Timing belt
Discussion in '1st Gen. Tacomas (1995-2004)' started by Joserdog, May 4, 2017.
  1. May 4, 2017 at 9:55 PM
    Joserdog
    Joserdog [OP] Member
    Jose
    San Jose
    2003 Tacoma TRD
    3" lift
    I just bought a 2003 tacoma limited 4x4 automatic couple months ago and the timing belt is consistently making a screeching noise when it idols is this a sign I should change the timing belt
  2. May 4, 2017 at 10:04 PM
    McMash
    McMash The only thing better than light bars? Sarcasm.
    Tyler
    Gig Harbor, Wa.
    '04 Tacoma AC TRD 4x4
    How many miles are on the truck? Has the timing belt ever been changed?
    Are you positive it is coming from the timing belt and not another belt or something else?
  3. May 5, 2017 at 5:57 AM
    NightProwler
    NightProwler Well-Known Member
    Harlan
    Maricopa, Az
    '01 Prerunner, '03 cbr600rr, '09 R1, '03 cbr954rr
    Yeah better be sure what it is exactly. Timing belt screaching/squeeling would only be caused by one of the idler/tensioner rollers seizing up. Which is doubtful, but possible. Otherwise I'd suspect a drive belt.
    However it could also be the water pump bearing seizing and screeching. Mine did this. So is it more of a belt squeel, or bearing screach?
  4. May 5, 2017 at 12:59 PM
    Joserdog
    Jose
    San Jose
    2003 Tacoma TRD
    3" lift
    I think it is possibly another belt and it has 135 k miles on it but thanks for the tips.
  5. May 6, 2017 at 7:22 AM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    FIRST YOU NEVER SAID IF YOU HAVE V6 OR i4 SO I GOTTA ASK??????????????? I4 have timing chains not belts and the chains never need replacing.
    next the most common issue for squealing is the idler pulleys for a/c and power steering belt, they each have one and they only cost $20 or $8 if you take it apart and just replace the bearing in it
  6. May 6, 2017 at 10:32 AM
    Joserdog
    Jose
    San Jose
    2003 Tacoma TRD
    3" lift
    It's a V-6
    keakar likes this.
  7. May 6, 2017 at 3:06 PM
    keakar
    karl
    louisiana
    ok, that helps
    yes you have a timing belt and it should be replaced every 100k miles are at least no more then at 150k miles, at this point with your mileage, its time to change your timing belt so you may as well do the full monty on it
    get the complete timing belt kit with everything and I suggest you put new idler pulleys or replace those bearings in them on the fan belts as well. they are notorious for going bad and making noise. I would say the fan belts idler bearings need changing every 30k miles or so.
    this is the timing belt kit if you want oem quality parts, he has a cheaper version if your ok using aftermarket parts but most of us agree, for this stuff you want to use oem stuff. http://www.ebay.com/itm/Toyota-3-4L...hash=item2c5bf69ef0:m:m4Q2V_w5K7vUbSPcBeUhWfA
    that kit doesn't include the fan belt idler pulleys so just check those and order them separately if needed
  8. May 6, 2017 at 3:27 PM
    b_r_o
    b_r_o refresco de carretera
    Alex
    WA
    2015 DCLB
    That's a good kit except for the bandos, they stretch. Mitsubishi belts (Like that timing belt) are better..
    YOU may have a seizing water pump or idler but you should simply take the accessory belts off 1 by 1 first and see if the noise goes away..
  9. May 6, 2017 at 3:28 PM
    b_r_o
    Alex
    WA
    2015 DCLB
    ..mitsuboshi belts.. damn auto correct..
  10. May 6, 2017 at 3:31 PM
    keakar
    karl
    louisiana
    well those are just the fan belts so that's why, you can get his kit without the fan belts or ask him to upgrade those to the oem Mitsubishi ones if you like. 98% of people don't care about the brand of a fan belt because none of them last very long anyway, all the important and vital components are oem factory brands
  11. May 6, 2017 at 3:35 PM
    b_r_o
    Alex
    WA
    2015 DCLB
    Yea but you're still dealing with screeching sounds if they stretch! You'll be tripping thinking your water pump is seized again LOL..
  12. May 6, 2017 at 4:27 PM
    keakar
    karl
    louisiana
    ya, like I said, he has versions of the kits without fan belts and personally I just go to napa and get the "gates" belts when I need fan belts, never had any issues with those
  13. May 6, 2017 at 4:31 PM
    02 quadcab
    02 quadcab Well-Known Member
    spray some belt conditioner on it shoudld stop the squeal.
  14. May 7, 2017 at 7:33 PM
    ZUK
    ZUK Gearinstalls.com
    Ken
    Chandler AZ
    2001 white Taco TRD 3.4L auto (SAS FJ60 flip) 35" KO2 5" AllPro leafpacks front and rear,
    SAS,1985 FJ60 flipped axle, 35" KO2,5" AllPro leafpacks front and rear,
    I presently have 201k miles on my timing belt (01 Taco 3.4L auto )and not a whisper from it ;)
    I would put money on the lower idler pulley on your fanbelts. I had it go out about 40,000 miles ago and it was only $35 on ebay. Being the lower one, it was super easy to replace from the underside.
    I think this is the one ....
    http://www.ebay.com/itm/Drive-Belt-...ash=item4d55f0e4d7:g:7rIAAOSw241YmKIE&vxp=mtr
    More research on my ebay purchase history and found it
    http://www.ebay.com/itm/Drive-Belt-...ash=item43eab88ce3:g:0t8AAOSwjDZYlv0t&vxp=mtr
  15. May 7, 2017 at 8:00 PM
    02 quadcab
    i had to replace the lower pull aswell $20 from autozone. super easy so no need for oem.
