timing belt?
Discussion in '1st Gen. Tacomas (1995-2004)' started by B ryan, Dec 18, 2011.
  1. Dec 18, 2011 at 5:03 PM
    B ryan
    B ryan [OP] Well-Known Member
    Bryan
    Washington
    '00 3.4 sr5 4wd
    K&N intake, Flow series exhaust, bfg all-terrains, Line-X bed liner, 2.5'' leveling kit, diff drop(just to be safe), hard wired inverter, Delta tool box, high lift mounted in bed, Jerry can mount for in the bed, spidertrax wheel spacers, all-pro rear bumper, gray wire mod
    My 2000 tacoma has 128,000 on it and am not sure if the timing belt has ever been changed. I've done basically everything else to "tune it up" since I bought it 6,000 miles ago, but am wondering if I should change it now or if I can wait a few more thousand miles. I know the sooner the better but I just spent a crap load of the green stuff on this thing and my wife would go crazy if she found out I now need to spend another $1000. Any wisdom on the matter would be appreciated.
  2. Dec 18, 2011 at 5:08 PM
    Monkeysuncle
    Monkeysuncle My Cat's breath Smells like Cat Food
    Kevin
    Florida
    99 Tacoma SR5 4x4 5 speed Manual Hubs
    Diff Breather,CB thingy,GPS,Cop Shocks,Cop Brakes, old Man Emu 881's Dakar Leaf Springs and Nitro sport shocks. Deck Plate mod
    You are good to go. When you do replace it go ahead and change the waterpump thermostat (and pullys if money permits) If it does break it will not kill the motor, you will be stranded though..
  3. Dec 18, 2011 at 5:13 PM
    TACOMABOSS
    TACOMABOSS Well-Known Member
    96 SR5 4x4
    Bilstein 5100s, Toytec AAL, Deck plate mod, Hella 500ff's, Sportsman Camo seat covers, Total Chaos 1" diff drop, JVC stereo, Painted bumpers and grille, Custom grille insert, HID projectors, Black spray paint
    X2
  4. Dec 18, 2011 at 5:24 PM
    hayabusa3303
    hayabusa3303 Well-Known Member
    florence sc
    95.5 taco 4x4
    ARB bumper, warn 9.5 winch. carbon fiber hood. Leer top with thule racks and MOAB from thule. Electric fans, blue sea fuse block, Sony dvd Head unit, Xm tuner and HD tuner. New carpet and new racing seats. ( other half doesnt like them i think). Nwor springs and adjustable coil overs. Sky jacker rear shocks. Slot and drilled rotors. Engine Titanium ceramic coated headers, no cat, jba cat back. URD Rear Sensor Simulator. Leds all around and inside cab and HID H4 hi/lo beams.
    Replace cam seals if leaking.
  5. Dec 18, 2011 at 8:53 PM
    B ryan
    Bryan
    Washington
    '00 3.4 sr5 4wd
    So a buddy of mine said that I should do it real quick cause if that belt snaps, it'll whip around and screws up a whole lot of other stuff in vicinity basically totaling the vehicle. Is this not necessarily true on the 3.4 engines?
  6. Dec 18, 2011 at 9:00 PM
    Project.paradigm
    Project.paradigm Well-Known Member
    Oil Country,Alberta, Canada
    04 TRD 4X4 Dub cab
    Airlift rear air bags. Hood struts. sockmonkey bedside decal. TRD supercharger(not installed). Deckplate. Grey wire mod. Extended rear diff breather. 6000k HIDS. 18"Magnaflow. Truxxx 3" level kit. (Temporary) Wet Okole seat covers. BoxRocket bed rack. Bora 0.75 wheel spacers All pro sliders. BAMF BPV. B&M trans cooler.
    I can't see it taking out more than the timing belt cover. Pull the cover off and have a look at the belt. If it's in really bad shape change it. If not, wait until you can afford it, just don't wait too long.
  7. Dec 18, 2011 at 9:05 PM
    MARSHBUSTER
    MARSHBUSTER Well-Known Member
    Jim
    Alamogordo NM
    2005 SR5 4X4 Tacoma TRD
    Grill Gaurd/ Winch Bumper, Mile Marker 9000 LBS Winch, Custom Head Ache Rack, Custom Rear Bumper, Marathon Camo Max 4 Seat Covers
    What about on a 2005 4.0 V6 with just over 91000 miles when should the belt be changed??? Thanks for any input!!!!!!!!!!!!!!!
  8. Dec 18, 2011 at 9:22 PM
    TACOMABOSS
    96 SR5 4x4
    no it wont totally screw up your engine. you will still have an engine but you will be stranded
  9. Dec 18, 2011 at 9:23 PM
    Project.paradigm
    04 TRD 4X4 Dub cab
    I think you have a timing chain, so i wouldn't worry about it. Some one correct me if i'm wrong. (That was for the 2nd gen guy)
