timing belt/ advance timing?
Discussion in 'Performance and Tuning' started by dzlpwrd, Jun 29, 2010.
  1. Jun 29, 2010 at 11:41 AM
    dzlpwrd
    dzlpwrd [OP] toyota fan from birth
    james
    wilton maine
    1995.5 v6 4x4 sr5
    ported air box, 3 inch custom exhaust, with cat delete, tinted windows, 4 6 inch 300 watt speakers, 2 1800 watt amps,2 6x9 900 watt speakers, pioneer recievier with ipod control, 3 inch lift, color match cap, more to come...
    i have a 95.5 tacoma 3.4 i bought the truck from a close friend that bought it new. i know the history of the truck, he had issues with a pulley on the timing belt after he had toyota replace the belt. second time around they replaced pulleys and belt. after that the truck did not go as well it still has decent power but not like it had before. my guess is that they got the timing belt off by one tooth so the timing is just a little retarded. i plan to replace the belt in the next couple weeks my question is has any one ever tried to advance the timing by one tooth just to see if it makes anymore power? i know i have done a few belts and if you get them off by a tooth retarded there is a diffrence in power.
  2. Jun 29, 2010 at 11:48 AM
    98tacoma27
    Ben
    Not Beech Creek
    I honestly don't think it would run being one tooth off.
  3. Jun 29, 2010 at 11:50 AM
    huntinggunns
    huntinggunns Lifes a garden, dig it.
    Fred
    Oklahoma
    2014 MGM SR5 DC SB TSS 4x4
    In progress
    James,
    Probably just let one of the cams slip a tooth when installing the belt. I would not try to advance it. Just line up all the dots on the cams, crank, and intermediate shafts with their respective match marks. Should run perfect then. :D
    Fred.
  4. Jun 29, 2010 at 11:51 AM
    98tacoma27
    Ben
    Not Beech Creek
    X2...........all the pulleys have timing marks
  5. Jun 29, 2010 at 5:03 PM
    dzlpwrd
    james
    wilton maine
    1995.5 v6 4x4 sr5
    i will be tearing into it soon and will post what i have found out. they will run if it is off a tooth when i did my old 89 3.0 i completely assembled it started it backed it out of the garage drove it from my house down the hill to the main road before i noticed the loss in power. the return trip was frustrating just the thought of tearing it all apart again. since then i have learned to be more cautious when reassembling.
  6. Sep 29, 2012 at 7:03 PM
    Tacoma2525
    Tacoma2525 Member
    03 tacoma prerunner
    What pulley did he have problems with and what symptoms did it present?
