Timing Belt job prep, and a couple questions.
Discussion in '1st Gen. Tacomas (1995-2004)' started by Actionjackson, Jan 29, 2018.
  1. Feb 5, 2018 at 3:01 PM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    That's not the timing belt cover. It's the fan bracket and pulley. The bearing is in the bracket and can not be removed/replaced. If that bearing needs replacement, you have to replace that whole assembly.
  2. Feb 5, 2018 at 3:04 PM
    04Burk
    04Burk Well-Known Member
    Glen
    Hinesville, GA
    04 4x4 V6 Xcab 217k miles
    Got it. I was reading in a post somewhere else in TW the bearing could be replaced. Maybe its a diff pulley than the one I'm thinking of. Again, not a real mechanic here. There are mechanics that work at the shop on post I can get advise from or my father in law.
  3. Feb 5, 2018 at 3:19 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Lots of people load up the parts cannon without figuring out what is really wrong - you can check your pulleys for smooth operation once the belts are off, or you can check it with them on here:
  4. Feb 5, 2018 at 3:31 PM
    04Burk
    Glen
    Hinesville, GA
    Not this squeal, I have the whine in the first quote. Hopefully I did the multi quote right.
  5. Feb 5, 2018 at 3:39 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Yeah that was smooth :)
    What does yours sound like - exactly like that one? You can always just pop the belt off and check the pulley for loose play or grinding as it spins...
  6. Feb 5, 2018 at 5:10 PM
    04Burk
    Glen
    Hinesville, GA
    Sounds exactly like the first video. That's another thing I have to change, belts. Will check the pulley when I'm doing that, and buy the bearing to replace it if its bad.
  7. Feb 5, 2018 at 8:41 PM
    MikeWH
    MikeWH Well-Known Member
    Colfax, CA
    1999 TRD 4x4 (x2)
    The lower tensioner is the one where you can tap out the bearing and put a new one in. There are some write ups on here. Since the bearing there is under $15 its a good one to do while you have everything apart. You will need snap ring pliers and the right sized sockets to tap it in and out.
    04Burk likes this.
  8. Feb 7, 2018 at 11:54 AM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    FWIW... The fan bracket/pulley was just marked down on Amazon today. They just dropped it from $135 to $119.86.
    For Amazon Prime members (free shipping) that is the best price I have ever seen it go for, anywhere.
    04Burk likes this.
