Time sensitive!!! Can a mechanic give me a call? 2007 Taco
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Mattynokes, Nov 18, 2019.
  1. Nov 18, 2019 at 11:14 AM
    Mattynokes
    Mattynokes [OP] Well-Known Member
    Madison, WI
    18' BLACK Off Road DCSB
    Prinsu Toprac TRD Beadlocks Century Shell
    Hey all! I am looking into a 2007 Tacoma Sport and it’s at a really good price. The problem is the condition of it currently. I was hoping someone out there wouldn’t mind giving me a call so I can run a couple things by them. Anyone?!
  2. Nov 18, 2019 at 11:15 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    got a link / pictures/ etc and maybe type out your concerns
    SR-71A likes this.
  3. Nov 18, 2019 at 11:17 AM
    Mattynokes
    Madison, WI
    Don’t have pics. Major issue that I know of so far is that when hooked up to a battery (my other Tacoma, via jumper cables) I get lights but nothing when I turn the key, nothing. 133,000 miles on it.
  4. Nov 18, 2019 at 11:19 AM
    TheDevilYouLove
    TheDevilYouLove You can’t polish a turd, but you can polish a TRD
    Marylandistan
    2010 Tacoma TRD Sport Access cab 4x4 silver streak
    Maybe bad starter or solenoid?
    I don’t think many mechanics do free diagnostic work.
    12TRDTacoma and Gunshot-6A like this.
  5. Nov 18, 2019 at 11:19 AM
    Mattynokes
    Madison, WI
    If I could get it there I would. Just trying to see if it is worth the $3000
  6. Nov 18, 2019 at 11:21 AM
    Mattynokes
    Madison, WI
    That’s kind of what I was thinking but I don’t want to dive into it if the transmission is shot or anything like that.
  7. Nov 18, 2019 at 11:35 AM
    Muddinfun
    Muddinfun Well-Known Member
    A '07 TRD sport is worth more than $3,000 for parts, especially if it's 4WD.
  8. Nov 18, 2019 at 11:37 AM
    Muddinfun
    Disclaimer: If the frame has rust holes and it's beyond 12 years from date of 1st use, it IS a parts truck.
  9. Nov 18, 2019 at 11:43 AM
    Mattynokes
    Madison, WI
    So checking the frame, it has rust but I don’t think to the extent that it is beyond surface.
  10. Nov 18, 2019 at 11:45 AM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    Check by the catalytic converters. That’s the most common spot for rust holes. If it is run.
    Gunshot-6A and Muddinfun like this.
  11. Nov 18, 2019 at 11:52 AM
    Muddinfun
    If this light is still blinking after you turn the key on, you don't have the right key for the truck, or there's something wrong with the imobilizer system.
    Anderson, Gunshot-6A and Shellshock like this.
  12. Nov 18, 2019 at 12:04 PM
    Mattynokes
    Madison, WI
    You guys are Lifesavers. I checked the passenger side frame right next to the catalytic converter and it was split I was able to bend it with the screwdriver. The other side was actually fine.
    aggr0crag likes this.
  13. Nov 18, 2019 at 12:04 PM
    Empty_Lord
    Dan
    Yea once that rot starts there’s only one way to fix it
    Gunshot-6A and whatstcp like this.
  14. Nov 18, 2019 at 12:05 PM
    96carboard
    96carboard Well-Known Member
    If it comes down to it, you could probably get $3000 for all the plastic parts in the cab.
    For $3000, I'd buy it, even if it was broken in half.
    Gunshot-6A likes this.
  15. Nov 18, 2019 at 12:12 PM
    Muddinfun
    So, there's an 93% chance that it was originally sold before 11/18/2007 and it's too late for a free frame. That's probably why it's so cheap. If you buy it and part it out, you can probably make some money on it, but it's a lot of work and a lot of hassle dealing with random Craigslist flakes.
  16. Nov 18, 2019 at 12:13 PM
    Empty_Lord
    Dan
    Money can be made for sure. Unless your willing to swap a frame or part out it’s likely not worth or time
    For that much money I’d buy it. Throw a frame under it. Sell it for profit.
  17. Nov 18, 2019 at 12:20 PM
    Mattynokes
    Madison, WI
  18. Nov 18, 2019 at 12:22 PM
    Muddinfun
  19. Nov 18, 2019 at 12:22 PM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    Wow, look at that rust
  20. Nov 18, 2019 at 12:52 PM
    nd4spdbh
    SoCal
    wouldnt touch with a 10ft pole.... unless i was an auto dismantle... and even then... id be leery.
    Trucknorris likes this.
