Timing Belt - Chain and 100,000 maint ??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Speed8082, Mar 27, 2011.
  1. Mar 27, 2011 at 5:15 PM
    Speed8082
    Speed8082 [OP] Member
    Coxs Creek, KY
    05 4X4 Double Cab
    Cap
    I have a 2005 crew cab 4X4 with 107,000 miles. How do I determine if I have a timing belt or chain? Also, the only maitenance I have had to preform is normal oil changes (syn oil and Toyota filter), front brakes, and tires. What do I need to do at this mileage to keep her going for 300,000 miles.
    Thanks in advance.
    Speed8082
  2. Mar 27, 2011 at 5:18 PM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    You have a chain.
  3. Mar 27, 2011 at 5:56 PM
    Speed8082
    Coxs Creek, KY
    05 4X4 Double Cab
    Cap
  4. Mar 28, 2011 at 7:47 AM
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
    For the other maintenance, when I hit 90K I went ahead and flushed the coolant, had a tranny flush done, and then took care of other things as I've had time. So if you haven't done so before now, here's a list of other things that you should change (and you shouldn't wait until 100K miles to do them):
    Brake Fluid
    Power Steering Fluid
    Front/Rear Differential Oil
    Transfer Case Oil
  5. Mar 29, 2011 at 8:02 AM
    Speed8082
    Coxs Creek, KY
    05 4X4 Double Cab
    Cap
    05Moose, Thanks. I took the truck into Toyota for the Tran fluid change, they said it had a "Lifetime" fluid and did not recommend changing it. They said that there was two types out and that mine was the kind that did not recommend changing.
    I will get on the the other fluid changes this weekend. Thanks for the heads up.
  6. Mar 29, 2011 at 8:09 AM
    TurfTaco
    TurfTaco Is there a long john silvers on the island?
    URE
    07 Deer Collector
    285/75-16 BFG KM1's, AVS vent visors, AVS hood shield, pioneer avic F900BT, pac steering wheel control adapter, Boyo rearview camera, pac ipod interface, tinted windows, Toytec 1.5 AAL, Bistein 5100s (front set to .85) Eibach coils, Black headlights, grillcraft black billet insert, N-fab light bar, 4 Hella FF700 lights & color matched grille, Sockmonkey bedside decals. 16x8 MT sidebiters, Weathertechs, Fabtech spare carrier.
  7. Mar 29, 2011 at 8:19 AM
    bertfull
    bertfull Member
    Bert
    VA
    PreRunner 6" Lift/ 33" BFGs/ 16mpg
    3" Procomp susp lift & 3" Body Lift/ SPC UCAs.
    There is no scheduled maintenance for the Timing Chain on 2005 & newer Tacoma V-6s.
