Timing Chain P0018 P0302,304,306
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Hdiscus7, Aug 10, 2018.
  1. Aug 20, 2018 at 2:32 PM
    #141
    Hdiscus7
    Hdiscus7 [OP] Well-Known Member
    Jay
    2006 Tacoma TRD Off-road 4x4 V6
    Another two rotations. The screw driver is the casting mark and with the crank at this position everything lines up. But it looks to be a hair off of 0 degrees again
  2. Aug 20, 2018 at 2:46 PM
    #142
    craigs1
    craigs1 Well-Known Member
    2007 4Runner Limited, 4.0L
    The "hair" may be normal chain slack. With the crank exactly on the zero casting mark, put your 24mm wrench on the intake cam that appears off and *gently* rotate that cam toward its zero mark, taking up the chain slack and countering the forces of that cam's (and it's corresponding exhaust cam's) valvesprings. Don't apply enough force to do any more than take up chain slack...and see if the timing marks line up exactly on their timing marks.
  3. Aug 20, 2018 at 3:30 PM
    #143
    Hdiscus7
    Jay
    I’ve decided to just go ahead and reset the chain with the crank at complete 0 just to be absolutley certain. Won’t take long, but my other question is, what happens when the cam phaser moves and the cam shaft stayed the same when I was taking the bolt out of it? Do the camshafts have specs on exactly how the should be matching up with the cam phasers?
  4. Aug 20, 2018 at 3:33 PM
    #144
    craigs1
    The VVT actuators have a lock pin that engages when no oil pressure is present, so the entire sprocket and vane assembly moves as one piece.
    If you re-do the chain, make sure you use the colored endplates again and put them correctly on their respective marks as shown in the manual. Crank has a dot on the sprocket, bank 1 intake cam has the single long line, bank 2 intake cam has the two short lines.
  5. Aug 20, 2018 at 3:33 PM
    #145
    Hdiscus7
    Jay
    I’m guessing that actually needs to be corrected
  6. Aug 20, 2018 at 3:35 PM
    #146
    craigs1
    The valvesprings are exerting pressure against the cam lobes and will rotate the cam in whichever direction the lobe ramp is facing at the time. I found that when each intake cam was positioned exactly against its timing mark, the forces were neutral and the cam stayed in place...but it only took a degree or two before the valvesprings forced the cam to rotate violently.
  7. Aug 20, 2018 at 3:37 PM
    #147
    Hdiscus7
    Jay
    Never mind @craigs1 I didn’t realize they only go on one way. I may have been imaging it since I’ve been working on this for so long
  8. Aug 20, 2018 at 3:38 PM
    #148
    craigs1
    And if you're really disassembling the sprockets from the cams, you may want to put the exhaust chains on w/ the colored endplates facing rearward as the manual specifies and my pictures show. The intake sprockets have dots on the cam teeth facing rearward...this way you can see the colored endplate and sprocket dot aligned on top of each other.
  9. Aug 20, 2018 at 3:40 PM
    #149
    Hdiscus7
    Jay
    Just wanted to confirm @craigs1 if you think that’s pretty spot on 0 for the crank
  10. Aug 20, 2018 at 3:44 PM
    #150
    craigs1
    No, the dot appears to be slightly before the block line. Needs to be right on top of it.
  11. Aug 20, 2018 at 3:47 PM
    #151
    Hdiscus7
    Jay
    @craigs1 you’re gonna laugh because I’ve been trying to line it up by the raised part on the dang crankshaft itself. Lord have mercy
  12. Aug 20, 2018 at 3:50 PM
    #152
    craigs1
    Use the small indented dot on the crank reluctor wheel's flat surface, and place it directly on top of the block casting line.
    edit: here's my pic again, with a red arrow pointing to the indented dot on the reluctor wheel's flat surface. When looking straight at the dot and block casting line the dot should be directly on top of the block casting line.
  13. Aug 20, 2018 at 3:56 PM
    #153
    craigs1
    And is this bare metal showing on your tensioner guiderail??
  14. Aug 20, 2018 at 4:03 PM
    #154
    Hdiscus7
    Jay
    Quick question. @craigs1 on the back of the cam phaser for the small chain does the colored link line up with the single dot or double dots and no not bare metal just wear oil residue is gone
  15. Aug 20, 2018 at 4:12 PM
    #155
    craigs1
    I guess reading the manual I keep posting just isn't gonna happen...here's the pic from step 37 showing the double dots for bank 2 intake sprocket:
  16. Aug 20, 2018 at 4:19 PM
    #156
    Hdiscus7
    Jay
    My apologies @craigs1 seriously. I’ll make sure to check the manual before dropping in here. I’m glad I caught that though because I was about to put it on dot 1.
  17. Aug 20, 2018 at 4:37 PM
    #157
    craigs1
    It sure takes the guesswork right out of the process. This was my first DOHC engine project, so I overcompensated by reading the shop manual and taking notes before I picked up a wrench...and then printed the relevant sections to use as a checklist while I was working.
    Biscuits and PzTank like this.
  18. Aug 20, 2018 at 4:49 PM
    #158
    craigs1
    Getting back to the o-rings and crankshaft seal, the drawings below show each one you'll need. Dealership parts dept is a sure thing, just bring these diagrams and they can look them up.
    PzTank likes this.
  19. Aug 20, 2018 at 4:51 PM
    #159
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    LOL, OP, I'm not even doing this and I read the manual so I could follow along, although it did take me a bit to find the right link in that long list (awesome links, BTW, all the info you need and more). Again, props to you for tackling this and to @craigs1 for his patience. Almost there . . .
    Those guides are kind of a wear part, did you get new guides? Chain angle on the left side of the crank sprocket looked a bit funny on one of your early pics, although it smoothed out on later ones.
    You are almost there, just get your marks figured out, do the 2 rotations and button things up with new gaskets and o-rings.
  20. Aug 20, 2018 at 5:36 PM
    #160
    PzTank
    PzTank Stuck in the Well
    Above the Notches
    ‘15 AC SR5 4X4 4.0 Auto
    ‘07 OR leather shift knob
    If I'm ever in a tight situation, for whatever reason, I hope to have a @craigs1 in my corner:hattip:
    Good Luck @Hdiscus7 :cheers:Pretty ballsy taking this project on with a limited budget. If you're gonna cut corners, carefully weigh which ones:sawzall:. PM me if you need $$ for gaskets.
    Biscuits likes this.
