timing belt questions
Discussion in '1st Gen. Tacomas (1995-2004)' started by 04trd, Feb 16, 2011.
  1. Feb 16, 2011 at 10:08 AM
    04trd
    04trd [OP] Well-Known Member
    Cleveland Ohio
    2015 f150 lariat
    weather techs, 20precent tint, leveling kit, back flip bed cover, rhino liner
    hey i was wondering what you guys think of the stealer ship telling me that when i do my timing belt i should do my water pump also?
    does that seem right
  2. Feb 16, 2011 at 10:11 AM
    davidpick
    davidpick NWXPDTN
    David
    Leavenworth, WA
    1988 Pickup 22R 5sp 2wd
    Weber 32/36, RV Cam, LCE exhaust headers, Desmogged
    yes, they're typically done at the same time as they have about the same life-expectancy. you're already that far into the engine, so you save the cost of labor doing both at the same time.
  3. Feb 16, 2011 at 10:13 AM
    04trd
    Cleveland Ohio
    2015 f150 lariat
    ok thanks that what i thought, they are doin if for 600 out the door with timing belt and water pump seems pretty fair
  4. Feb 16, 2011 at 10:52 AM
    Space Wrangler
    Space Wrangler Well-Known Member
    JCT
    Ga
    04 DC 4x4
    04 Tacoma 4x4 Double Cab SAW 2.0's Alcan's Ion 171 wheels 15x8 (-27mm bs) 32" BFG AT's
    make sure they change the thermostat, pcv valve, and the drive belts if needed. ...good time to get all that out of the way. ...going rate is $600-$800 for everything. ...you may also want to ask for a 10% discount. ...they'll usually agree.
  5. Feb 16, 2011 at 3:01 PM
    04trd
    Cleveland Ohio
    2015 f150 lariat
    just got it back from the stealer ship, they did a good job changed everything that they said they would and than they did a factory undercoating. They did a pretty good job i am impressed but they guy said its not going to dry up, has anyone else done that factory undercoating? and has it dried to the touch where you wont get it on you if you work on your truck, cause if it dont dry i will be pretty pissed
