time for new rear shocks
Discussion in '1st Gen. Tacomas (1995-2004)' started by DinnedLucey, May 2, 2014.
  1. May 2, 2014 at 2:10 PM
    DinnedLucey
    DinnedLucey [OP] New Member
    Fairbanks
    2001 Tacoma v6 4wd
    Deck plate mod
    So Im having trouble finding any threads relating to my specific situation.
    My girlfriend for christmas got a a two inch leveling kit( not quite sure which one)
    My leaf springs are bending downwawards instead up up like a u. not sure if that is normal for shocks thats are completely shot.
    which shocks should i get??
  2. May 3, 2014 at 8:24 AM
    Lumpskie
    Lumpskie Independent Thinker
    New Hampshire
    '96, 4x4, v6, manual hub
    Toytec 16" coilovers with Tundra Bilstein 5100s, Light Racing UCAs, Alcan Leafs with Orbit Eyes, 12" Bilstein 7100 short Bodies, ARB rear locker, 33x12.5 Duratracs, CBI sliders, Bushwacker fender flares, self made front bumper, M8000, Vision X 6.7" Hi/Lo Beam HIDs, full skids, Inchworm dual case setup - 15º clocking
    If your springs are "frowning" instead of "smiling", your springs are shot. I'd look into a new spring pack instead of shocks. Better yet, get both with a little lift!
  3. May 3, 2014 at 4:41 PM
    skeezix
    skeezix Well-Known Member
    Colorado
    1998 Limited
    That's BS. I bought my 1998 TRD brand spanking new with only 6 miles on it, and its rear leaf springs had a slight "frown" to them. So did all the other new TRDs on the lot. If the ride height has not changed from when the truck was new I see no reason to replace the leafs, and much less reason to get a lift.
  4. May 3, 2014 at 5:38 PM
    DinnedLucey
    Fairbanks
    2001 Tacoma v6 4wd
    Deck plate mod
    im not so much worried about the smiling or frowning, more like what shocks should I get to replace my shocks that are shot ( not the leaf springs) sorry for the miscommunication.
  5. May 3, 2014 at 5:39 PM
    DinnedLucey
    Fairbanks
    2001 Tacoma v6 4wd
    Deck plate mod
    and will it matter if i put a leveling kit on the front?
    or if i were to get new leaf springs AND shocks, (leaf springs with a bit of lift) which set should i get?
  6. May 3, 2014 at 5:46 PM
    smmarine
    smmarine Well-Known Member
    Melbourne FL
    2020 Kawasaki Vulcan S ABS
    Most of the people here love the Bilstein 5100s. And go check out the wheelers 5 pack leaf springs for a little lift. Check out wheelers offroad for a lot of your suspension
  7. May 3, 2014 at 5:58 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    k the shocks may or may not be shot. if your leafs point down in front of the axle your leafs are toast and its time for new ones. Toyota leafs are garbage and most 1st gens have leafs that do that because they are so weak. I would like some confirmation on this, but i believe OME shocks are an inch longer extended than the 5100s. Which would prevent them from being over extended. But like I said, your leaf pack also needs to be replaced.
  8. May 3, 2014 at 6:35 PM
    Andy.G
    Andy.G Well-Known Member
    Andy
    Virginia
    96 tacoma sx 4x4 2.7 5 speed
    Started automatic. Swapped to manual
    You need to replace leafs before shocks. Your shocks won't last as long with frowning leafs. I bought my truck new with almost frowning leafs. 2 yrs later toyota replaced because 1 set was broken!They also replaced shocks!! Shocks were bad in 2 yrs. Now that's no B.S.
  9. May 3, 2014 at 8:03 PM
    dispatch55126
    dispatch55126 Well-Known Member
    MN
    2004 Xtracab SR5
    Complete OME kit w/ 881's and dakars. All-Pro Sliders, CB, HAM Radio and various other minor stuff.
    My leaves are OEM and brand new and look like this:confused:. They're flat to slightly frowning. If your leaves look like this:( then that is a problem. How much room do you have between the main leaf and overload leaf?
    Also, how do you know the shocks are shot? The OEM leaves are weak and will "give" just by pressing down on the box. If your shocks are shot, you could literally bounce a tire off of the ground just by bouncing on the tailgate.
  10. May 4, 2014 at 7:11 AM
    Andy.G
    Andy
    Virginia
    I myself ca feel when the shocks are done. I load tools often for work. When you push down on back of truck it should not bounce more than once. Easy to see with 4 or 500 lbs in bed. If it bounces and doesn't recover instantly, the shocks are dun! It shouldn't fall into sharp turns.
  11. May 4, 2014 at 9:30 AM
    smmarine
    Melbourne FL
    This! That's how I tell too, and mine like to bounce 3-4 times haha
  12. May 4, 2014 at 6:36 PM
    Andy.G
    Andy
    Virginia
    Show off! haha
  13. May 4, 2014 at 6:38 PM
    smmarine
    Melbourne FL
    My truck is like driving a boat in 5ft chop
  14. May 4, 2014 at 9:25 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    Know how awesome it is having new shocks that are the correct length?
    Fucking awesome. Its a good feeling :D
  15. May 4, 2014 at 11:01 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Nope, not B.S... Even if bought new, you're springs were toast before it got off the assembly line...
    Shocks dampen spring activity, if you push down on your bed & everything is in decent working order & then let up you should only have 1-1.5 actions of rebound meaning it should come back up & stop, if you push down & it just bounces until it stops your shocks are done
    I cannot confirm this.....:p
