Time it takes to engage 4X4
Discussion in '3rd Gen. Tacomas (2016-2023)' started by PEIHank, Feb 25, 2021.
  1. Feb 25, 2021 at 3:55 PM
    PEIHank
    PEIHank [OP] Active Member
    2018 TRD Sport
    I have 2018 DCLB Sport that I have owned since July, so first winter. I am surprised at how long it takes for the four wheel drive system to engage. Today I was at a red light and it took 10 seconds or more for the light on the dash to stop flashing and go solid after turning the knob...is this normal? I tried putting it into neutral but that didn't help. The light turned green and there was a loudish clunk while the light went solid.
    My previous vehicle was a 2009 JKU, so one yank of the lever and I was good to go!
    I have owned vehicles before with the electronically engaged 4WD systems (1998 and 2005 Expeditions) and I don't recall them taking this long.
    Sometimes I want the extra traction but don't have the time to wait for the system to engage.
    What re you folks experiencing?
  2. Feb 25, 2021 at 3:59 PM
    Westsideott
    Westsideott Well-Known Member
    Ottawa, ON
    2020 DCSB OR
    You usually need to move to get the gears engaged. Unless they are perfectly aligned while you're sitting at a stop.
  3. Feb 25, 2021 at 3:59 PM
    mtip
    mtip Go Outside & Play!!!
    South Louisiana
    18 TRD Sport 6MT 00 Tundra 5MT
    Possibly moving slowly will help with engaging quicker in 4H.
    I'm pretty sure you should either be stopped or below 2mph for 4L
  4. Feb 25, 2021 at 4:03 PM
    Westsideott
    Ottawa, ON
    2020 DCSB OR
    stopped and neutral for 4lo!!
    Anton338, MadKatt, BRFab and 8 others like this.
  5. Feb 25, 2021 at 4:03 PM
    Tacoma091919
    Tacoma091919 Well-Known Member
    Tim
    2019 OR DCLB
    The first couple times I used mine it took a few seconds. After that it has been pretty quick. I would recommend you exercise it occasionally, probably not necessary to do 10 miles/mo but it is good to engage it occasionally. My 06 4Runner would have a longer delay when I’d go 4-6 months without engaging 4wd. If I did it a little more frequently it seemed to be faster. Not really sure why, but in general exercising the actuator and letting some oil splash around is a good thing mechanically.
    Dryfly24 likes this.
  6. Feb 25, 2021 at 4:04 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
  7. Feb 25, 2021 at 4:05 PM
    Itchyfeet
    Itchyfeet Well-Known Member
    It sounds like you need a Ridgeline. I'm pretty sure my own mom knows that 4WD doesn't just happen esp sitting at a light
  8. Feb 25, 2021 at 4:07 PM
    Sclarpepplar
    Sclarpepplar Your raptor lights look like braces.
    Corey
    2016 TRD sport
    BFG KO2's Fuel rims SPC uca's Arb OME lift Arb on board air Prinsu designs roof rack
    Yikes. Please stop and use neutral for 4lo. If you don't know, please don't tell people improper stuff. It's on your sunvisor man...
    Anton338, Kev250R, The hammer and 3 others like this.
  9. Feb 25, 2021 at 4:20 PM
    PEIHank
    2018 TRD Sport
    It does in a Jeep. Essentially turning that knob should do what pulling the lever in my Jeep did. My Expeditions didn't have this lag...didn't think a newer Tacoma should.
  10. Feb 25, 2021 at 4:21 PM
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    Well, TBH his Sun visor would read differently than yours because he has a clutch.
    Point taken, though...
    Edit: He would be reading that sticker as it applies to him, as he has a clutch. The sticker denotes both manual trans and auto 4x4 operation.
    Sclarpepplar[QUOTED] and mtip like this.
  11. Feb 25, 2021 at 4:24 PM
    flatus
    flatus Well-Known Member
    biloxi,ms
    2020 TRD OR DCSB 4wd Auto
    Waiting for bank account to grow
    It appears he drives a manual which can be at 2mph or less to engage 4lo
    mtip and 0xDEADBEEF like this.
  12. Feb 25, 2021 at 4:24 PM
    Dryfly24
    Dryfly24 He’s a leprechaun. He tells me to burn things.
    George
    NM
    2020 Jeep Gladaitor - Formerly 2019 Tacoma OR SB
    What does a Jeep or an Expedition have to do with a Tacoma?
    Anton338, tonered and MadKatt like this.
  13. Feb 25, 2021 at 4:27 PM
    PEIHank
    2018 TRD Sport
    They all utilize a mechanism which engages a 4WD system. I feel that a newer vehicle should have a system that works better than one that's 20 years older.
  14. Feb 25, 2021 at 4:29 PM
    Dryfly24
    George
    NM
    Sounds like you’re not happy with the truck. Did it do that when you took it for a test drive?
    Anton338, tonered, MadKatt and 2 others like this.
  15. Feb 25, 2021 at 4:32 PM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    Mechanics aside, I can't think of a logical reason why one would need instant 4H.
    tonered, MadKatt, Kev250R and 4 others like this.
  16. Feb 25, 2021 at 4:33 PM
    PEIHank
    2018 TRD Sport
    Not unhappy overall, just curous if what I'm experiencing with the 4WD system is normal...nothing more.
    My test drive was in July so my test of the 4WD system was done quickly and momentarily while driving straight. It took a few seconds but nothing like today, which lends credence to the theory of movement assists with engagement.
  17. Feb 25, 2021 at 4:34 PM
    flatus
    biloxi,ms
    Gotta have at least a little movement for it to engage.
    Chew and Dryfly24 like this.
  18. Feb 25, 2021 at 4:36 PM
    TRD-Troll
    TRD-Troll Smoked Orc 75% off
    NV
    2019 TRDOR DCSB AT
    Dear Diary,
    Today I was trying to cook popcorn in the microwave and when I put the bag inside and closed the door it was not instantly cooked. Is my microwave a POS?
    Anton338, Mace27, MadKatt and 2 others like this.
  19. Feb 25, 2021 at 4:36 PM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    The difference is a manual transfer case vs a computer controlled one. You can jam gears and break shit much easier with a manual one. The computer one is not as apt to allow you to break things. It's best to do it while moving and off the gas. It'll take about 3-5 seconds or so.
    Kev250R, Chew and Dryfly24 like this.
  20. Feb 25, 2021 at 4:36 PM
    Dryfly24
    George
    NM
    If you think about how the process works, it sort of comes intuitively that sometimes you just happen to stop when the gears aren’t lined up rise to valley, male to female however you want to put it. Moving forwards a bit positions them. It’s not rocket science and I’m pretty sure there’s nothing wrong with your truck. Now if it just won’t engage no matter what then yes, you have a problem. But if your complaint is simply that it doesn’t engage instantly - well...
    Anton338 likes this.
