Timing chain cover leaking i think.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tunajoe13, Dec 10, 2013.
  1. Dec 10, 2013 at 11:01 AM
    Tunajoe13
    Tunajoe13 [OP] Well-Known Member
    Joe
    Parrish, FL
    05’ Base V6 4x4 extended cab
    20'' wheels, 34''x11" Toyo Open Country A/T II tires, 4.88 Gears, ARB Locking Rear Diff, ARB compressor, Fiberglass bed cover, Weathertech floor liners, Weathertech side window protectors, Allpro Apex front bumper, Allpro Apex rear bumper Allpro 3'' Expo rear leaf kit, Allpro hidden hitch receiver, 10'' aluminum drop hitch, Camburg 4'' spindles, Allpro uniball uca's, Ottonavi 6.5'' touch screen G.P.S, 09' Tailgate with factory reverse camera, Stampede hood protector, Raptor style grill and hood mesh (Homertaco), Piaa 5100 Fog lights, Volt HID's, Viper5704 Alarm with remote start, Limo tint, Scangauge II, TRD cai, URD 3'' Mk2 exhaust, Doug Thorley LT headers, URD Y-pipe, Unichip PnP Pcm, Unichip Flux2 display, Factory Sport hood....
    So i went under my truck today (1 week after degreasing the engine bay) and found a oil leak on the front passengers side of my engine and the steering rack is wet. :( …. Seems I have an 05 which makes me think I have the dreaded timing cover gasket tsb issue but I'm out of warranty. FML!
  2. Dec 10, 2013 at 11:18 AM
    jw1983
    jw1983 Well-Known Member
    Alberta
    13' Tacoma Access 4x4 OR
    Pictures would be great.
  3. Dec 10, 2013 at 11:25 AM
    wrmathis
    wrmathis Dark Lord of the Sith
    Bonaire, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
    the power steering pump is the problem. the top bolt hole mounts between the timing cover and the block. its a tight fit. if you remove the PS pump and grind a little bit off the bolt hole on teh powersteering pump with a dremel, so that the PS pump doesnt push the timing cover out, it will fit better and should fix the issue. there is a TSB out for this. or atleast there was but with an 05 you would have to pay for it. its an easy fix
    when i swapped motors, i couldnt get my PS pump to fit back into the mounting spot on the engine. if i didnt grind a little bit off, it would have caused this issue. anyways, i did it with out removing any of the lines going to the pump. just remove fan/shroud, serpintine belt, and 2 bolts for power steering pump and pull it down to the bottom to get a dremel up there. you dont have to grind much off
    rogotoko likes this.
  4. Dec 10, 2013 at 4:59 PM
    wrmathis
    Bonaire, GA
    parts and stuff
    or you know, jsut do what i did and fix it self in about an hour
