Timing belt melted/shredded 2003 Tacoma 2wd TRD
Discussion in '1st Gen. Tacomas (1995-2004)' started by eptacoma22, Dec 16, 2017.
  1. Dec 16, 2017 at 4:08 PM
    eptacoma22
    eptacoma22 [OP] Member
    2003 Toyota Tacoma TRD 2wd
    Has anyone ever seen anything like this?? My Tacoma died on the highway the other day and I thought it was the fuel pump. Checked codes and threw an P0340 Camshaft sensor code. Read that it may be on the circuit with fuel pump and cut power to it as a safety measure. I checked all fuses and relays and figured it HAD to be the fuel pump. Well, it was replaced and nothing. No voltage to pump when tested at connection. Continuity was good from fuel pump connection to pump itself and just cannot future out WTF is going on. Anyone had this issue? I opened up the timing belt cover to find this. Half the belt melted/shredded. My mechanic figured the idler pulley seized and melted the belt. He has been Turning wrenches for over 20 years and never seen anything like it. There is nothing grinding/touching the belt and all pulleys turn freely when cranked. Perplexed.IMG_5186.jpg
  2. Dec 16, 2017 at 4:11 PM
    Itchyfeet
    Itchyfeet Well-Known Member
    If he's been turning wrenches for 20 years and has never seen this I'd start questioning his experience.
    I hope he didn't nail you with a fuel pump job when it was the belt that was boned
    wilcam47 likes this.
  3. Dec 16, 2017 at 4:19 PM
    1997tacomav6
    Denver
    Belt and bearings were probably well past their replacement miles
  4. Dec 16, 2017 at 4:20 PM
    eptacoma22
    Have you seen anything like this? He is an ASE Certified Mechanic and may have never run into the issue. He has seen them broken and so forth but never half melted. Timing looks right and sounds normal when we crank the engine. If the pulley seized, why only half the belt? It should be melted all around, I figure. Also, why I am I not getting juice to the fuel pump??
  5. Dec 16, 2017 at 4:25 PM
    eptacoma22
    Belt and bearings were replaced less than a year ago. All done with the water pump job. Torqued to specs etc. May have been a bad pulley/bearing. Thats what we figured. Time to call ROCK auto.
  6. Dec 16, 2017 at 4:25 PM
    RockenAlex
    RockenAlex New Member
    Alex
    Never seen half the belt disappear like that... When a buddy had his water pump seize up it melted and shredded the entire thing. However based on the picture the idler pulley looks to have been rotating with the half belt some, since half of it is shiny from use and the other half has some making's and gunk.
  7. Dec 16, 2017 at 4:27 PM
    eptacoma22
    Now, why am I not getting juice to the fuel pump??
  8. Dec 16, 2017 at 4:29 PM
    Itchyfeet
    He's going to need to tear it down further. The belt is being pushed over because either the tensioner is coming apart or something is causing the belt to not run true. I would not be surprised if the belt has sawn through a cam sensor harness.
    1997tacomav6 likes this.
  9. Dec 16, 2017 at 4:37 PM
    eptacoma22
    Actually, it did not. We pulled the sensor and tested it. Looks good. It was gunked up, but once cleaned it produced voltage(?) on the voltmeter when metal was passed in front of it. I bought a brand new Dayco kit with tensioner, idler pulley etc. I am now remembering a funky sound on start up in the AM. So yes, it probably is the idler pulley. Now my issue is the fuel pump. No juice.
  10. Dec 16, 2017 at 4:54 PM
    eptacoma22
    And yes, now that makes sense! Half the belt under more tension than the other, thus causing more friction on half the belt causing it to melt/shred slowly. Thank you all for the help and insight.
  11. Dec 17, 2017 at 3:04 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Has the Cam sensor code been cleared ??
    Any other codes still present ??
    Something has turned fuel off to a engine that the ECM sees as not running
  12. Dec 17, 2017 at 3:31 AM
    smmarine
    smmarine Well-Known Member
    Melbourne FL
    2020 Kawasaki Vulcan S ABS
    Don’t get anything other than the Denso kit, otherwise you’re going to have issues again. Denso is the factory part manufacturer.
  13. Dec 17, 2017 at 6:11 AM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    Dayco and Bando make the OEM belts for many auto manufacturers. I wouldn't hesitate to run either of them.
    The ECM will not allow the fuel pump to send gas to the engine if it doesn't detect spark happening. So to start, you're looking into why spark isn't being created.
  14. Dec 17, 2017 at 7:29 AM
    NM Lance
    NM Lance Well-Known Member
    I would bet the idler bolt or the tensioner pulley bolt came loose causing eccentric tension on the belt. Did he check the torque on those bolts? Just a guess.
  15. Dec 17, 2017 at 7:31 AM
    NM Lance
    I would think if a pulley seized altogether, the entire belt would be trashed uniformly.
  16. Dec 17, 2017 at 7:40 AM
    eptacoma22
    Cam position sensor codes have been cleared. Still no voltage to pump. And I put in a Dayco kit with new tensioner and pulley. Everything was torqued to specs. I have that kind of luck...the one crappy one out of the factory had to be mine! We are going to look into the open circuit relay and go from there. I will let you know what we found. Thanks.
