timing chain or timing belt ?
Discussion in '1st Gen. Tacomas (1995-2004)' started by sunflower, Apr 30, 2012.
  1. Apr 30, 2012 at 4:39 PM
    sunflower
    sunflower [OP] Well-Known Member
    I have a 2002 Tacoma with V6 and 97,000 miles. I heard something about replacing either a timing BELT or a timing CHAIN at 95,000 miles but I dont know which one it is.
  2. Apr 30, 2012 at 4:40 PM
    CNEDEER
    CNEDEER If ya ain't first, your last!
    2015 DC SR5 4x4
  3. Apr 30, 2012 at 4:46 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    and yes you need to change it along with the water pump ASAP. It was due at 90k.
  4. Apr 30, 2012 at 4:47 PM
    hayabusa3303
    hayabusa3303 Well-Known Member
    florence sc
    95.5 taco 4x4
    ARB bumper, warn 9.5 winch. carbon fiber hood. Leer top with thule racks and MOAB from thule. Electric fans, blue sea fuse block, Sony dvd Head unit, Xm tuner and HD tuner. New carpet and new racing seats. ( other half doesnt like them i think). Nwor springs and adjustable coil overs. Sky jacker rear shocks. Slot and drilled rotors. Engine Titanium ceramic coated headers, no cat, jba cat back. URD Rear Sensor Simulator. Leds all around and inside cab and HID H4 hi/lo beams.
    Now is the time to replace water pump and all the roller bearings while you are in there.
    Check the tensioner too while you are at it make sure its in spec. If not replace.
  5. Apr 30, 2012 at 4:50 PM
    sunflower
    Does anyone know how much the dealer or a reputable shop would charge for this ?
    Oh, and the people I bought the truck from said something about them replacing the belts, so how would I tell if they are new or old ?
  6. Apr 30, 2012 at 4:55 PM
    Leggo
    Leggo slow is smooth, and smooth is fast.
    Newton,Ma.
    10 TRD Sport AC 4x4 MGM
    Kenwood HU,Infinity Kappa speakers (x4), Infinity reference tweeters(x2),10" Kicker sub, Box by Subthump, Infinty Five channel amp,DVD anytime bypass, DTRL Mod, Xtang trifecta, Fogs anytime Mod, Bed Mat,Westin running boards, Console vault, Maglite mod, Weathertechs,Autopage remote starter, Power tailgate lock, HID Bi Zenon, Hella Supertones,Rain guards,Rear leaf TSB,Steering shaft TSB, Fisher Homesteader plow, 886 reverse lights mod, Redline Hood struts, Hankook Dynapro ATM LT265/70R17, power sliding rear window, Auto dimming/on anytime Bed lights, Blue Sea fuse panel & 100amp Breaker, de- badged,Rear headrest's removed, imMrYo mirror relocation,Homeroshi grill
    Last time I checked, I think it was around $650.00. That was for my 2003 v-6. I think it included a new water pump. It was a long time ago so I could be way off.
  7. Apr 30, 2012 at 4:56 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    they should write the last time it was changed on the timing cover. If there's nothing on the cover then I would assume its original.
    Not sure on prices, I did it myself for under around 140 or so.
  8. Apr 30, 2012 at 4:58 PM
    hayabusa3303
    florence sc
    95.5 taco 4x4
    The dealer here last time i checked was 399 for the replacement not including other stuff (Ie water pump or anything else)
    Rule of thumb this is what i do replace timing belt replace all other belts and they are good to go till i replace the belts again I do mine a 60,000 miles.
    As long as the belts are not cracking split torn anything like that they are ok. Look in the groove part of the belt if you see the ribs cracking badly or some is missing replace the belt.
  9. May 1, 2012 at 6:29 AM
    BVCOTaco
    BVCOTaco Well-Known Member
    BV, CO
    02 Xtra Cab SR5 TRD
    ARB Bullbar
    I just had this done on my 02 Tacoma V6 about a month ago. The truck had 140k on it when I bought it and there was no record of the timing belt being changed. I had a toyota dealership in Colorado Springs do it and it was $600 for the time belt and replacing the water pump. The dealer put a sticker on the air filter box stating the mileage it was changed at.
