Time to replace rotors
Discussion in 'Technical Chat' started by pop639, Jan 18, 2012.
  1. Jan 18, 2012 at 2:12 PM
    pop639
    pop639 [OP] Well-Known Member
    Western PA
    16 SR5 DCSB 4x4
    Hello all,
    I have 130,000 on the truck and it's time to replace the rotors and pads up front. I've done this on other vehicles in the past with no problem but on our trucks I've noticed a hard line going from the caliper to a flex line. Do i have to remove the hard line from the caliper thus draining the fluid or is there a way to keep it intact. Thanks a lot
  2. Jan 18, 2012 at 2:13 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    welcome
    no you just un bolt the caliper from the hub (2 bolts on the back) and swing it out of the way. I have never seen an easier vehicle to do a brake job on than a tacoma.
  3. Jan 18, 2012 at 2:14 PM
    pop639
    Western PA
    16 SR5 DCSB 4x4
    but won't the hard line bend
  4. Jan 18, 2012 at 2:25 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    no because the rubber line will be able to bend.
  5. Jan 18, 2012 at 2:29 PM
    pop639
    Western PA
    16 SR5 DCSB 4x4
    there's a bracket where the 2 lines meet, I assume you just have to loosen the bracket...why didn't they just make everything out of rubber, it's just gonna flex anyway. You're right though, they're easy to work on
  6. Jan 18, 2012 at 3:47 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    oh you have a 2nd gen. lol oops
    Yeah I would assume you just undo the bracket, you should never have to release fluid doing brake pads.
