Time to Engage?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ToyComa92, Nov 2, 2011.
  1. Nov 2, 2011 at 12:58 PM
    ToyComa92
    ToyComa92 [OP] Write your love, Then your anger.
    Jon
    Conifer, Colorado
    2006 Tacoma TRD sport Debadged
    Heated katzskin leather, Black TRD sport wheels, Bilstein 5100s, Toytec 2" Springs, Deaver 2" AAL, Pioneer AVH4400BH, Ultragauge, Weathertechs front/rear,
    Hey guys, Last night we had a pretty Freak blizzard in Denver and i had to drive clear home to Conifer which is about 20 miles up 285 from C-470, (for anyone who lives in Colorado) Anyways! I dont have sandbags or anything in my bed and i didnt have trouble until i started having to climb hills, As soon as i got on it my back wheels would spin and my rear would be in the left lane hahaha and id be barely trudging up the hill. I wasnt sure if it okay to engage 4WD and keep it at a constant 35-45MPH so i just keep letting off and slowly getting back on it.
    For you guys going through the same horrible winter, What is in your bed? two Tubed sandbags?
  2. Nov 2, 2011 at 1:00 PM
    Fink
    Fink Motorboatin' SOB
    Orlando, FL
    2013 Regular Cab 4x4
    WeatherTechs, 265/75-16 DuraTracs, ATX Mojave Teflon Wheels, ARE V-Series Shell
    As long as you don't engage 4WD when your wheels are spinning at different speeds, you will be fine. You can drive in 4WD up to highway speeds if you need to.
    I would recommend putting 200lbs of sand in the bed (some will argue where, but anywhere will help in this case) and using 4WD.
    Fink
  3. Nov 2, 2011 at 1:02 PM
    G scott04
    G scott04 ...
    Garrett
    Mesa
    04 PreRunner
    Keep it under 50 and you can engage 4hi, but Stop for 4lo and put it in nuetral :thumbsup:
  4. Nov 2, 2011 at 1:03 PM
    Fink
    Orlando, FL
    I love how two PreRunner owners were the first to reply. :D
    Fink
  5. Nov 2, 2011 at 1:04 PM
    G scott04
    G scott04 ...
    Garrett
    Mesa
    04 PreRunner
    I am 4wd :D
  6. Nov 2, 2011 at 1:04 PM
    G scott04
    G scott04 ...
    Garrett
    Mesa
    04 PreRunner
  7. Nov 2, 2011 at 1:05 PM
    ToyComa92
    Jon
    Conifer, Colorado
    Ha, my last truck was an Land Rover which was ALL TIME 4wd so im not used to having to stop and engage it. Im glad to know i can engage it below 50 :) i didnt want to have to stop in the middle of a highway like an asshat to engage my 4wd haha.
  8. Nov 2, 2011 at 1:06 PM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    hes a boss. 4wd prerunner 4tw
  9. Nov 2, 2011 at 1:12 PM
    Fink
    Orlando, FL
    Show's how much I pay attention!
    You are supposed to engage it below 50. I wouldn't engage it if you are going faster than 35mph though. That's just my personal opinion.
    Fink
  10. Nov 2, 2011 at 1:15 PM
    coloradotacoma
    coloradotacoma Well-Known Member
    I drove home at about 11 last night to Elizabeth from the Tech Center and the roads weren't plowed so I imagine it was a pretty similar situation. 6"-8" of slippey wet snow and no visibility. I had it in 4H when needed, basicly all of the last 10 miles. I do have 100 lbs of kitty litter in my bed as well as a box with all my recovery gear and engine fluids. If thats going to wear it out then its just going to get worn out. Thats what 4WD is for so you don't slip in shitty conditions on or off road. BTW what kind of tires are you running? That will have a big affect also.
  11. Nov 2, 2011 at 1:17 PM
    ToyComa92
    Jon
    Conifer, Colorado
    Im running BFgoodrich All terrain TA KOs so i know my tires probably helped alot cause it was a mess last night! People were pulling over left and right.
  12. Nov 2, 2011 at 1:24 PM
    coloradotacoma
    I run the same tires and they definetly help a bunch. Try a couple hundred pounds in the bed right over the rear axel that should help. I saw some really bad accidents last night. Does everone in Colorado have no idea how to drive in snow? I have been here 12 years and still can't believe the accidents I see.
  13. Nov 2, 2011 at 1:24 PM
    G scott04
    G scott04 ...
    Garrett
    Mesa
    04 PreRunner
    Good Advice I wouldn't either with the add hubs.. I engaged my transfer case at 45 with no front driveshaft and it went smoothly, made me more comfortable with it.
  14. Nov 2, 2011 at 1:28 PM
    jgwheeler17
    jgwheeler17 I'm a zit. Get it?
    NC
    07 Double Cab TRD Off-Road 4x4
    tint, dents, scratches, two blown speakers and trying to pay her off...
    im so old school i throw the bitch in neutral, flip it over to 4lo or hi and then get back in gear and go. . . same thing with locker :cool:
    edit: all that is while moving zero miles per hour too btw.
  15. Nov 2, 2011 at 1:28 PM
    ToyComa92
    Jon
    Conifer, Colorado
    People in Colorado expect there 2011-2012 Tahoes or Big fuckin diesels to just pull them through anything. Then when all four tires hit ice and they slide off the road... They instantly blame the asshole going 20 under for conditions. Then there is always the people in there 2wd accords that fully regret making a CAR purchase in colorado as there daily.
  16. Nov 2, 2011 at 1:29 PM
    Fink
    Orlando, FL
    Same here. I will only engage it on the fly if I need to.
    Fink
  17. Nov 2, 2011 at 1:30 PM
    ToyComa92
    Jon
    Conifer, Colorado
    Wait, Why is that Old School? I put it in neutral everytime when i go to 4hi or 4lo... Does toyota really say you can just throw it in 4hi while in drive? That goes against everything i was tought... And im only 20?!...
  18. Nov 2, 2011 at 1:32 PM
    all.on.black
    all.on.black Well-Known Member
    Auburn, WA
    06 Double Cab Sport with a few mods
    You can engage and disengage up to 62mph (it's in your owners manual). You can drive as fast as you want with 4x4 engaged but you can't engage/disengage unless you are under 62mph.
  19. Nov 2, 2011 at 1:32 PM
    coloradotacoma
    Good point and as I often say, 4WD drive is great for traction but it doesn't do shit for braking in slippery conditions unless you are throwing it in reverse. Most people have no idea that their automatic has multiple gears and how to use them.
  20. Nov 2, 2011 at 1:34 PM
    Fink
    Orlando, FL
    I'm old school, so I would only engage it on the fly when I absolutely had to.
    Generally, I would know far in advance that it was needed and would plan it around a stop on the way, a red light, etc...
    Fink
