Time for timing belt! Have some questions
Discussion in '1st Gen. Tacomas (1995-2004)' started by fouillard13, Jan 11, 2014.
  1. Jan 11, 2014 at 1:15 PM
    fouillard13
    fouillard13 [OP] Well-Known Member
    Riley
    Canadia
    1998 tacoma 4x4
    We'll I am going to do my timing belt on my 3.4 it has 229k miles on the original belt. Thought I may as well do it and the water pump. I will be doing it my self. Now the questions I have are.....
    1. Since I haven't done my belt before what should I all replace while I'm in there.
    2. Can someone link me a complete kit that would work well for me.
    3. My belt being so old and miles up is there a chance I could be slightly out of time. I'm battling a cyl 1 miss fire (pending) and have tried everything. Wondering if timing has something to do with it.
    Thanks
    Any info and advice would be great
  2. Jan 11, 2014 at 1:55 PM
    lipster
    lipster Well-Known Member
    Northern MN
    2004 ext cab 3.4 auto TRD
    License plate frame
    What year?
    #3 is unlikely the case.
    Just me, but if I have all that apart, I would do timing belt, OEM thermostat, Waterpump, the 3 ribbed belts, radiator hoses. Probably the idler pulley as well. It has gone round millions of times, and it is right there in front of you.
  3. Jan 11, 2014 at 3:12 PM
    fouillard13
    Riley
    Canadia
    1998 tacoma 4x4
    My truck has a cylinder 1 missfire but it's pending but if I'm hard on my truck in 4wd the check engine light comes on and say. Cyl 1 missfire confirmed
  4. Jan 11, 2014 at 3:33 PM
    lipster
    Northern MN
    License plate frame
    I understand, but can't see how an old timing belt can cause a misfire in any single cylinder. I'm sure others will weigh in.
  5. Jan 11, 2014 at 4:16 PM
    fouillard13
    Riley
    Canadia
    1998 tacoma 4x4
    I agree. I'm so baffled on the missfire though I don't know where else to look
  6. Jan 11, 2014 at 5:00 PM
    lipster
    Northern MN
    License plate frame
    Have you pulled the plug to look for a crack?
    Have you changed the plug coil to another cylinder to see if the misfire moves?
  7. Jan 11, 2014 at 5:09 PM
    toyotaman29
    toyotaman29 Well-Known Member
    Darrell
    North Carolina
    2021 SR Prerunner Silver
    LED upgrades, Husky weatherbeaters, Black 16’’ wheels
  8. Jan 11, 2014 at 5:43 PM
    fouillard13
    Riley
    Canadia
    1998 tacoma 4x4
    Yup did everything from plugs to coils wires compression test
  9. Jan 12, 2014 at 6:57 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
  10. Jan 12, 2014 at 9:15 AM
    tacomataco2
    tacomataco2 A dude
    Mass
    15’ ACLB
    Some of this Some of that
    Rockauto has the asin kit which I believe is what came equipped originally with the engine, for a lot less than the dealer. I'd go for that one
  11. Apr 14, 2014 at 3:57 PM
    KillaBoDilla
    KillaBoDilla Member
    04 PreRunner DBLcab
    Can anyone tell me what the difference is between the two AISIN timing kits on rockauto's site?
