Timing Belt Question
Discussion in 'Technical Chat' started by Martin64, Oct 6, 2016.
  1. Oct 6, 2016 at 9:40 PM
    Martin64
    Martin64 [OP] Well-Known Member
    Martin
    Yuma, Az
    1998 Tacoma TRD 4x4
    Stock
    So I have a 98 Tacoma with a V6. It only has 44k miles and I'm almost sure it has the original timing belt, but can't be sure. How can I inspect the timing belt without removing covers?
  2. Oct 6, 2016 at 10:54 PM
    00yotasr5
    00yotasr5 Well-Known Member
    lee
    merced, ca
    00 SR5 4X4 RED DEVIL
    Icon ext travel expo leafs rear billies 5125 10'' travel bamf bpv relocate Brute Force Fab Sliders allpro ss brake lines f/r LR UCA 22in wetokled bar RAT Products ifs skid ARB rear locker Ultra gauge Redline Hood Struts Blue Sea Fuse box smittybilt xrc 9.5 w/TJM synthetic rope trail-gear rock assault low profile bumper LED bed strip 12v/usb charger in truck bed
    with that low of a mileage, its for sure gotta be the original. gotta remove the covers to see belt. no other way.
    98tacoma27 likes this.
  3. Oct 7, 2016 at 7:27 AM
    Martin64
    Martin
    Yuma, Az
    1998 Tacoma TRD 4x4
    Stock
    So has anyone ever thought about cutting an inspection port into their cover?
  4. Oct 10, 2016 at 12:49 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Quite simple to loosen the top cover and pull it front to have a look
    Loosen the hose clamp slide it towards the radiator remove the bolts holding the cover slide it front
    Take a gander at the belt .
    Push the cover back install your bolts place the hose clamp back tighten if it is the screw type
    I thought every one did this .
    I do this during a pre purchase inspection
    Martin64[OP] likes this.
  5. Oct 10, 2016 at 5:22 AM
    Martin64
    Martin
    Yuma, Az
    1998 Tacoma TRD 4x4
    Stock
    I still have to go get the truck and, having not gone through the process or having the truck in the driveway, I'm building my list of stuff that has to be done. I tend to think things are harder than they actually are but I also tend to do quite a few "fixes" to things just to make processes easier or a lot more simple.
