Timing belt
Discussion in '1st Gen. Tacomas (1995-2004)' started by Whitelightning77, Jul 18, 2010.
  1. Jul 20, 2010 at 1:11 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    X2
    It'll never look bad. It's the nylon strands inside the rubber that fatique and can break un-expectedly.
    Besides all this....Your water pump will probably need changed before the timing belt anyway. So - when your water pump fails or leaks, this is the best oppurtunity to change the water pump, timing belt & thermostat.
  2. Jul 20, 2010 at 9:26 AM
    asus611
    asus611 Well-Known Member
    CA
    03 Double Cab Prerunner
    ^^ agree with above. At 90K my timing belt looked pristine, but my water pump was leaking quite a bit.
  3. Jul 20, 2010 at 11:21 AM
    Space Wrangler
    Space Wrangler Well-Known Member
    JCT
    Ga
    04 DC 4x4
    04 Tacoma 4x4 Double Cab SAW 2.0's Alcan's Ion 171 wheels 15x8 (-27mm bs) 32" BFG AT's
    in some cases, it will. they start to frey at the edges and it gets progressively worse to the point where it looks like tangled up hair..
    here's a pic of belt that's just starting to frey.
    now, that's not to say that a belt that looks brand new won't break.
  4. Jul 20, 2010 at 12:57 PM
    Madjik_Man
    Colorado Front Range
    I respectfully disagree.
    When they showed me mine it clearly had those "dried out/rotting" cracks in between the teeth.
  5. Jul 20, 2010 at 2:15 PM
    Janster
    Jandy
    Lancaster, PA
    The point here is.....
    DO NOT judge a timing belt by how it looks. The all-important structure of the belt is hidden underneath the rubber. This nylon structure can be stressed without you even seeing it.
    Honestly? If you have a belt that's dry rotted and/or freying on the edges, then you've been avoiding your vehicle maintenance and have pushed the belts lifespan WAY TOO FAR.
  6. Aug 10, 2010 at 5:15 AM
    tacoma guy
    tacoma guy Well-Known Member
    Joe
    Phoenix Az.
    2011 Tacoma Prerunner TRD
    Bilstein 5100's on all four corners. Front set @ 0 with OME 883x coils. Alcon leaf springs. Viper Alarm. Wet Okole seat covers. WeatherTech Floor liners front and back. Oem Toyota chrome exhaust tip. ARE Shell. America Outlaw Wheels.
    x2 on 60k. That is what toyota recommends.
