Timing belt
Discussion in '1st Gen. Tacomas (1995-2004)' started by Whitelightning77, Jul 18, 2010.
  1. Jul 18, 2010 at 7:32 PM
    Whitelightning77
    Whitelightning77 [OP] Member
    Jake
    Driggs, Idaho
    1998 Tacoma extended cab trd
    Rims, hoe lights, sound system, tint, vent shades. Mostly all cosmetic right now. Can't wait to finally have it paid off, and start doing suspension and performance mods.
    So you're suppose to chage your timing belt before 100,000 miles. So does that mean you gotta change it before or at 200,000?
  2. Jul 18, 2010 at 8:25 PM
    Tacomadude89
    Tacomadude89 Well-Known Member
    Austen
  3. Jul 18, 2010 at 8:28 PM
    x2468
    x2468 Well-Known Member
    '02 TRD 4wd V6 Xcab Sr5
    Im 99% sure it's every 90,000 miles. So you should do the second one 90,000 miles after you changed it the first time.
  4. Jul 18, 2010 at 8:30 PM
    wildjerseyfirefighter
    wildjerseyfirefighter I sell fishing and fishing accessories
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    im hoping this winter to have mine done..Sticker on the timing cover says 70,000 ish..I have 138,000 now. lol
  5. Jul 19, 2010 at 11:36 AM
    01Tac0ma
    01Tac0ma Bash Fabriction & Off-Road
    Chad
    West Columbia, SC
    SAS 01 TRD 4x4
    Look at build!
    mine was done around 126,xxx
  6. Jul 19, 2010 at 3:28 PM
    crazyasu45
    crazyasu45 Well-Known Member
    Canada
    2013 MGM DCLB 4X4 TRD SPORT
    3" SUSPENSION LIFT
  7. Jul 19, 2010 at 3:54 PM
    747 function > form
    1st Gen.
    I thought Toyota recommended timing belt change at 60k? Anyone?
  8. Jul 19, 2010 at 3:57 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    When I owned my 96 tacoma...it was 60K miles. That's what my owners manual said.
    Now....according to some, I've read that Toyota changed it to 90k miles in the newer trucks.
    Do you have an owners manual? It'll be listed in there.
  9. Jul 19, 2010 at 3:59 PM
    Janster
    Jandy
    Lancaster, PA
  10. Jul 19, 2010 at 4:02 PM
    Hot Sace
    Hot Sace Well-Known Member
    Sue
    Cali.
    *01 S-Runner*
    Welded roll pan, custom tail lights, tail lights are candied and smoked, 20' chrome rims 225/35/20, Line-X Xtra bedliner, Chassis Tech leafs, LCE short shifter, Eibach drop coils, 3 peice Racemesh grille, 4 wd lower valance w/ Racemesh grille (not yet finished and installed), blacked headlights, corners and blinkers, Hid headlights, Eclipse head unit. Have new rims on order (HP Design Lightning 18'), single pane rear window, shaved tailgate, all windows tinted including full windsheild,
    About 136,000 and it was still in pretty good shape.
  11. Jul 19, 2010 at 4:05 PM
    747 function > form
    1st Gen.
    Nerp...no owner's manual. fwiw, I found this on edmunds. Sweet...another 30k on my current t-b.
  12. Jul 19, 2010 at 4:07 PM
    Speed Freek
    Speed Freek Tacoma Whisperer!
    Vista, Ca, Lake Havasu, Az.
    98 Tacoma V8 (LS1) swap
    LS1-T56 swap, Z06 ported heads, cam, Titanium valves, Kevlar clutch. Now building a forged stroker (383) and all the ponies! Old setup was rod-knockin on heaven's door...
    I would suggest doing them every 90,000 or less, the main problem with old timing belts is that they stretch and throw off the camshaft timing, not that they break necessarily.
  13. Jul 19, 2010 at 4:19 PM
    Madjik_Man
    Colorado Front Range
    For my '98 they recommend it every 90K.
    Of course that meant I did it at 125k because I'm semi-moronic. It was in pretty bad shape. Lots of cracks in between each "tooth" and when the mechanic flexed it backwards the rubber snapped/cracked in half.
  14. Jul 19, 2010 at 5:33 PM
    Whitelightning77
    Jake
    Driggs, Idaho
    Ok so do think I should take it to a Toyota dealer? And how much did it cost you guys?
  15. Jul 19, 2010 at 5:34 PM
    747 function > form
    1st Gen.
    I think it was just under $400 (i.e., like $360 or so) when I had it done...non-dealership...all belts replaced at same time.
  16. Jul 19, 2010 at 8:20 PM
    BajaTaco96
    BajaTaco96 Well-Known Member
    Silver Springs, FL
    1996 Toyota Tacoma 4wd, 3" suspension lift
    K&N, ToyTec 3" front spacers, 3" Fabtech AAL's, Flowmaster exhuast, no cat, Exedy Stage 2 clutch
    I need to change mine. :eek: 230,xxx miles and haven't touched it. :eek:
  17. Jul 19, 2010 at 8:23 PM
    Firefighter160
    Firefighter160 Well-Known Member
    Josh
    Eastern VA
    05 DCSB Offroad
    Lol, a friend of mine just changed his on his 96 Taco for the first time at 215k, he said it still looked perfect.
  18. Jul 19, 2010 at 8:54 PM
    Madjik_Man
    $550 which included doing the water pump. Which is highly recommended since it's easily accessible when you're doing the timing belt.
  19. Jul 19, 2010 at 9:02 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    A timing belt isnt going to "look" bad. It degrades. At what point, is unknown. I have seen them last as much as 180k miles, and let go at 98k miles. Best to change it at the recomended interval, as they rarely last longer than 110k miles.
  20. Jul 19, 2010 at 9:05 PM
    tacosuprem
    tacosuprem Well-Known Member
    Florida
    4x4
    209k stock belt
