Timing chain cover bolt diagram
Discussion in '2nd Gen. Tacomas (2005-2015)' started by foampile, Sep 8, 2015.
  1. Sep 8, 2015 at 9:57 AM
    foampile
    foampile [OP] Well-Known Member
    Mid-Atlantic
    2007 V6 4WD 6 speed Extended Cab
    Does anybody have a diagram of the V6 timing chain cover that shows in which hole each bolt goes? There are something like, I believe 19 bolts of 4-5 different types. I have them all but I did not document which hole each came from. A detailed diagram specifying bolt sizes would greatly save me the pain of trial and error.
    Thanks
  2. Sep 8, 2015 at 3:32 PM
    Drivesector
    Drivesector Well-Known Member
    TRD sport
    TIMING CHAIN OR BELT COVER SUB-ASSEMBLY (for 1GR-FE)
    Install the timing chain cover with the 15 bolts and 2 nuts. Tighten the bolts and nuts uniformly in several steps.
    Torque 23 Nm (235 kgf-cm, 17 ft-lbf)
    Each bolt length is as follows:
    ramonortiz55 and foampile[OP] like this.
  3. Sep 8, 2015 at 3:38 PM
    foampile
    Mid-Atlantic
    Thanks, @Drivesector -- this is better than could I ever have hoped for :headbang:
    Are both the short and long bolts the same torque spec ? Also, for the two nuts, they go onto "set" bolts (or whatever you call them) that are put in using an inverse torx bit (so they look like a stud protruding from the engine block) -- do you know if their torque is the same ?
  4. Sep 8, 2015 at 3:55 PM
    Drivesector
    TRD sport
    The torque is The same for everything.
    foampile[OP] and ramonortiz55 like this.
  5. Sep 8, 2015 at 3:56 PM
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    :thumbsup::thumbsup::thumbsup:
  6. Sep 8, 2015 at 5:21 PM
    foampile
    Mid-Atlantic
    one more semi-related question. do you know if it's better to put the crankshaft oil seal on the cover before hanging the cover or after ? i am inclined to think after
  7. Sep 8, 2015 at 5:30 PM
    Drivesector
    TRD sport
    1GR-FE ENGINE MECHANICAL: FRONT CRANKSHAFT OIL SEAL: INSTALLATION
    1. INSTALL TIMING GEAR CASE OR TIMING CHAIN CASE OIL SEAL
    (a) Apply MP grease to a new oil seal lip.
    (b) Using SST and a hammer, tap in the oil seal until its surface is flush with the timing chain cover edge.
    SST : 09226-10010
    1. INSTALL CRANKSHAFT PULLEY See: Timing Chain\Service and Repair\Installation
    2. INSTALL FAN SHROUD See: Cooling System\Radiator\Service and Repair\Removal and Replacement\Installation
    3. INSTALL RADIATOR SUPPORT TO FRAME SEAL LH
    4. CONNECT CABLE TO NEGATIVE BATTERY TERMINAL
    Torque : 3.9 Nm (40 kgf-cm, 35 in-lbf)
    1. CHECK FOR ENGINE OIL LEAKAGE
    2. INSTALL ENGINE UNDER COVER SUB-ASSEMBLY (for 4WD and Pre Runner Drive Type)
    (a) Install the engine under cover with the 4 bolts.
    Torque : 29 Nm (296 kgf-cm, 21 ft-lbf)
    1. INSTALL V-BANK COVER
    (a) Install the V-bank cover with the 2 nuts.
    Torque : 7.5 Nm (76 kgf-cm, 66 in-lbf)
  8. Sep 8, 2015 at 5:37 PM
    foampile
    Mid-Atlantic
    in the absence of a SST, is there an alternative workaround ? like for example using a nail set or some such tool that concentrates force in a small area
  9. Sep 8, 2015 at 5:49 PM
    jeeprjames
    jeeprjames Well-Known Member
    James
    Summerville, SC
    2006 DCLB 4X4 TRD Radiant Red
    ICON Stage 2, Retrax Pro, frame replaced by Toyota!
    Thanks for this write up! Mine is starting to seep a little as well at 125K. Dealer wants $1100-$1200 to do this. The service rep said it's quoted at 11 hours labor!
  10. Sep 8, 2015 at 5:53 PM
    foampile
    Mid-Atlantic
    what is seeping, the time chain cover ? unless you have to take the cylinder heads off, i would say that is too much.
  11. Sep 8, 2015 at 6:12 PM
    jeeprjames
    James
    Summerville, SC
    Yeah, timing chain cover right where the block and head meet on the passenger side. They pointed it out when they were replacing my frame two weeks ago. I will keep an eye on it to see if it gets any worse.
  12. Sep 8, 2015 at 6:18 PM
    foampile
    Mid-Atlantic
    I can't see how that amounts to 11 hrs of work because it doesn't involve taking the chain off or cylinder heads. Now if it's leaking because the block is warped (vs. just the cover) that will end up costing a lot more. If only the gasket maker (the cover doesn't use a fixed gasket, only caulk-llike maker that you apply) went bad and that's why it leaks, that's easy. It could also be that the cover is bad and leaking (not likely) but a new cover is around $500.
    Taking the cover off is a little pain because you have to take the whole drive belt system off, meaning the power steering pump, AC pump, etc. but those are all low profile jobs well within the DIY domain. if you have to take the chain and/or the heads (which also means the chain), that adds complexity and $$
  13. Sep 8, 2015 at 6:31 PM
    jeeprjames
    James
    Summerville, SC
    I thought 11 hrs sounded a bit much as well. I will more than likely do it myself. Is it easier to do it by pulling the radiator out?
  14. Sep 8, 2015 at 6:35 PM
    foampile
    Mid-Atlantic
    No, you shouldn't pull the radiator out. It is very thin and won't get in the way any. You will have to take off the fan. Also, don't take the water pump off the cover (unless it or the gasket need replacement)
  15. Sep 9, 2015 at 4:20 AM
    jeeprjames
    James
    Summerville, SC
    Thanks in advance for the helpful info. The wealth of knowledge and info on TW is awesome!
    foampile[QUOTED][OP] likes this.
  16. Sep 9, 2015 at 8:00 AM
    R0dzilla75
    R0dzilla75 Well-Known Member
    Rodney
    Virginia
    05 Sport
    HID fog light 265-70-17 Firestone destination ATs Led interiors lights TRD seat covers
    Leave it alone unless you are loosing so much oil that it's requiring you to put a quart or more back in it between changes. Consider it rust prevention. Many have this problem. Very few have done anything about it. I have this issue and have ever had to put oil in between changes. Going on 11 years and 115 k miles.
    jeeprjames likes this.
  17. Sep 9, 2015 at 8:04 AM
    foampile
    Mid-Atlantic
    Sounds like a recurring issue. Do we know what's causing it or is it a crapchute ?
  18. Sep 9, 2015 at 8:11 AM
    R0dzilla75
    Rodney
    Virginia
    05 Sport
    From what I understand the factory used a type of liquid gasket and the fix is an actual physical gasket. In any case I wouldn't loose any sleep over tearing down your rig to fix it. It may get to the point that it needs fixing but mine has not yet.
  19. Sep 9, 2015 at 8:15 AM
    foampile
    Mid-Atlantic
    i was going to put gasket maker on mine. i wasn't aware there was such a thing as aftermarket 'physical gasket' that can be put in there.
  20. Sep 9, 2015 at 3:43 PM
    foampile
    Mid-Atlantic
    Hey @Drivesector , your diagram does not include the 4 bolts that connect the timechain cover to the oil pan
