timing belt replacement
Discussion in 'Garage / Workshop' started by Steve97501, May 12, 2015.
  1. May 12, 2015 at 8:54 PM
    Steve97501
    Steve97501 [OP] New Member
    2004 Tacoma TRD 4WD V6
    My 2004 has only 64,000 miles, but the dealer says the belt should be replaced at 90K or 10 years, whichever comes first.
    Is it a good idea to change it out now along with the water pump, etc?
  2. May 13, 2015 at 2:41 AM
    coffeesnob
    coffeesnob Well-Known Member
    VA
    2010 access 4 cyl 2 wd
    I'd wait till you hit 90 but I am by no means a mechanic.
  3. May 15, 2015 at 5:47 AM
    ecoterragaia
    ecoterragaia Everyone lives downstream.
    Central Virginia
    2006 RC 4X4 5 speed & 2021 4Runner SR5
    If you can, check for cracks or other wear to the belt. If it has any cracks I'd change it out, you dont want it break or you can say goodbye to the engine.
  4. May 15, 2015 at 5:59 AM
    JLee
    JLee The Man! Vendor
    Jerry
    Benicia, CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    Not true the 3.4 is a non interference engine so no bent valves if it broke. The worst thing is a tow back home or a shop. I dont think you can check for cracks without getting in there and you might as well just change it if your that far.
  5. May 15, 2015 at 7:44 AM
    ecoterragaia
    Central Virginia
    Oh cool, i didnt know that. Sorry for the misinformation.
  6. May 15, 2015 at 12:11 PM
    JLee
    Jerry
    Benicia, CA
    This^ i really think the water pump is the main reason to be in there in the first place. Change everything you can wile in there. That reminds me I'm changing mine this weekend after 165,000 miles or at least i think it's never been done I bought it at 94,000 and have no record of it being done :oops:
  7. May 15, 2015 at 12:41 PM
    DriverSound
    DriverSound Señor Member
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    90K is the change interval but like others have said, change everything while you're in there. I have seen these motors go over 200K+ on the same T-belt and water pump. It's all over craigslist.
  8. May 18, 2015 at 12:40 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Just what other then the mileage is the reason the belt itself being cracked or dry rotted ?? It is quite easy to pull the top cover off and inspect the belt
    Does the belt stretch beyond the ability of the tensionor to keep it tight ?? To the point the timing changes or the belt just comes off stopping every thing.
    I am sure some of us have engines we have no clue when the timing belt was done if at all.
    If you need to pay to have this done it can be quite expensive.
