Timing belt help please.
Discussion in '1st Gen. Tacomas (1995-2004)' started by cbull, Jan 5, 2020.
  1. Jan 5, 2020 at 11:52 AM
    #41
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    The bolt itself was also upgraded, mid 99 IIRC.
    Empty_Lord and cruiserguy like this.
  2. Jan 5, 2020 at 2:26 PM
    #42
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    you can run it if you put the crank pulley on. its fine for a 30 second- 1 minute run to make sure it all works. BUT THE CRANK PULLEY HAS TO BE ON
    cruiserguy and TWJLee[QUOTED] like this.
  3. Jan 5, 2020 at 2:26 PM
    #43
    Empty_Lord
    Dan
    217 is what i do at work. never issues. and we reuse bolts. (unless its the 3rd belt.. i replace them on the 3rd belt)
    cruiserguy, TWJLee and CS_AR like this.
  4. Jan 5, 2020 at 4:39 PM
    #44
    cbull
    cbull [OP] Active Member
    Curtis
    2002 4x4 extended cab 5 speed v6
    Well guys, truck starts and runs good, has no leaks, as of right now, lol. I wasn't happy about things not lining up perfectly like I thought they should, but all seems to be good.
    The other issue I had was getting the crank Bolt tightened to 217 foot pounds. I rented a torque wrench that was about a foot and a half long that made things a little difficult, needed to be more like 2 and 1/2 to 3 ft long . And I also tried doing it without the crank tool and tried to use the engine which didn't work until I realized I needed to do it in 5th gear. Once I got that figured out I got her done.
    Thanks again for your help, since this was my first time it no doubt would have been a disaster if it weren't for you and a couple YouTubers.
