Timing belt service
Discussion in '1st Gen. Tacomas (1995-2004)' started by 98Tacoma, Oct 12, 2011.
  1. Oct 12, 2011 at 9:58 AM
    98Tacoma
    98Tacoma [OP] Well-Known Member
    adam
    V.A.
    1998 V6 xtracab
    k&N intake, 40 flowmaster turndown, westin brushguard,10 inch JL sub, alpine cd player.painted black tool box. bilstein 5100s 3inch Ebiach springs all around and toytec aal. mickey thompson beadlocks. and 33inch goodyear duratracs
    ok i have a 98 tacoma 5vz with 170k on it have no idea when the timing belt was changed so i was going to go ahead and do it as preventive maint.
    im planning on using all oem toyota parts i kno i need the
    the timing belt
    tensioner
    water pump
    accessory belt
    what gaskets should i change.
    if there is anything else i need plz let me kno id like to only do this once till the next 60K miles get here. thanks
  2. Oct 12, 2011 at 2:49 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    x2...litterally. There are two of them.
    Also add
    Camshaft seals (again two)
    Crankshaft seal
    waterpump gasket
    thermostat
    thermostat gasket
  3. Oct 12, 2011 at 4:05 PM
    .Trdtaco315.
    .Trdtaco315. Well-Known Member
    Will
    Santa ana
    03 Trd SR5 Prerunner
    how much would all of this cost???
  4. Oct 12, 2011 at 6:55 PM
    98Tacoma
    adam
    V.A.
    1998 V6 xtracab
    i called my dealer ship
    the belt was 55
    and the pump was 185. damn
    and tensioner was like 35.
    i was going to get upper and lower radiator hoses and accessory belts from advance. but i guess i should get all the gaskets and seals from toyota
  5. Oct 12, 2011 at 7:40 PM
    98Tacoma
    adam
    V.A.
    1998 V6 xtracab
  6. Oct 12, 2011 at 9:44 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
  7. Oct 12, 2011 at 9:54 PM
    707eric
    707eric Member
    Santa Rosa
    99 TRD 4x4
    You are an amazing man! I was just knee deep in kits also. This saves a lot of time and headache.
    Same seller also sells this kit
    $285 15 Piece 3.4L engine TIMING BELT KIT WATER PUMP Genuine & OE Manufacture Parts!http://cgi.ebay.com/ebaymotors/Toyo...r_Truck_Parts_Accessories&hash=item2a144a37e8
    Same amount parts but OEM
  8. Oct 14, 2011 at 3:32 PM
    98Tacoma
    adam
    V.A.
    1998 V6 xtracab
  9. Oct 15, 2011 at 9:07 AM
    707eric
    707eric Member
    Santa Rosa
    99 TRD 4x4
    As far as I can tell technically it is one idler pulley and one tensioner pulley. Everything have looked at only shows the two but I could be wrong. I haven't opened my FSM yet. It is advertised as a complete kit so I assume it is.
    The same guy also has this kit
    $231 Toyota V6 Trucks TIMING BELT+WATER PUMP KIT w/ Hydraulic Ten Genuine +OE Partshttp://www.ebay.com/itm/Toyota-V6-T...Parts_Accessories&vxp=mtr&hash=item2c5f7f7331
    Which is the one I am getting. The only difference between this kit and the other I linked is it doesn't have the drive belts. Mine were recently replaced so no point in spending the extra $50.
  10. Oct 15, 2011 at 2:31 PM
    clothar
    clothar Well-Known Member
    Vancouver
    98 V6 4WD Xtra Cab Limited
    +1 this is the kit that i bought had absolutely everything and for 8 bucks more than the kit you were looking at you get all the drive belts too (good to have back ups. The only difference is that it's a Mitsubishi timing belt other than a toyota one. But the other part numbers are identical. I did the same thing as you bought a truck with no history on the timing belt sure am glad i changed it some good piece of mind there.
  11. Oct 15, 2011 at 9:27 PM
    98Tacoma
    adam
    V.A.
    1998 V6 xtracab
  12. Oct 17, 2011 at 7:43 PM
    98Tacoma
    adam
    V.A.
    1998 V6 xtracab
  13. Oct 17, 2011 at 8:03 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Looks like everything.
  14. Oct 17, 2011 at 8:18 PM
    98Tacoma
    adam
    V.A.
    1998 V6 xtracab
    are upper and lower idler pulley in there to im guessing there just have a special name for it?
  15. Oct 17, 2011 at 8:21 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    They are called rollers. Idler roller and tensioner roller. Idler is on the top, tensioner on the bottom.
  16. Oct 17, 2011 at 8:41 PM
    98Tacoma
    adam
    V.A.
    1998 V6 xtracab
    ok thanks bro for all the help i will be ordering that kit tomorrow.
