Timing chain cover leak???
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 07 sport 4x4, Apr 5, 2011.
  1. Apr 7, 2011 at 7:36 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    I think its valid to point out that this is oil sip not oil leak. There is no pressure there only oil splashing from nozzles. So if you are out of warranty and don't have money to fix this, simply ignore it. If you want you can check if bolts in the area are tighten to spec.
    But this is no danger to the engine. :)
    R0dzilla75 and bigfoote13 like this.
  2. Apr 7, 2011 at 10:27 AM
    06RadiantRed
    06RadiantRed Well-Known Member
    CA-Bay Area
    2006 Tacoma 4x4 TRD Off Road - RadRed!!
    ICON ext. Travel Coilovers, TC UCAs, Fox 2.0 FJ Rear Shox + 2"AAL rear
    Well if this is no real issue to engine life/safety I'm fine with cleaning it and just watching it. I have not noticed any oil usage at all actually that I can notice. Have gone about 4k miles on the last two oil changes, and it still was fine at the end of the service interval. So as you guys suggest, maybe i will leave this on be. Ill try to get some better pictures, but iv never seen any oil on the floor, so cant be too bad.
  3. Apr 7, 2011 at 10:32 AM
    MxRacer190
    MxRacer190 Well-Known Member
    Georgia
    06 SR5 4x4 Indigo
    Mine has been leaking for about a year now. I took it in out of warranty, and they wanted to charge me $1400.00 to repair it. . . . fuuuuuuck-ah-that. I can't notice a difference between oil changes, it's going to leak until it blows up.
  4. Apr 7, 2011 at 10:34 AM
    river rat 69
    river rat 69 Well-Known Member
    Jim
    Orlando, Fla., Green side of the grass
    007, trd, sr5, fmf.
    NO Chrome,3" NFab's steps,TRD skid,Wet okie's.011 grill, k&n,5100's,All this comes right off when the old lady says let's go get a NEW ONE!!!
    1 qt. per 1000 miles was out of line. Im going to get this right! Can get it fixed For $850 if they dont find anything more then they already have, 30year pal is top dog in the back of a big ford dealership.I know who he puts on it they will work on it like its his moms truck. Think toyota and there dealer will have a good BM over this.
  5. Apr 7, 2011 at 1:19 PM
    06RadiantRed
    CA-Bay Area
    Well i got an email back today from SF Toyota. Said my service record with toyota, and the status of my truck was a good candidate for a good will service. But i need to bring in my truck for a $160 engine fluid leak inspection.. $160! Hmm. Its pretty obvious whats wrong I think.
    Thoughts?
  6. Apr 7, 2011 at 1:46 PM
    river rat 69
    Jim
    007, trd, sr5, fmf.
    More bull they replace the oil and filter and put paint on em, Find a new dealer!!! PS MINE DID TELL ME I HAD TO PAY THE 30 FOR THE NEW OIL !!!
  7. Apr 7, 2011 at 2:19 PM
    wlmuncy
    wlmuncy Well-Known Member
    William
    Knoxville, TN
    2007 Double Cab Manual 4*4
    160 for 1400 worth of work. I would do it and be happy. I would get the good will part in writing so they don't screw you over later.
  8. Apr 7, 2011 at 2:24 PM
    06RadiantRed
    CA-Bay Area
    Well, $160 for a CHANCE at a goodwill service.
  9. Apr 7, 2011 at 2:34 PM
    wlmuncy
    William
    Knoxville, TN
    That's why I say get it in writing that they will do the service for free when the test proves it needs to be done.
  10. Apr 7, 2011 at 2:39 PM
    06RadiantRed
    CA-Bay Area
    Im sure they wont do that. They are doing the test to make sure that the timing cover leak is the actual problem. When they confirm that, they will then contact Toyota USA, asking for a good will service for me. They will not guarantee it, and are requiring i do the inspection before i find out if the good will is going to happen.
