Time to get creative!
Discussion in 'Garage / Workshop' started by JimBeam, Dec 12, 2012.
  1. Dec 13, 2012 at 9:21 AM
    Boerseun
    Boerseun Well-Known Member
    Ferdie
    Sarasota, Florida
    2018 Tundra TRD Sport 4x4
    Upgraded 2002 Tacoma to 2018 Tundra
    ^^^^Perfect!
    Also, I would not use kitty litter because it would make it difficult to clean out. Just use the blue liquid that is used in port-a-potties, or they are available at camping stores also. That way you can just flush the contents down the toilet in your apartment when it's time to empty it.
  2. Dec 13, 2012 at 9:23 AM
    jgwheeler17
    jgwheeler17 I'm a zit. Get it?
    NC
    07 Double Cab TRD Off-Road 4x4
    neglect, mostly.
    the 5 gallon bucket with the kitty litter is my favorite idea so far.
    what about some type of deal with a hole going out the wall and a little receptacle you pee in to which the contents would drain outdoors? would be fairly easy. drill a hole , do some pvc magic, and there you have it. . maybe put up a curtain around it?
    as for the ladies... :notsure:
  3. Dec 13, 2012 at 9:25 AM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    bingo!
    i think this is a winner.
  4. Dec 13, 2012 at 9:25 AM
    Evil Monkey
    Evil Monkey There's an evil monkey in my truck
    Robert
    Escondido, CA
    07 4x4 DC SR5 TRD Off-road
    Weathertech front & rear mats, rear suspension TSB, Toytec AAL for TSB, Hi-Lift Jack, Bilstein 5100 & Toytec Adjustable coilovers, Built Right UCAs, KMC XD 795 Hoss Wheels, Definity Dakota MTs 285/75R16, Leer XR, Thule Tracker II & Thule MOAB basket
    That's why you put a bag in it. Plus you don't have to deal with sloshing body liquids.
  5. Dec 13, 2012 at 9:27 AM
    gooch14
    gooch14 Well-Known Member
    Kyle
    Michigan
    2011 Blk DC Taco SR5 4x LB
    Bestop, Child Seats, petrified french fry, dog hair, empty Mtn Dew cans cracked windshield, scratches.
    I thought about this for my deer blind.
    I was planning on sinking a 55gal plastic barrell with a bunch of holes drilled in it...mini perk tank really.
    Then filling it part way with pea gravel and running some PVC up into my blind, where I'd put an Y so that the pipe continues vertical and Y's. Pee in the Y, you could cap it to eliminate smells and at the vert portion have a small collection of water to 'flush' with' with a valve.
    copy?
    if need be i can draw it out and post it to TW live
  6. Dec 13, 2012 at 9:27 AM
    jgwheeler17
    NC
    neglect, mostly.
    hadn't even read this one. yeah, basically that ^^ was what i was basically saying.
  7. Dec 13, 2012 at 9:30 AM
    jjew18
    jjew18 the Nightman cometh!
    Alliance Airport
    05 PreRunner SR5
    Added extra awesomeness to its original awesomeness.
    Yup, get a toilet that you would use on a boat.
  8. Dec 13, 2012 at 9:36 AM
    gooch14
    Kyle
    Michigan
  9. Dec 13, 2012 at 9:37 AM
    gooch14
    Kyle
    Michigan
    the drum looks like a weiner with some STD problems....
  10. Dec 13, 2012 at 9:44 AM
    tinker_troy
    tinker_troy Well-Known Member
    T R O Y
    WY/SD
    #3, 2015 SR AC 4x4 V6 6 speed
    shackle brace, rear sway bar, 3 gen seats, Coupe Shifter, 3rd gen OR front springs + shocks, 17" 4runner 6 spoke wheels
    BAHAHAHAHAaa
  11. Dec 13, 2012 at 10:19 AM
    Namyo
    Namyo -
  12. Dec 13, 2012 at 10:29 AM
    Namyo
    Namyo -
  13. Dec 13, 2012 at 10:55 AM
    Hurtin Albertan
    Hurtin Albertan Free Man
    Duck
    on the road less traveled
    The mud hides the tree scrapes in the paint
    Huskyliner floor mats
    Lol
  14. Dec 13, 2012 at 11:36 AM
    tvbd56
    tvbd56 Epic Member
    Tyler
    Sacramento, Ca
    2018 Black DCLB OR 4x4
    I knew that was going to show up sooner or later
  15. Dec 13, 2012 at 12:07 PM
    #35
    gooch14
    Kyle
    Michigan
    photoshop
    his pinky isn't out
  16. Dec 13, 2012 at 12:12 PM
    #36
    Mapcinq
    Mapcinq Well-Known Member
    Ontario, Canada
    Chamber pot toilet. I have one of these bad boys in my cabin in case Im too drunk to find my way outside to use the outhouse/piss off the deck. It will class the place up as well.
    #36
