Timing belt
Discussion in '1st Gen. Tacomas (1995-2004)' started by Swan, Mar 6, 2010.
  1. Mar 6, 2010 at 10:40 AM
    Swan
    Swan [OP] New Member
    Darren
    Long Beach, Ca.
    04 Pre Off Road
    Hi There. I have a 2004 tacoma extra cab 2wd with the trd package. It's sr5 and has a 6 foot bed. I have 104,000 miles on it. I have not changed the timing best. Am I living dangerously? Also, I bought the trd just to not get stuck in mud, as I do traffic data collection in muddy areas but would like to know how well the trd 2wd does off road. Thank You for any info.
  2. Mar 6, 2010 at 11:14 AM
    brg88tx
    brg88tx Well-Known Member
    i think it's supposed to be changed at 90,000 miles. i plan on changing mine at 100,000.
  3. Mar 6, 2010 at 4:35 PM
    SkyHighTacoma
    SkyHighTacoma Josh
    Josh
    Brazoria County Texas
    15 DCSB SR5 MGM
    The 5vz-fe (3.4l V6) is a non interference engine that means at TDC (top dead center) and the valves open the piston will NOT touch them. So if your timing belt breaks you will not destory you motor, you will only be stranded untill you get a new belt. And search around and you will find ALOT of answers. While you replace, you should also replace the water pump and thermostat since your already in there. And a TRD Prerunner is just fine with the locker engaged. :)
  4. Mar 6, 2010 at 8:29 PM
    RockyTacoma
    RockyTacoma Well-Known Member
    Dojo
    colorado
    2002 tacoma trd
    stock
    i changed mine at 87k. i just cant take chances
  5. Mar 6, 2010 at 8:32 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    I bought my truck used w/ 146,00 and did the belt at 156,000 just to get it done. The original belt and water pump were in there w/ a huge crust of dried up coolant everywhere. Please do your t belt as soon as possible!
  6. Mar 6, 2010 at 8:51 PM
    vicstacoma
    vicstacoma Guest
    how much did it run you for the whole thing??/ I have 128k on my truck and it was replaced at 60k so i'm almost due for another timing belt, water pump, and thermostat.
  7. Mar 6, 2010 at 8:53 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    I honestly don't remember. I got everything at NAPA auto parts. I got a gates belt, what ever brand of water pump they have there, and some black permatex sealent for the water pump gasket. I want to say $120 but don't quote me on that.
  8. Mar 6, 2010 at 11:23 PM
    vicstacoma
    vicstacoma Guest
    oh cool.. so it's not that much for the parts.. labor must be a little high though i'm guessing...??... i've replaced timing belts on a few 4 cylinder cars, but never on a v6 or v8 so i'm not sure if I trust myself to do the job.. lol
  9. Mar 6, 2010 at 11:27 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    My dad and I did it and it really isnt that bad. It is just time consuming. Our problem was not having the right tools and breaking like 3 socket drivers on the factory tight bolts.
  10. Mar 9, 2010 at 12:52 PM
    Muddytaco11
    Muddytaco11 Whatchamacallit Member
    David Ryan
    Alabama
    '02 Prerunner SR5 Few Small Mods
    Cold-air, Prosound Muffler and Duel out pipes, Stereo with XM, Streetglow underglow kit, Streetglow Interior kit, Tinted Lights, 10000K HID
    I'm at 125k on mine. I'm going to change mine next week. I found a website that sells Toyota parts pretty cheap, The Water Pump, Thermostat, and timing belt for less than $170. The website btw is http://www.toyotapartscheap.com/
    Thanks for the info guys.
