Timing adjustment on a 1986 22R
Discussion in '4 Cylinder' started by Chuck Khuen, Mar 13, 2011.
  1. Mar 13, 2011 at 8:33 AM
    Chuck Khuen
    Chuck Khuen [OP] New Member
    Chuck
    Massachusetts
    1986 Pickup
    Camper cap on back
    New Member and I am sorry for the overly simple question but how do I adjust teh timing on my 1986 22R engine?
  2. Mar 13, 2011 at 8:44 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Pull the vacuum lines off the distributer, and using a timing light, set the timing to "0"
  3. Mar 13, 2011 at 9:03 AM
    facemob
    facemob Well-Known Member
    Chase
    1st state
    03 V6 Manual, TRD
    OME 881, Nitrochargers front and rear, diff drop, Wheelers 3 Leaf AAL, Supertop, shitty brush guard and a hole in the muffler
    Yes, you will definitely need a timing light and it would be a good idea to get a haynes manual if you do not already have one. I had to do it a few times on my 89, cant remember the exact steps but the haynes will walk you thru it. basicaly point the timing light at the top of the crank pulley with motor running and rotate the distributor until the notch on the pulley lines up with the correct degree reading. This was on a 22re though. had plastic chain guides if im not mistaken. Good luck
  4. Mar 13, 2011 at 9:13 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Same on teh 22r. The RE is set to +5* useually, and the R is set to 0*
  5. Mar 13, 2011 at 6:47 PM
    Chuck Khuen
    Chuck
    Massachusetts
    1986 Pickup
    Camper cap on back
    Thank you VERY much guys!
