Timing chain cover oil leak
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Billy58, Mar 19, 2024.
  1. Jun 24, 2024 at 6:18 PM
    Ronk44
    Ronk44 Well-Known Member
    Rockerville, SD
    2017 MGM Sport
    Leveled with Bilstein 5100 shocks, Falken Rubitrek AT 265/75 tires, Redline hood struts, R4T tailgate lock, Matt Gecko LED strips in bed and under hood, WeatherTech hood guard, OEM bed mat, Husky floor mats, Carhart seat covers, Grille replacement with Toyota letters, Sony AX6000 head unit, OTT lite/mild tune, and an occasional splash of fuel additive.
    My aftermarket (sold at dealership) extended warranty covered my $3200 timing cover leak repair. Mine was taken apart from the bottom up without pulling engine.
  2. Jun 24, 2024 at 6:20 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    This timing cover leak in the 3.5 V6 is prevalent across all Toyota/Lexus models. We had it in our 07 Lexus ES350, and now in our 18 RX350. Have seen also seen it in Camry and Rav4 forums. It seeps where the right bank head and timing cover meet. On most engines it is just a seep. You may never notice the oil level drop on the dip stick because of it. I never have. Eventually it did on the ES but that was at 200K+ due to worn piston rings. It is covered under warranty but probably better to ignore it and just keep the area clean. Many have reported the leak returning. It can be controlled to en extent by going thicker oil.
    usmc2msu and bgavin like this.
  3. Jun 27, 2024 at 5:29 PM
    bgavin
    bgavin Well-Known Member
    Orangevale, CA
    2023 Tacoma Access Cab, V6, 4WD, A/T, OTT Medium/Spicy
    CURT Mfg front receiver, anti-theft cages around cats
    I asked this question of my shop-owner buddy who specializes in Japanese vehicles.
    I asked "why no gasket" and he said all the makers eventually figured out that a true metal-to-metal surface with some some fancy sealant lasted longer than a gasket.
    He said Nissan was the last to figure this out, before they went to no-gasket precision surfaces.
    He also said the weep is many cases is minuscule, a few drops.
    For myself, I will tolerate this to avoid the stealership hauling the engine out, or otherwise screwing something up that would otherwise be OK.
    Unless the weep is chronic, it's a sleeping dog that I won't bother to kick.
    usmc2msu and Chuy like this.
