Time to replace old torque wrench
Discussion in 'Technical Chat' started by Failure2Comply, Dec 23, 2012.
  1. Dec 23, 2012 at 3:41 PM
    Failure2Comply
    Failure2Comply [OP] Old HVACR Tech
    Virginia, USA
    05 Access Off Road TRD/SR5
    So it sounds like the in my price range the Craftsman is the way to go.
  2. Dec 23, 2012 at 3:49 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    And if he needs it, he can always add a 50-250 later on.
    But a 10-75 and 20-150 are going to satisfy his needs on the Taco until he can save a few bucks to broaden the collection.
    I'm not a fan of the wide-range like a 20-250... I just don't trust the calibration over that span in "consumer grade" tools.
  3. Dec 23, 2012 at 3:50 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    X2. If you need more than 150 ft-lb (for things like front driveshaft hub nut), use a larger size torque wrench.
  4. Dec 23, 2012 at 3:51 PM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    like a 3/4? would the up to 250 wrenches be used on heavy equipment like dozers?
  5. Dec 23, 2012 at 3:53 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    And as rare as those needs are, it's more economical to rent one from Autozone or Kragen/O'Reilly/Checker than to buy one.
    Many stores are doing free tool loans now.
  6. Dec 23, 2012 at 3:55 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    3/4" and 1" would be getting into heavy equipment.
    I've never had a need for anything over 1/2" on a car or pickup.
  7. Dec 23, 2012 at 4:02 PM
    KenLyns
    Belly of the Beast
    3/4" drive is not necessary. By larger size, I meant a longer handle to avoid straining yourself.
  8. Dec 23, 2012 at 4:26 PM
    Failure2Comply
    Virginia, USA
    Well it looks a trip to Sears is in my future tomorrow, thanks guys!
  9. Dec 23, 2012 at 4:27 PM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
  10. Dec 23, 2012 at 4:27 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Noes a good time. Both the 1/2" and 3/8" were on sale for 49.99 yesterday when I was there. You could get both for a hundred bucks.
  11. Dec 23, 2012 at 4:31 PM
    Failure2Comply
    Virginia, USA
  12. Dec 23, 2012 at 4:53 PM
    Failure2Comply
    Virginia, USA
    They do offer these two models, any suggestions?
    http://www.sears.com/craftsman-micr...p-00931425000P?prdNo=2&blockNo=2&blockType=G2
    or
    http://www.sears.com/craftsman-micr...0944595000P?prdNo=10&blockNo=10&blockType=G10
  13. Dec 23, 2012 at 4:57 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Either one.
    2nd one is on sale for only a couple of bucks more, I'd get that one.
  14. Dec 23, 2012 at 5:45 PM
    Failure2Comply
    Virginia, USA
    Sounds like a plan, thanks.
  15. Dec 24, 2012 at 10:34 AM
    #35
    wyotaco06
    wyotaco06 Well-Known Member
    Offroad 4x4 06
    Is this the type you use on the 15ft.lbs for spark plugs? Have changed them twice now without a T wrench, figure on the next change I will try one out. So far I have had good luck with finger tight then 1/4-1/2 turn more, done! But I also change out a TON of plugs on chainsaws during the summer, and know never to overtighten them.
  16. Dec 24, 2012 at 11:17 AM
    #36
    Failure2Comply
    Virginia, USA
    Well I made the trip to Sears and they only had the first one that I previously listed, said the second one was being discontinued. And it was on sale for $10.00 off which helps. So I was forced to also get a little bit bigger plastic tool box for the truck so the torque wrench would fit, which was also on sale a little bit. :D
    Thanks for everyone's help, Merry Christmas.
    and this tool box.
    http://www.sears.com/craftsman-26-i...0959326000P?prdNo=13&blockNo=13&blockType=G13
    Down the road I will add this one to the box.
    http://www.sears.com/craftsman-micr...p-00931424000P?prdNo=5&blockNo=5&blockType=G5
  17. Dec 24, 2012 at 11:19 AM
    #37
    Failure2Comply
    Virginia, USA
    I think this one is more in line with the task.
  18. Dec 24, 2012 at 11:50 AM
    #38
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yup! ^^^ thats the one I use for plugs.
  19. Dec 24, 2012 at 3:12 PM
    #39
    Rich91710
    Rich
    Los Angeles
    08 Base
    For spark plugs, I use a 10-75 ft/lb 3/8" clicker.
  20. Dec 26, 2012 at 7:14 AM
    #40
    ihadmail
    ihadmail Well-Known Member
    Chapin, SC
    2008 4Runner SR5 4x4
    Car seat
    I use the gear wrench brand torque wrenches and have never had any issues out of them. I work at a power plant, so after buying the first one I took it in to our cal lab to see how good it was calibrated out of the box. It was within 3% in it's intended usable range, so I bought a couple more to cover all of the ranges that I regularly use.
    EDIT: They are all micrometer type torque wrenches. 1/4" drive 30-200 in/lbf, 3/8" drive 10-100 ft/lbf and a 1/2" drive 25-250 ft/lbf.
