Timing belt question
Discussion in '1st Gen. Tacomas (1995-2004)' started by fouillard13, Jan 29, 2014.
  1. Jan 29, 2014 at 5:52 PM
    fouillard13
    fouillard13 [OP] Well-Known Member
    Riley
    Canadia
    1998 tacoma 4x4
    I'm doing my timing belt this week and wondering if I need to replace all the rad fluid? Do I drain the whole rad when doing it or just the top hose?
  2. Jan 29, 2014 at 5:57 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    i would replace the water pump while i was at it
  3. Jan 29, 2014 at 6:31 PM
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    I think you would have to drain it all to drain the water pump.
  4. Jan 30, 2014 at 10:56 AM
    Zer0
    Zer0 Well-Known Member
    SGV, California
    99 PreRunner
    Just let it spill out of the water pump when you replace it. It will drain faster.
  5. Jan 30, 2014 at 11:02 AM
    NCJeyota
    NCJeyota Well-Known Member
    Raleigh,NC
    2002 Tacoma 3.4 v6 Prerunner
    If the antifreeze is still good just drain it in a clean 5 gallon bucket, and pour it back after you hook the radiator back up.
