Time to replace battery??
Discussion in '3rd Gen. Tacomas (2016-2023)' started by WoodsGhost, Aug 28, 2022.
  1. Aug 28, 2022 at 8:03 PM
    WoodsGhost
    WoodsGhost [OP] Well-Known Member
    PA
    2017 DCSB OR:2016 4Runner
    I have a 2017 with the original battery. Starts great every time but should I be looking to replace it soon? I keep a charged jump pack with me at all times but the truck battery is 5 years old at this point.
    Oh and any suggestions on battery brand would be helpful.
    MGMDesertTaco and davidstacoma like this.
  2. Aug 28, 2022 at 8:08 PM
    musicisevil
    musicisevil Lesser-Known Jack Wagon
    Alaska
    2019 TRD Sport
  3. Aug 28, 2022 at 8:09 PM
    Technique
    Technique Well-Known Member
    Alex
    Utah
    2017 Silver Offroad DCSB
    -285/70/17 Toyo AT3 -Tuned
    My 17' battery crapped out at the end of 2018 lol. Been rocking a Everstart Maxx from walmart since then with no issues.
    WoodsGhost[OP] and davidstacoma like this.
  4. Aug 28, 2022 at 8:45 PM
    Trail Limo
    Trail Limo Well-Known Member
    Eh. They all come out of a few factories. Johnson controls, Exide, and East Penn manufacturing. The average life of a battery is 3-4 years regardless of the actual manufacturer. There really is a lot less difference between the batteries than most people would like to argue.
    The best things to do are the following:
    1. Keep a good booster in your vehicle. Clore (jump and carry) is the top lead acid booster pack and is what you will find in most tow trucks. Both NOCO and Clore make good lithium ion boosters (what I personally use). Do NOT buy a cheap lithium ion booster.
    2. Purchase a variable load carbon pile tester and load test your battery every fall before it gets cold. This will ensure that your battery is in good condition going into the cold which will demand the most performance from your battery. You need to load test the battery at 1/2 the CCA hence the need for variable. Brand won't really matter if purchasing for personal use as long as it's adjustable.
    NOTE. While cold weather is when a bad battery is most likely to be found, it's actually the heat that kills batteries. You only notice when it gets cold due to the extra demand placed on the battery. This is why I recommend testing annually in the fall. The heat has already done it's damage, so as long as it tests good in the fall, it usually is good all winter.
    cwdog, WoodsGhost[OP] and mquibble like this.
  5. Aug 28, 2022 at 8:59 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    Definitely keep jump pack on you!
    shakerhood and Trail Limo like this.
  6. Aug 28, 2022 at 9:53 PM
    2021SR5V64WD
    2021SR5V64WD Well-Known Member
    2021 SR5 V6 4WD ACCESS CAB
    Best time to buy a new anything is when you don't need to.
    So buy a battery TODAY because yours is probably on the edge.
    And if it doesn't die tomorrow it will die on you soon.... probably when you need it the most.
    Chew and RIX TUX like this.
  7. Aug 28, 2022 at 10:43 PM
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    Depends on your situation. I'd echo the jump pack at least.
    That said I got 10 years out of my OEM battery. It worked perfectly every day until one day it didn't in a cold snap. First time it didn't, I bought a new one.
    shakerhood likes this.
  8. Aug 28, 2022 at 11:31 PM
    MGMDesertTaco
    Your time is worth something. Swap it out before your stuck waiting on AAA or a friend/family member to take you to the parts store. I recommend the Everstart 24F AGM from Wally World or Toyota's TrueStart with 84 month warranty.
    https://www.tacomaworld.com/threads/oem-battery-life.776081/page-2#post-27742665
  9. Aug 29, 2022 at 2:02 AM
    Travelinman301
    Travelinman301 4 x 4 Fanatic
    Florida
    2018 Blazing Blue Pearl Tacoma TRD Sport 4 x 4 DCSB
    KDMAX-PRO-10.0 Diode Dynamics Sport Fog Lights Morimoto Clear Tail Lights TRD Skid Plate
    My OEM battery is 4 years old and still performing well. I'm the type that likes to get my money's worth so I'll go with it to the end. One thing I've always done with any vehicle is have a booster on board just in case. One in the truck and one in my wife's car.
    mquibble and bulalo like this.
  10. Aug 29, 2022 at 4:47 AM
    WoodsGhost
    PA
    Thanks for all the replys. Im planning to get a battery this week. Especially with cold weather right around the corner, I dont wanna be caught in a “why didn’t you just get one you cheap ass” situation lol
  11. Aug 29, 2022 at 5:00 AM
    Sungod
    Sungod Well-Known Member
    St Augustine
    I don't think replacing it now would be the worst idea. Batteries biggest enemies are extreme heat and extreme cold. You can roll the dice, but I wouldn't want to be stranded on a cold day having to change it in a parking lot because lord knows they never fail in your garage.
    WoodsGhost[OP] and Chew like this.
  12. Aug 29, 2022 at 6:32 AM
    Hooper89
    Hooper89 Well-Known Member
    2016 White TRD Sport
    Costco or Wally World
    Get a lithium ion jumper pack too and check it every now and then for charge, nice to have in case you or somebody else needs a jump
  13. Aug 29, 2022 at 6:45 AM
    Chaosh1
    Chaosh1 Well-Known Member
    2021 Tacoma TRD Pro
    Another good thing about the NOCO chargers is its ability to Desulfate the Battery. Once a year I tend to pull/disconnect batteries and Desulfate them.
    WoodsGhost[OP] likes this.
  14. Aug 29, 2022 at 6:59 AM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    The quick and dirty guide is to test the battery's resting voltage after fully charging.
    Meaning - after running around town, shut down the truck and let it sit for 30 mins to an hour, then test battery voltage. Nominal is 12.6 or above. Yellow "its gettin' old" zone is 12.5-12.2. Replace me now is 12.2 or below.
  15. Aug 29, 2022 at 7:16 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    My choice has been a deka. They seem to be better than other brands tried.
  16. Aug 29, 2022 at 7:27 AM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