  11. Apr 7, 2011 at 5:22 PM
    06TXED
    06TXED Well-Known Member
    Tony
    Aurora CO
    2023 DCSB MGM TRD OR 4x4
    I agree 100% my leak is so slight that I will just add oil as needed (nothing at this time) rather than take it to the dealer so they can open a huge can of worms. I would probably have to take it back for all the other issues that they would create while trying to fix it. After almost 3 months, the area that I have cleaned off is not seeping at all. Hopefully the leak does not get bad anytime soon.
  12. Apr 7, 2011 at 7:26 PM
    jinxed77
    jinxed77 Well-Known Member
    06 4.0L TRD SR5 4x4
    I had what I believe is the same leak. Passenger side timing cover near the power steering pump . Mine was under warranty. It was repaired around 36,000 if i remember right. Then the tech put the small square cover with four bolts on backwards then it leaked so i had to go back behind the tech and fix that. Oh they left a radiator clamp off too. Lucky it didn't blow on the way home.
  13. Apr 7, 2011 at 7:38 PM
    jinxed77
    06 4.0L TRD SR5 4x4
    I had the same timing cover leak repaired under warranty around 36,000 i believe.
    What thats insane. $800.00 isn't much better. If it calls for 7.7 and the labor rate at the shops in my area are $65.00 per hour thats $500.50 not including sealant. You both need to find another shop. Just call a reputable shop a check prices.
  14. Apr 7, 2011 at 7:48 PM
    jjw1
    jjw1 Well-Known Member
    Jesse
    Citrus County Florida
    2011 Super White DCSB TRD OR PreRunner
    Weather Tech Floor Liners, Truxedo Bed Cover, OEM Silver Step Bars, Debadged, Colormatched Satoshi, Wet Okoles, OEM Roof Rack, Bed Mat, Locking Gas Cap, and removed Mud Flaps
    Yep, take it in. I had this problem but mine had oil splattered all under the truck especially on the tranny pan and the front cross member
  15. Apr 7, 2011 at 9:20 PM
    #35
    river rat 69
    Jim
    007, trd, sr5, fmf.
    Mine was doing ok till a 2000k trip to S port, La. and back and all hell came about. If you go out on road trip high speed for hrs. watch it. Jim
  16. Apr 7, 2011 at 9:36 PM
    #36
    Bodete
    Bodete Well-Known Member
    Missouri
    2018 Tacoma TRD Off Road
    My timing chain cover was leaking just behind the power steering at only 20,000 miles. The dealership had it for over a day. They actually did a good job fixing it. One year later no leaks. If you got a leak and your under warranty get it fixed. The list of things the dealership fixed... gaskets, parts, oil and coolant pretty much filled up the repair receipt.
  17. Apr 7, 2011 at 9:47 PM
    #37
    A7XTaco
    A7XTaco Member
    Bryan
    Austin, TX
    You don't want to know...
    Just find exactly where its leaking, and put a good heavy coat of oil/gas rated silicone on it.
    R0dzilla75 likes this.
  18. Apr 8, 2011 at 7:00 AM
    #38
    river rat 69
    Jim
    007, trd, sr5, fmf.
    My x dealer in Orl. starts at 86$ per hr. up to 99$ per hr as to how hard the job is= bend over. 600$ to replace pulley on o7 v6 ac unit 637.35 for pulley. 1237.00 byo ky. Jim
  19. May 12, 2011 at 8:58 PM
    #39
    dmicgrif
    dmicgrif Well-Known Member
    mike
    kihei, maui
    2005, 4x4, 4 door, LB, black all over
    yeah just took my truck in and had to 50 bucks for the 1200 dollar job. so glad i bought the toyota care.
  20. May 12, 2011 at 9:00 PM
    #40
    dmicgrif
    mike
    kihei, maui
    you think that they would do a recall or something of that nature since everyone is having this problem.
