Timing belt replacement 5VZ Hilux
Discussion in '1st Gen. Tacomas (1995-2004)' started by twistit, Jun 1, 2009.
  1. Jun 1, 2009 at 5:20 AM
    twistit
    twistit [OP] Member
    3.6 v6 4x4 Hilux
    Hi there, from australia and i have a Hilux 04 3.4 v6 4x4, xtra cab. i bought it last november with 65000 miles on it, it now has 70k. Since then ive put new plugs in, new fuel filter, changed rear diff oil, greased drive shaft etc, done the deck plate mod and done the usual oil and filter change.
    Im thinkin bout tackling the timing belt (if its even needed), if so do i need any special tools?
    Is there anything else i should be doing as well?
    Cheers
  2. Jun 1, 2009 at 5:25 AM
    98tacoma27
    Ben
    Not Beech Creek
  3. Jun 1, 2009 at 5:55 AM
    98tacoma27
    Ben
    Not Beech Creek
  4. Jul 6, 2009 at 9:04 AM
    perniva1978
    perniva1978 Active Member
    Fort Worth TX
    04 PreRunner V6 Double Cab
    Bridgetone Dueler Alenza
    So at what mileage should the Tacoma's get their timing belt replaced? Dealers say 90K and some people say 120K ?
  5. Jul 6, 2009 at 11:27 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    90k
