Timing belt kit
Discussion in '1st Gen. Tacomas (1995-2004)' started by d33pt, Dec 30, 2023.
  1. Dec 30, 2023 at 9:52 AM
    d33pt
    d33pt [OP] Well-Known Member
    Where are you guys getting your timing belt stuff? I've heard good stuff from the aircabman kits on ebay. Just slightly worried about counterfeit stuff from ebay or Amazon.
    It seems like a comprehensive kit that he offers. I think I would just add a new crank nut.
    https://www.ebay.com/itm/184268614769
  2. Dec 30, 2023 at 9:54 AM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    Cant get OEM...
  3. Dec 30, 2023 at 10:13 AM
    Red_03Taco
    Red_03Taco Well-Known Member
    Jerad
    2003 Tacoma Xtra Cab 4WD
    I bought an aircabinman kit from eBay and it was all good
  4. Dec 30, 2023 at 11:36 AM
    ManInTheMaze
    ManInTheMaze Well-Known Member
    Mendo
    2003 and 2017
    I bought a kit from aircabinman as well. Happy with the purchase.
  5. Dec 30, 2023 at 11:41 AM
    STOCKTRD
    STOCKTRD Well-Known Member
    In Traffic
    CustomTacos Mafia!
    Nachos, Lemon Heads, My Truck Is Stock!
    Same here, used aircabinman for a timing belt kit. Had no problems at all.
  6. Dec 30, 2023 at 11:53 AM
    leid
    leid Well-Known Member
    Brandon, MS
    1997 V6 Tacoma 4x4 & 2020 V6 Tacoma TRD 4x4
    ECGS & ZUK diffs w lockers/Marlin R150F/NITRO axles/winches
    OP,
    Add another big thumbs-up here for aircabinman. I opted for his kit with an OEM Toyota (Mitsuboshi) timing belt and upgraded crank bolt when doing the work this past summer. All the individual high-quality parts in aircabinman's kit were found to be exactly as advertised and a bargain at that price. .02
  7. Dec 31, 2023 at 7:41 AM
    457taco
    457taco Active Member
    Toby
    Brooklet, GA
    2001 Tacoma pre runner
  8. Dec 31, 2023 at 12:54 PM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    Another vote for aircabinman's kit.
    There are a few parts/supplies that you still need to pick up to complete the job and aren't included in the kit:
    1. The crank pulley bolt, which Toyota says is a single-use bolt given the 217 ft-lbs of torque it's under while in service. (90119-16006)
    2. Two gallons of red coolant concentrate, to refill the radiator when it's reinstalled. (00272-1LLAC)
    3. Six gallons of distilled water - again, for the radiator.
    Here's the write-up I did on the job, and links to all the tools I bought (and where I bought them). Was a great investment from my POV since I've used them a few times, and it's nice to have them around when buddies need them. I've included links below as well for your convenience.
    full write up: Step by Step Toyota Tacoma Timing Belt Replacement for 3.4L V6 5VZFE
    cornbread_wy likes this.
