timing belt and water pump kit
Discussion in '1st Gen. Tacomas (1995-2004)' started by fish, Apr 26, 2011.
  1. Apr 27, 2011 at 8:58 AM
    JDMcQ
    JDMcQ Well-Known Member
    The Mushroom Capital of the World
    The '04 should be the same.
    I am right down the road from you. When are you planning on doing it? I might be able to come up for a bit to help out.
  2. Apr 27, 2011 at 10:28 AM
    Enigmaaron
    Enigmaaron All your soul are belong to us
    PA
    1st gen superiority
    Probably a few months from now, definitely July at the earliest. Figure I could buy the parts now just in case though.
    That would be awesome if you wanted to come give me a hand. I can provide beers at the least for your time. I'll PM you when I'm actually getting close to doing it.
  3. Apr 27, 2011 at 10:52 AM
    JDMcQ
    Absolutely. I look forward to it. I also made the crank pulley holding tool that you can use for the reassembly. Might as well get another use out of it.
  4. Apr 27, 2011 at 5:02 PM
    beefcake
    beefcake J-rob
    J-Rob
    Central California
    98 4WD V6
    Debadged,Deck Plate mod, Helix throttle body spacer, magnaflow two chamber, smoked corner marker lamps, cb radio, smoked headlights, grillcraft mesh grill, URD short throw shifter, ultagauge, billstein 5100 front struts, spidertrax 1.25 spacers on all four
    :eek:damn! my truck just hit 186k and im pretty sure it has never been changed! i plan on doing it this summer, my truck still runs between 188 and 200, im guessing this is still good temp?
  5. Apr 27, 2011 at 5:13 PM
    Watari06V6
    Watari06V6 Faster than a speeding ticket
    Wounded Knee
    TRD-V6-SR5-06
    mines at 85k and man and i thought somethin smells of coolant a few months back while i was drivin. this is a bad sign!! i think i need to change mine too before sht hits the fan :mad:
  6. Apr 27, 2011 at 5:17 PM
    JDMcQ
    At 96k my water pump looked like brand new. The bearing was still solid and smooth.
  7. Apr 27, 2011 at 6:10 PM
    ChavisT93
    ChavisT93 Well-Known Member
    Lexington, SC
    07 reg cab base
    Wish you were a little closer to the Columbia area, I need to do mine soon.
  8. Apr 28, 2011 at 8:06 AM
    brs127s
    brs127s Well-Known Member
    O'Fallon, MO
    04 D-Cab 4x4 Limited TRD
    TRD Headers, Aero Turbine AT2525XL Deckplate Mod, TRD tranny cooler, King Coilovers, LR UCAs, Alcan 5 Leaf springs and Bilstein 5100s, Shrockworks front bumper, CBI rear bumper.
    Might not be your water pump. About 2 years ago, my truck was losing coolant and you could smell it from time to time. Never dripped anywhere and the water pump was not leaking. After several months on a cool day parked up hill, I noticed something dripping under the back of the engine. I opened up the hood and saw I had coolant leaking down the back side of the engine from the intake. There is an open cavity under the intake. I guess my gasket let loose so that the coolant was filling up the cavity. It finally got full enough to leak out the back of the intake when parked on a hill. Got it fixed under the extended warranty. They thought my fan clutch wasn't locking up enough, causing the Taco to run hotter, and eventually causing the leak. The tore the engine apart to clean all the crap out, replaced the fan clutch, and did my timing belt at the same time. Dealer said they hadn't seen one leak like that, but it was now something they would watch for.
  9. Jun 9, 2014 at 9:51 AM
    coastalyeti
    coastalyeti Still runs perfect
    Dana
    san diego
    Black 2004 Tacoma 4x4 doublecab 480,000 miles
    newbie here... my truck just started running bad, and the water pump\ timing chain is making funny noises. this will be my first engine repair, and my truck has 334,000 miles on it. two of my cousins bought tacomas after they saw how solid mine was.
    so far;
    brakes
    tires,
    batteries
    is all ive had to do to it. BEST damn truck on the road.
    ive never even had a tune`up.
  10. Jun 9, 2014 at 7:49 PM
    TheTimmyJimmy
    TheTimmyJimmy Dumbazz
    Tim
    Colorado
    04 Tacoma DBl Cab
    Lots of lil stuff
    So much false information online..... Aisin is an OE component manufacturer. They do not make belts they purchase cheap retail belts. But there compnents are great. Dayco to is an OE supplier but they dont always sell the same product in the Aftermarket as in OE and saying that they are the OE is only partially accurate. They are typically the 3rd to 4th in terms of global OE business, depending on what product your discussing. 4th is a very small fraction compared to other manufacturers.
    Also, buying a "cheap" timing kit is just dumb. Its a critical part to you motor..... Definently do the full job, tensioner, idler, water pump.
