Timing belt questions?
Discussion in '1st Gen. Tacomas (1995-2004)' started by sir1123, Feb 9, 2012.
  1. Feb 9, 2012 at 9:33 PM
    sir1123
    sir1123 [OP] Tacomas FTMFW!!!!
    Charleston
    99 SR5 Prerunner, Black,3.4L
    3"Ebaich with 5100 Bilstiens, K&N cai, 5% 3M Tint, Magnaflow 18", Hella 500s with 35w 3000k hid retro, 33x9.5x15 BFG A/T
    My truck has 216k on it. i do belive the timing belt has been changed. does anybody know what brand toyota uses for their tb from factory? i do know that they are suppossed to be replace around 90k so my truck should have gone through 2 of them by now. i am the second owner so i dont know if it has been done twice. am almost positive it has been replaced i just need to know what the factory brand is so i can tell.. Also what kind of wear should i look for for signs that it need to be changed? Thanks
  2. Feb 9, 2012 at 9:51 PM
    Jdaniel1274
    Jdaniel1274 Well-Known Member
    Daniel
    Orange County, Ca
    01 DC TRD 4X4
    PIAA lights, OMD leaf spring mod, magna flow muffler, oil filter relocation kit
    Do not know the brand, just change the Timing belt along with the water pump. Your getting close 270,000 anyway.
  3. Feb 9, 2012 at 9:53 PM
    Tacomadude89
    Tacomadude89 Well-Known Member
    Austen
    California
    2002 Tacoma TRD SR5, 3.4, 5spd
    -Bilstein 5100 Series shocks on all 4 corners -Rancho HD lift coils -1/4" Toytec driverside top plate spacer -Toytec 1" diff drop -Wheelers 1.5" AAL's -Toytec 1" lift shackles -Revtek extended length BPV bracket -285/75/16 BFG KO T/A's -Pro Comp rims -ET Conical tyle lug nuts -Spidertrax 1.5" wheel Spacers -CV Boot slide mod -TRD skid plate -Magnaflow 14" round muffler -Shortened tailpipe hidden behind framerail -Toyota bug deflector -Weathertech floormats -Black leather seat covers -Valentine 1 Radar Detector
    I'm fairly certain it's a Mitsubishi.
  4. Feb 9, 2012 at 9:58 PM
    sir1123
    Charleston
    should i change the tensioner pullys? and is the tensioner tool worth the $30 bucks?
  5. Feb 9, 2012 at 10:00 PM
    TACOMABOSS
    TACOMABOSS Well-Known Member
    96 SR5 4x4
    Bilstein 5100s, Toytec AAL, Deck plate mod, Hella 500ff's, Sportsman Camo seat covers, Total Chaos 1" diff drop, JVC stereo, Painted bumpers and grille, Custom grille insert, HID projectors, Black spray paint
    that seems to be ringing a bell too
    And X2 on the water pump
  6. Feb 9, 2012 at 10:02 PM
    sir1123
    Charleston
    i will be doing the pump even though i am not getting any strange noises from any bearings up in that area
  7. Feb 9, 2012 at 10:04 PM
    TACOMABOSS
    96 SR5 4x4
    i cant say for sure. if you dont hear them squeaking or anything i think they should be fine. but im not 100% sure
  8. Feb 9, 2012 at 10:12 PM
    Tacomadude89
    Austen
    California
    The issue with the pump is that they eventually begin to leak all of which usually starts to occur between 100k-200K, in other words soon after you do the pump if it's not already leaking. You don't want to have to go back in there again just to change out the pump, so it's extra security and better to do it all at once while you're in there in the first place.
  9. Feb 9, 2012 at 10:14 PM
    sir1123
    Charleston
    i mean that makes sense. i guess i will make sure a auto store has some on standby then wiggle em around when i do this job sometime this spring. thanks for all the help and i know it isnt a mitsu belt so i guess it has been changed....or were yall being facisiuos?
