Timing belt help please.
Discussion in '1st Gen. Tacomas (1995-2004)' started by cbull, Jan 5, 2020.
  1. Jan 5, 2020 at 8:44 AM
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
    Did you pull the pin out of the "pin hole" as shown with the arrow to release the tensioner.
    The tensioner is spring loaded and pulls out the slack when released.
    Did you install a new tensioner or are you reusing the old tensioner?
    The belt should be tight like you see in the picture when the tensioner has been released.
  2. Jan 5, 2020 at 8:44 AM
    cbull
    cbull [OP] Active Member
    Curtis
    2002 4x4 extended cab 5 speed v6
    I wondered that myself, seems like something's not quite right but maybe I'm being a little more precise then others and maybe there's a fraction of wiggle room. With everything lined up in the four photos I posted above, the tensioner is tight and the belt all the way around is tight. It all seems good now except the marks don't perfectly lineup. Either I can get the cam marks to line up perfectly or I can get the crank Mark to line up perfectly but not all three treated but again the belt is tight all the way around.
    CS_AR likes this.
  3. Jan 5, 2020 at 8:45 AM
    CS_AR
    Where did you get the belt?
  4. Jan 5, 2020 at 8:45 AM
    Thatbassguy
    Thatbassguy Sweet or sour?
    James
    '19 T4R, TRDORP, KDSS
    RSG sliders, SOS skids, SOS bumper, wheels, tires, etc
    Based on these pictures, it looks like everything is lined up pretty good.
    Agreed. Why is the belt loose? That is definitely a problem.
  5. Jan 5, 2020 at 8:48 AM
    Thatbassguy
    James
    Can you get a picture of the whole front of the motor? It's hard to tell what's going on.
  6. Jan 5, 2020 at 8:51 AM
    cbull
    Curtis
    To answer your question the pin is not yet pulled. But the belt is equally tight. It might be a tad loose on the tensioner side but once I pull the pin that will fix any of that.
    cruiserguy and CS_AR like this.
  7. Jan 5, 2020 at 8:59 AM
    cbull
    Curtis
    The belt was in a complete kit that I bought off of eBay from air cabin man. I have checked the Belt part number with several other internet websites and they all confirm that I have the correct belt.
    Looking at the pictures the belt is still loose because I did not tighten up the tensioner until after.15782435258344102113451900918029.jpg
    cruiserguy likes this.
  8. Jan 5, 2020 at 9:06 AM
    CS_AR
    You are using the same kit that thousands of members use. Pulling the pin will allow the tensioner to pull out any slack in the belt.
    Thatbassguy and cruiserguy like this.
  9. Jan 5, 2020 at 9:09 AM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    CS_AR has it nailed for you cbull. You're good to go. That tiny bit of slack will be gone when you pull the tensioner pin and give it a couple revolutions.
    Nice job man, that's not some easy peasy job to do. Love a good DIY story:D:cool:
    Thatbassguy and CS_AR[QUOTED] like this.
  10. Jan 5, 2020 at 9:14 AM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    general rule of thumb with these belts is the marks on the belt. line them up. the ones on the pulley to the engine can be just close.. when you go to rotate everything once its tight use the engine marks to make sure its in time.
    i do all my belts going off the timing belt. havent had one out of time yet
  11. Jan 5, 2020 at 9:16 AM
    cbull
    Curtis
    Thanks for all your guy's help, it really wasn't that bad of a job thanks to some YouTubers out there. My only real hiccup is Ben these marks don't perfectly line up but other than that everything seems fine. I will put it all back together and see what happens.
  12. Jan 5, 2020 at 9:18 AM
    cruiserguy
    Elijah
    SEKS
    Trust this guy cbull. He does this for a living at Yota stealership service dept. I mean trust us too. :D But I think you've had the belt in place and knew what you were doing, just being cautious. Rightfully so
    cbull[QUOTED][OP] likes this.
