Timing Belt Suggestions
Discussion in '1st Gen. Tacomas (1995-2004)' started by La_Mere, Jun 12, 2025.
  1. Jun 16, 2025 at 2:00 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Only worth it if you done get fleebay crap parts.
  2. Jun 16, 2025 at 4:23 PM
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    2023 TRD SPORT 4X4 DCSB CSM, 2004 TRD OR DCSB IRP
    They’re counterfeit…… stay away from those parts on eBay!
    gotoman1969 likes this.
  3. Jun 16, 2025 at 6:38 PM
    gotoman1969
    Just remember OP OEM from a 3rd party is not the same as OE from the dealer.
    t0p_d0g likes this.
  4. Jun 16, 2025 at 10:00 PM
    JustADriver
    JustADriver Well-Known Member
    1996 Tacoma 3.4L V6 2WD 5-lug AT 5VZ-FE
    I don't understand. People have been raving for years about aircabinman's kit being legit Aisin and OEM parts. Now all of a sudden you're saying he's selling fakes?
    ChinoXL likes this.
  5. Jun 16, 2025 at 10:19 PM
    ztwatson
    ztwatson Well-Known Member
    Milwaukee, WI
    2004 Tacoma TRD Xtra Cab
    I heard he was ripping people off recently on Facebook. Don’t know if it is true.
    Don’t over think it. Either get OEM and pay or get Aisin and get likely OEM quality at a discount. Don’t buy fake OEM Toyota on EBay.
    I bought this kit from Amazon. $350. Been doing great the past 2,000 miles since installation.
    Timing Belt KIT with Water Pump https://www.amazon.com/dp/B09MQ4XFTF
  6. Jun 19, 2025 at 6:24 PM
    AlexR
    AlexR New Member
    Alexander
    2001 Toyota Tacoma Prerunner 3.4
    I did my timing belt and few months back on my 2001 Prerunner v6. Got everything from yota shop and its high quality parts. You don’t have to buy the complete kits. You at least need water pump and might as well do thermostat.
    At minimum you should get mitsuboshi timing belt, belt tensioner, and water pump.
  7. Jun 21, 2025 at 7:40 AM
    ChinoXL
    ChinoXL Well-Known Member
    95 Tacoma V6 MT 4x4 Xtracab
    I had the 16 pc aircabinman kit installed 13k miles ago and haven’t had any issues. The shop that did the work was impressed that I had all the “right stuff”.
    leid likes this.
  8. Jun 21, 2025 at 1:54 PM
    CrippledOldMan
    CrippledOldMan Well-Known Member
    David
    Salisbury North Carolina
    2003 TRD Crew Cab
    None
    Post #27, Aircabinman on has a reputable kit on ebay that should be right up your alley. check it out if you haven't already purchased another Kit. I'm surprised that other members didn't chime in before my post
  9. Jun 22, 2025 at 8:18 AM
    Clucky
    Clucky Well-Known Member
    W
    WC to EC back to WC
    00 SR5 Stock 5 Speed
    & 12 TRD Stock 6 Speed
    Working on finally resealing leaking oil pump and pan on 3.4 L 4wd. In my enthusiasm I didn't notice there were no longer visible marks on the timing belt before taking it off. I was planning to reuse it as it's only 14 months old. Anyone put one on without marks?
  10. Jun 22, 2025 at 8:39 AM
    SpencerTacoSC
    SpencerTacoSC Well-Known Member
    Daniel
    2004 Tacoma 4x4 V6
    No big. The marks are mostly for convenience when you're putting the belt on. Just start from one end and work your way around, then spin the engine around two full revolutions (one complete cycle) - if the timing marks on the cam pulleys & crank pulley are still in sync, you're good to go. If not, one of those three is off by a tooth or two - adjust, and try again.
  11. Jun 25, 2025 at 2:46 PM
    La_Mere
    La_Mere [OP] Member
    Christopher
    Arizona
    2000 Tacoma 3.4L 5-speed 4x4
    All I had to do was loosen some bolts. The upper radiator hose clamp kept it from moving too far off, but it was still enough to catch a glimpse of the timing belt.
  12. Jun 25, 2025 at 2:50 PM
    La_Mere
    La_Mere [OP] Member
    Christopher
    Arizona
    Okay, so I ended up getting that 16pc kit from aircabinman. Out the door it was $422 and change. Ill let everyone know if the parts are real or not when it gets here.
    Now I need to get the SST's to install it...
  13. Jun 25, 2025 at 3:20 PM
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    I looked at that kit and it looks legit.
  14. Jun 25, 2025 at 3:56 PM
    rish57
    rish57 Well-Known Member
    2000 Tacoma 3.4L SR5 4x4
    I got the same kit about 6 weeks ago and thoroughly inspected everything...looks completely legit...I actually ordered a timing belt straight from Toyota a couple years ago that I never put on and it's completely identical, including the packaging etc...just fyi, I did also order the A/C pulley since it was cheap and people have had them seize up on them, didn't want any strain on the system when I do this in like a week...the pulley is like $50.
  15. Jun 25, 2025 at 4:21 PM
    #35
    La_Mere
    La_Mere [OP] Member
    Christopher
    Arizona
    Good to know... Here's another one: Can I use a cheapo Harbor Freight puller instead of the OTC one that people recommend? What about the belt tension gauge? Is it necessary?
  16. Jun 25, 2025 at 4:24 PM
    #36
    SpencerTacoSC
    Daniel
    2004 Tacoma 4x4 V6
    The belt tension gauge is a convenience - that said, I used a Krikit-style tension gauge, which is a lot cheaper than the dial-type. Trickier to use, but that's your tradeoff for convenience. I have no idea about the Harbor Freight puller, but if it's the right style it should work.
  17. Jun 26, 2025 at 7:12 AM
    #37
    rish57
    Great question...I'll be honest, up till a couple weeks ago I didn't even know a gauge like that existed and I got that one that was suggested just because the starting tension on that belt is so important...it wasn't cheap, I think in total I spent around $400 in tools just for this job...I didn't want to be knuckles deep and regret not having something that would make my job easier, plus one of the kits I knew I needed for other jobs.
  18. Jun 26, 2025 at 1:57 PM
    #38
    CrippledOldMan
    David
    2003 TRD Crew Cab
    None
    From all of the posts, and Threads I've read about this kit, I don't think you'll be sorry you purchased it. I purchased an Aisin kit before I knew about these kits from aircabinman. Let us know what you think when you get it.
  19. Jun 30, 2025 at 4:52 PM
    #39
    La_Mere
    La_Mere [OP] Member
    Christopher
    Arizona
    I just received my eBay kit and have been going through it for the past hour or so. Everything is either oem (Toyota, Aisin, Koyo, etc.) Or came in a branded Toyota box, with the exception of the crank bolt. Out the door, this kit set me back $422, including tax. Everything was nicely packaged and the water pump gasket is perfect. This kit came with everything to do the job except the tools, which I will be hunting down next. I might post a wtb ad here for the tools, just in case there's someone here that doesn't use theirs anymore.
    #39
    rish57, leid and ChinoXL like this.
  20. Jul 1, 2025 at 7:54 AM
    #40
    rish57
    When I get home later, I'll check my packaging against yours and see how it compares as I bought that kit about 6 weeks ago.
