timing belt question
Discussion in '1st Gen. Tacomas (1995-2004)' started by kiwi, Oct 26, 2006.
  1. Oct 26, 2006 at 9:30 PM
    kiwi
    kiwi [OP] New Member
    The timing belt on my 2000 Tacoma (v 6 mannual tran) broke last month (82,000) My mechanic was surprised as he had never seen Tacoma timing belts go this early. He said the truck either has more miles on it than says or towed some heavy loads. Bought the truck last year, seems to be well cared for. Does anyone know how long timing belts should last? and why it would go prematurely?
    Thanks
  2. Oct 26, 2006 at 10:29 PM
    4x4Runner
    4x4Runner Sam’s gone, man. Moderator
    Drunken Sailor
    Not north, not south, not west, mostly east
    1WD
    nuttin fancy
    Sounds perfectly reasonable for the timing belt to go at 82k. Most last between 60,ooo miles and 80,000 miles. My 93 4runner's went at 75k
  3. Oct 27, 2006 at 11:46 AM
    jbodine
    jbodine New Member
    I have a 2000 tacoma and run it to the grond and I did mine around 70,000. I did also tow a boat before I turned it into a prerunnner.
  4. Oct 27, 2006 at 11:49 AM
    jbodine
    jbodine New Member
    Run into the ground and towed a boat sorry.
  5. Oct 27, 2006 at 5:04 PM
    06TRDsport
    06TRDsport Well-Known Member
    Bend, OR
    2007 F250 Diesel and 1999 4Runner
    My brothers 96 with the 3.4 v-6 is currently at 186K miles on the timing belt and it still looks new, no weathering, cracking, or signs of stretching. But they are recommended to be replaced every 60K-90K miles.
  6. Oct 28, 2006 at 9:11 PM
    Hilux
    Hilux Member
    My '85 Civic's timing belt snapped at 56K and '91 broke at 78k. May be the extreme cold weather we have here in Northern Illinois made the rubber based timing belts so stiff. So, no more Hondas or any car having a timing belt!. I now have a '06 Taco with 2.7L 4cyl engine. The biggest reason I chose the 4cyl engine was that 4cyl had a timing chain. The biggest reason I did not buy one with 6cyl engine was that 6cyl had a timing belt and it is an "interference fit" type engine which means that the valves and pistons collide each other when the belt snaps and engine can be severely damaged. On the other hand my 4-cylinder is a "free spin" type engine which means that even when the timing chain breaks(I've never heard of that the chain broke, though), the valves and pistons will not collide each other and the repair is relatively cheap because all you have to do is to install the new chain. I've been impressed by Toyota lately because more and more cars, even Corolla engine has a timing chain now.
  7. Oct 29, 2006 at 6:25 PM
    yorgor
    yorgor Member
    That sounds interesting, I wonder if there are conversion kits available to go from a belt to a chain. I did mine at 85 cause it was a designated do, but if it could be converted, I would do it in a heartbeat.
  8. Nov 6, 2006 at 8:57 PM
    khinanight
    khinanight Member
    Am I mistaken? I thought the first generation Tacoma's had timing chains.
  9. Nov 6, 2006 at 9:38 PM
    yorgor
    yorgor Member
    If a 99 is first gen then it's a belt, at least mine is.
  10. Nov 8, 2006 at 7:25 AM
    khinanight
    khinanight Member
    My Tacoma is a '97 and my mechanic said it used a chain. Let me know If he is wrong please!
  11. Nov 9, 2006 at 1:19 PM
    Truck champion
    Truck champion Active Member
    All V-6s prior to 2005 used a belt only th 4-cylinders had chains. Recommended belt change is at about 60k on that generation V-6 most will last to 90 if you baby them. Towing or pulling loads has nothing to do with wear as the belt is only driving the cam shafts and has nothing to do with what laod is on the engine except that high reving and drastic changes in RPM are hard on belts. Poor tensioning can also play a role in premature belt wear.
    2002Tacoma4x4 and SLAPS 65 like this.
  12. Nov 10, 2006 at 7:40 AM
    khinanight
    khinanight Member
    Thank you! That is the best answer yet. Now If only you knew something about ADDCO sway-bars!
  13. Nov 10, 2006 at 2:58 PM
    Truck champion
    What did you want to know! First tell me what you are planning on using your truck for the 5% of the time when it needs to be the badest of the bad. towing? off roading? rock climbing or just going around corners fast?
    j.p. AKA thrck Champion
  14. Nov 10, 2006 at 8:47 PM
    khinanight
    khinanight Member
    I am mainly looking to improve handling for street driving. I haul stuff so I am really limited on what I can do so mainly shocks and sway bars for upgrades?
  15. Nov 11, 2006 at 9:44 PM
    Truck champion
    ADDCO makes decent Sway Bars. Some others to consider are Hellwig, Eibach,Hotchkis or Tanabe. Hotchkis perform very well and look the best with thier Eye grabbing red powder coat. they are beefy and there is only a little rub on the steering rack boot when the truck is in the air as the bar is very thick. ADDCO are alodine coated for rust resistance but will not show as well as the hotchkis. Hope this helps Tokico makes great adjustible shocks. Weather or not they have an application for you year truck is the question. But there are a lot of choices out there for street performance. If it is easily adjustible go for it.
  16. Nov 12, 2006 at 10:01 AM
    khinanight
    khinanight Member
    Thanks for the tip! I was looking at the ADDCO and now will do some further research. Lambert
  17. Nov 15, 2006 at 8:05 PM
    flatboy
    flatboy Member
    Edmonton, Alberta, Canada
    FASTACO
    Turbo, meth, Nitrous, w/a intercooler.
    The hellwig is a better fit up on the rear. If you are lowered or are goina lower the addco will give you some grief on instalation. Up front the addco is a good upgrade.
    Hilux - when I look in my manual it looks like the 4cylinder engines are interfearance.
  18. Nov 16, 2006 at 7:51 AM
    khinanight
    khinanight Member
    Now you answered my question! THanks Flatboy!
  19. Jul 24, 2019 at 7:54 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    last one on the 1st gen list :rofl:
  20. Jul 24, 2019 at 7:56 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    This post is older than my niece.
    GQ7227 likes this.
