2024 at 8:16 AM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    You got your moneys worth out of it - batteries usually fail at inconvenient times.
    My favorite brand is DEKA/East Penn Mfg, made right in Pennsylvania.
    NAPA brand batteries are made by EPM.
    https://www.eastpennmanufacturing.com/
    Chew, shakerhood and 908tacoma[OP] like this.
  3. Jan 4, 2024 at 8:26 AM
    RichochetRabbit
    RichochetRabbit Bing Bing Bing
  4. Jan 4, 2024 at 8:29 AM
    2021SR5V64WD
    2021SR5V64WD Well-Known Member
    2021 SR5 V6 4WD ACCESS CAB
    5 years? Duh. Chalk up a win and buy a new one - Walmart NeverStart ( ever start ) is as good as anything else for the price.
    mikesixtysix, Chew and 908tacoma[OP] like this.
  5. Jan 4, 2024 at 9:23 AM
    908tacoma
    New Jersey
    2018 MGM
    OME, SPC, TRD
    Thanks. I’m going to NAPA now and I’ll install a fresh one this weekend.
    Chew, RustyGreen and shakerhood like this.
  6. Jan 4, 2024 at 9:34 AM
    Mallcrawler20
    Mallcrawler20 Well-Known Member
    Trd off-road 4x4 Manual
    Oem battery ? Thats impressive mine took a dump after 3 years . But I was running car audio amplifier . So more than Likely the cause of the failure.
    908tacoma[OP] likes this.
  7. Jan 4, 2024 at 9:35 AM
    RustyGreen
    sleeping in a chair
    Pavement Princess
    If you have a battery maintainer put it on the new battery until you install it.
    Batteries generally ship about 80% charged, a day or two on the maintainer gets your new battery off to a good start.
    Two units to consider are NOCO Genius 1 or a Deltran Battery Tender.
    Both brands are tech leaders and well established with good reputations.
    Either model is easily available at online, your local auto parts store or The Mart for around $30.
    The NOCO unit has more functions, the Deltran is slightly easier to use, I have several of both and they have given good service.
    https://no.co/products/charging/genius
    https://www.batterytender.com/battery-chargers
    Chew and 908tacoma[QUOTED][OP] like this.
  8. Jan 4, 2024 at 10:07 AM
    908tacoma
    New Jersey
    2018 MGM
    OME, SPC, TRD
    yeh very impressed honestly. OEM, bought truck new
  9. Jan 4, 2024 at 10:08 AM
    908tacoma
    New Jersey
    2018 MGM
    OME, SPC, TRD
    yep thanks, I have a CTEK I like to use
    RustyGreen[QUOTED] likes this.
  10. Jan 4, 2024 at 10:18 AM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    Is this a serious question? Go get you a new battery OP!
  11. Jan 4, 2024 at 10:27 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    past due
    chasecmc and 908tacoma[OP] like this.
  12. Jan 4, 2024 at 10:51 AM
    908tacoma
    New Jersey
    2018 MGM
    OME, SPC, TRD
    TacoTime55, chasecmc, b_r_o and 3 others like this.
  13. Jan 4, 2024 at 10:55 AM
    Chew
    Chewy
    Midwest
    19 TRD OR
    I like to get in and drive :rofl:
    but, difference is the spice of life my friend!
  14. Jan 4, 2024 at 10:55 AM
    Stevie17
    Stevie17 Well-Known Member
    Stevie
    Crossville, Alabama
    24 Celestial Silver Sr 5 DCSB 4x4
    When you bought it, did you get a lifetime battery? I just replaced mine at 80k and got lifetime for as long as you own the vehicle the battery is replaced for free. :thumbsup:
    908tacoma[QUOTED][OP] likes this.
  15. Jan 4, 2024 at 10:59 AM
    Yoda_Mike
    Yoda_Mike YotaWerx Authorized Tuner
    Michael
    South Glens Falls, NY
    2019 Tacoma TRD Sport
    YotaWerx Blackhawk 2.0 tuned. Typer Auto tail light guards. Rough Country tri-fold tonneau cover. Start-X remote starter. Injen CAI. MBPR Armor Plus high clearance exhaust.
    A load test is the proper way to answer this question. If the battery is weak, a quality load tester will identify that. I've seen batteries last 10 years. I've also seen brand new batteries fail a week after install. Load testing in the only definitive way to check their integrity.
    02TRDXTRA, bfonic and 908tacoma[OP] like this.
  16. Jan 4, 2024 at 11:13 AM
    908tacoma
    New Jersey
    2018 MGM
    OME, SPC, TRD
    Hmmm I’ll check
    Stevie17[QUOTED] likes this.
  17. Jan 4, 2024 at 11:22 AM
    smallfrye
    smallfrye Well-Known Member
    Stock
    I'm at 86k on the original battery on my 2018 and it works fine.
  18. Jan 4, 2024 at 11:26 AM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    My 2018 battery was finally replaced a month ago at 65k miles.
    It also was getting a little slow with the cold front, so I took the multimeter to it. A good battery should read 12.6V after the car has been shut off for more than an hour, and should be replaced if its below 12.2. Mine was 12.3, which was borderline. Then I did the engine start test, where a good battery should never drop below 10V when cranking the engine. Mine was right at 10.0V on the first start, 9.9V on a second start 15 minutes later.. So yeah, it got replaced.:anonymous:
    In retrospect, it was easier to swap the battery at the store when you drove it there instead of having to carry it.
    b_r_o, StayinStock, willtill and 3 others like this.
  19. Jan 4, 2024 at 11:41 AM
    Stevie17
    Stevie
    Crossville, Alabama
    They said mine was still good but @ 80 but I didn’t want to wait for it to start giving me trouble. :thumbsup:
  20. Jan 4, 2024 at 11:42 AM
    surfingtaco209
    surfingtaco209 Well-Known Member
    Jamie
    2019 Tacoma
    Damn. Replaced my 2019 OEM last summer. Started cranking a bit slow for a couple of days then boom, dead. 55K.