  13. Jan 5, 2020 at 9:19 AM
    Empty_Lord
    Dan
    just make sure the crank one hasnt moved before you pull the pin. thats the one that forwhatever reason i almost always manage to knock a tooth over when getting the uppers on
    arrows out, point to the dot on the crank, arrows on the top point to the mark on the cam pulleys. if theyre there (the left looks close enough) your fine
    cruiserguy and Thatbassguy like this.
  14. Jan 5, 2020 at 9:50 AM
    cruiserguy
    Elijah
    SEKS
    I'm sure you get tired of it eventually just cause repeating etc, but you don't know how peace inducing to the DIYERS, like me and the OP and most of us here, but such peace of mind to have an actual real life day to day technician chime in and let us know that it looks good/correct and looks like we're doing it right etc. Seriously man. May not seem like big deal to you but I assure you that when you do, it gives huge confidence to all us hobby or part time Toyota brothers :D
  15. Jan 5, 2020 at 9:53 AM
    #35
    Empty_Lord
    Dan
    i try to offer help where i can. honestly i enjoy doing timing belts. lol
    once you pull the pin, rotate the engine twice (cams are 1 full rotation to every 2 crank rotations) and check that the timing mark on the crank is TDC and the marks on the cams line up with the notch in the backing plate and your good to go
  16. Jan 5, 2020 at 9:56 AM
    #36
    cruiserguy
    Elijah
    SEKS
    You're good man. You definitely do help out. Guess I was just saying thanks, and I know me and the homies here all appreciate you and your info and help and experience
  17. Jan 5, 2020 at 9:57 AM
    #37
    Empty_Lord
    Dan
    Oh. before i forget. Once you rotate the engine by hand, the timing marks on the belt wont line up to anything anymore. ignore them
  18. Jan 5, 2020 at 10:11 AM
    #38
    TWJLee
    TWJLee Well-Known Member
    Jay
    Midwest
    2001 Tacoma 4X4 2.7 5spd access cab 2020 Tundra DC LmTD 2020 F150 5.0
    2020 Tundra GFC 33’s Borla Pro XS FOX 2.0 2020 F150 33’s Magnaflow FOX 2.0 2001 Tacoma 4x4 2.7 5spd access cab new frame 217k 2” lifted Always for sale.
    Couple weird questions maybe relating to this job:
    1:Is it ok to start to the engine for a few moments making sure it runs w/o adding the coolant and all? (Like 20-30seconds, Cleetus Mcfarland does on occasion YT) because it would suck to put it all back in running order the first time doing this and have to take it all apart to adjust-
    2: Easy removal of the crank bolt after testing the clockwise rotation so everything lines up?
    ..use old one probably to test, then assemble new one torquing it at 217lb once it is good?
  19. Jan 5, 2020 at 10:23 AM
    #39
    cruiserguy
    Elijah
    SEKS
    Yeah you're fine without filling all the way. I'd prolly at least fill the block up, you know the internal engine side and stuff. Can fill radiator and stuff after you know you got everything lined up and tested.
    I wouldn't put the crank bolt to 200 lbs to test it. I haven't replaced the crank bolts on the timing belt jobs I've done. :anonymous: I haven't done a 3.4L Yota, but the Honda V6s and Yota 4s and V6s I've done, I reused them. I didn't notice they were torque to yield, fancy name for 'use once only'
    Dirty Pool and TWJLee[QUOTED] like this.
  20. Jan 5, 2020 at 11:39 AM
    #40
    Styx586
    Styx586 Well-Known Member
    Terrance
    Lake Elsinore, Ca
    2013 Tacoma DCLB TRD Sport, 2001 Tacoma TRD Off-Road
    FYI IIRC the torque spec was updated to be more than 217 at some point. My old manual said it was 217 but someone told it Toyota increased it to 260ish. Hopefully someone can chime in with the actual number...
    Edit: my bad, 217 is the updated torque. Used to be 184.
