Time for a real stupid question?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Fore, Apr 18, 2011.
  1. Apr 18, 2011 at 8:08 AM
    Fore
    Fore [OP] Well-Known Member
    07 PreRunner
    Just trying to be safe, I would like to know where is the best place to put the hydraulic jack to lift up both front tires off the ground and then where to set the jack safety stands? Also, how may tons should the hydraulic jack be to lift it up properly and how many tons should the jack stands support? Do I need to take the front skid plate off to do this? Thanks for your help any pic's would be great ~
  2. Apr 18, 2011 at 8:11 AM
    Namyo
    Namyo -
    dono what kind of jack or stands you have.....but frame is where you want ur chit.
  3. Apr 18, 2011 at 8:13 AM
    AndrewFalk
    AndrewFalk Science!
    The North East
    2010 5 speed 5 lug
    Owners manual.
  4. Apr 18, 2011 at 8:14 AM
    rex99
    rex99 Well-Known Member
    TArdCOMAWORLD
    Proton Cruiser
    Rocket Boosters, Flux Capacitor, Escape Pod, Throttle Body Spacer, Homeroshi, ATRAC disable
    ^^this
  5. Apr 18, 2011 at 8:42 AM
    Tacozoid
    Tacozoid Well-Known Member
    Terry
    Katy Texas
    White Tacoma Pre-runner
    Billsteins,Texas tint. Blue Dash mod. Console mod. in Blue, Customized grille
    I don't know........Gas tank maybe??
  6. Apr 18, 2011 at 8:48 AM
    OffroadToy
    OffroadToy This ain't Dodge City, and you ain't Bill Hickok
    4X4 Offroad
    snugtop, piaa, weathertech, westin, oem bed mat, trd seat covers, avs inchannel vent visors, 2" suspension lift, front diff drop, rear differential breather extension, oil filter drain hose, a/c drain hose extention & reroute, front window tint, cat theft protection plate, tailgate clamp mod, xpel headlight/foglight protecters, oem block heater, bfg 265/75R/16 a/t k/o's, cabin air rodent protection screen, rcbs illuminated 4X4 switch mod
  7. Apr 18, 2011 at 9:33 AM
    jpmorrisvb
    jpmorrisvb Well-Known Member
    Jimmy
    Virginia Beach
    2014 Barcelona Red TRD Off-Road PreRunner
    Clazzio seat covers, KB Voodoo Powder Coated Tailgate Cap, OEM running boards, ImMrYo Rear-View Mirror Lift Bracket, 35% Tinted windows, EGR window vents, color matched door handles and tail gate lift, WeatherTech FloorLiners, OEM bed mat, sound dampening on rear wall and rear doors, on anytime foglight mod
  8. Apr 18, 2011 at 12:21 PM
    Primersinmyshoe
    Primersinmyshoe Old Sheepdog
    St. Louis, MO
    gray, shiny, dependable
    Glock 36, spare mag
    This is from the link:
    (c) When jacking up the vehicle, first release the
    parking brake and move the shift lever to N.
    I am used to leaving it in Park when lifting a vehicle with a jack. Wouldn't the truck want to roll off the jack if you pushed it a little?
  9. Apr 18, 2011 at 12:51 PM
    OffroadToy
    4X4 Offroad
    I could be wrong but I think that's when useing a floor jack to lift both front or rear tires...helps keep the weight of the vehicle firmly on the pad of the jack. The tires on the ground rotate a bit as the opposite end comes up. Make sure your on a level surface, block the tires, and always use jack stands. While lifting from the frame where only one tire is lifted I think the parking brake method still applies.
    edit...I just noticed that it mentioned being in neutral also. How can that be done with these automatic's...leave the key in the ignition turned to accessories?
  10. Apr 18, 2011 at 12:53 PM
    jjew18
    jjew18 the Nightman cometh!
    Alliance Airport
    05 PreRunner SR5
    Added extra awesomeness to its original awesomeness.
    Depending on truck and mods (tires, grille guard etc.) your truck is sitting right at 2 tons, you may be able to go 2 tons, but three to safe. I tried a 2 ton jack and got about an inch off the ground and it was extremely difficult to jack up. I returned it and got a 3, no problems.
  11. Apr 18, 2011 at 12:59 PM
    jjew18
    Alliance Airport
    05 PreRunner SR5
    I wouldn't put it N, I would release the break, I do chock the wheels from rolling back. The jack should have wheels to allow slight movement from the action of jacking. I could be wrong but, I don't want my vehicle moving too much.
  12. Apr 18, 2011 at 1:01 PM
    jjew18
    Alliance Airport
    05 PreRunner SR5
    Leave the key in or use the release (the little button cover to the left of your shifter, pop it off and stick in your key).
  13. Apr 18, 2011 at 1:18 PM
    OffroadToy
    4X4 Offroad
    Good point on the floor jack having wheels. What's the purpose of being in neutral with the parking brake off then...I don't see a issue as long as the jack has some movement. :confused:
  14. Apr 18, 2011 at 1:20 PM
    VooDoo
    VooDoo More Cowbell!
    Carter Ivey
    Baton Rouge, LA/ Starkville, MS
    '06 DC LB PreRunner
    :laughing:
  15. Apr 18, 2011 at 1:31 PM
    jjew18
    Alliance Airport
    05 PreRunner SR5
    After reading the link from above, here is my take:
    When you chock the wheels in front and back of the wheel, this will keep the vehicle from moving forward and back.
    However, you want the axle to have movement, because when you jack one end, the other rotates. Hence putting in Neutral allows rotation.
    Interesteing, I have never looked at it this way. And yes, the wheels on the jack then allow for any movement on the lifted end while jacking.
  16. Apr 18, 2011 at 5:13 PM
    Fore
    07 PreRunner
    Thanks everyone lots of good advice. Does anyone have pictures showing the positions how they lifted and supported their truck with jack stands.
  17. Jun 19, 2011 at 3:42 PM
    samsung
    samsung Well-Known Member
    George
    Sugar Land, Texas
    2011 PreRunner doublecab TRD Offroad
    undercover lid/Ipod integration kit/Pop n lock/bed rug, fumoto drain valve, full piping Wet Okole covers, Blacked out badges, Lamin-X fog light cover yellow, window tint, ARB deluxe bumper with fog light kit,DSM UCA'S,3 support shrockworks sliders,complete OME lift with 886X coil and dakar leaf spring with 3 degree axle shims and center pin lenghtener,warn VR10000 winch,amsteele blue synthetic rope, daystar winch isolator, daystar delrin rollers, IPF 900xs Extreme Driving H9 Kit 900XSD (900XSD),Horn on fire with shot Penning,
