Time for front brakes
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Soulsurvives, Oct 26, 2022.
  1. Oct 26, 2022 at 5:17 PM
    Soulsurvives
    Soulsurvives [OP] Well-Known Member
    Bill
    2009 Tacoma
    So I have a 2009 TRD Sport dcsb with almost 190k and I'm doing the front brakes. I am replacing the rotors and pads with Advics. The calipers have seen better days so I'm gonna swap those out as well. I've narrowed it down to new units from a Toyota dealer for about $500 or reman units from Power Stop for about $200. Any advice on which way to go? I did the rear brakes last weekend with Power Stop drums and shoes. I also have swapped out my rubber lines for Goodridge SS lines. Thanks for any advice or insight.
  2. Oct 26, 2022 at 8:09 PM
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    I'd get reman calipers from what every auto store you like and trust - I take the old caliper off first to save time since you have to give the old caliper back to the auto store for a core charge - that way you make one trip. The last ones I got were coated ones from NAPA - figured it would slow up rust - I live in New Jersey - lots of salt in the winter.
  3. Oct 26, 2022 at 8:16 PM
    Harp1
    Harp1 Well-Known Member
    Masshole for now
    2022 Toyota Tacoma DCSB
    purely stock
    I'm just about to do entire front brakes on my son's 2007 AC 4x4 180K and was going to ask the same questions about products. I was leaning towards the PowerStop kit (pads/rotors) Not sure if we'll do calipers but I'll look at them this weekend and decide how they look. Any other suggestions would be great. Thanks
  4. Oct 26, 2022 at 8:22 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    I have a year on my reman Power Stop 4Runner calipers. They've been fine. Suggest you do the 4Runner big brake upgrade since you have a TRD Sport with 17" wheels. Only extra expenses are two 4Runner dust shields:
    Pro tip: if getting reman calipers, check all the bolts holding the two caliper halves together are tight.
    wi_taco and ColoradoTJ like this.
  5. Oct 27, 2022 at 5:41 AM
    Soulsurvives
    Bill
    2009 Tacoma
    I've thought about doing the 4runner upgrade. Thanks for the info.
  6. Oct 27, 2022 at 9:22 AM
    tak1313
    tak1313 Well-Known Member
    2013 Base 2WD
    Rock has NEW Ultra-Power calipers for about $100 each with "enhanced corrosion protection." They also have the usual reman suspects. I haven't personally tried Ultra Power calipers, but have used Centric remans with no problem - but everything we have is just daily driver stuff.
    I've been using Centric brake stuff for years because I have met multiple shop owners in my job as an auditor (sorry) (I always "talk shop" while auditing), and many of them swear by Centric, saying they've had the least returns when using that brand. Be aware though that Centric has two lines - their regular "Centric" line and cheaper "C-Tek." I am referring to the regular Centric stuff.
    Doc Samson likes this.
  7. Oct 27, 2022 at 9:23 AM
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    2021 Tacoma TRD Off-Road 4x4
    Power Stop Z36 >>>>>>
  8. Jan 8, 2023 at 11:53 AM
    6Thick
    6Thick Well-Known Member
    Poconos
    2015 TRD Sport MGM 6MT
    TRD Pro Rims, BFKO2 265/70/17, ARE Shell, Leveling kit
    Sparksparts
    OEM calipers $200 a piece
  9. Jan 8, 2023 at 11:57 AM
    Rupp1
    Rupp1 "If you can dodge a wrench, you can dodge a ball."
    NC
    2024 Nissan Titan Pro4X
    I was using the stock rotors with Powerstop pads. (Can’t recall which ones) They worked great. Changed to Akebono pads when I gave the truck to my MIL. A little gentler, but they bot worked good.
